[PATCH v2 3/3] bsps/sparc: Change tabs to spaces.
Daniel Cederman
cederman at gaisler.com
Tue May 13 15:21:08 UTC 2014
c/src/lib/libbsp/sparc/erc32/clock/ckinit.c | 10 +-
.../lib/libbsp/sparc/erc32/console/erc32_console.c | 4 +-
.../lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c | 4 +-
c/src/lib/libbsp/sparc/erc32/include/bsp.h | 4 +-
c/src/lib/libbsp/sparc/erc32/startup/spurious.c | 6 +-
c/src/lib/libbsp/sparc/leon2/cchip/cchip.c | 440 ++++++++++----------
c/src/lib/libbsp/sparc/leon2/clock/ckinit.c | 2 +-
c/src/lib/libbsp/sparc/leon2/console/console.c | 2 +-
c/src/lib/libbsp/sparc/leon2/include/bsp.h | 2 +-
c/src/lib/libbsp/sparc/leon2/include/leon.h | 92 ++--
c/src/lib/libbsp/sparc/leon2/include/rasta.h | 14 +-
c/src/lib/libbsp/sparc/leon2/rasta/rasta.c | 2 +-
c/src/lib/libbsp/sparc/leon2/startup/spurious.c | 4 +-
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 8 +-
c/src/lib/libbsp/sparc/leon3/include/leon.h | 6 +-
.../sparc/leon3/leon_smc91111/leon_smc91111.c | 10 +-
c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c | 6 +-
c/src/lib/libbsp/sparc/leon3/startup/spurious.c | 4 +-
18 files changed, 309 insertions(+), 311 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
index 0ae8482..25504f1 100644
--- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
@@ -82,14 +82,14 @@ static CPU_Counter_ticks erc32_counter_difference(
rtems_configuration_get_microseconds_per_tick(); \
ERC32_MEC_Set_Real_Time_Clock_Timer_Control( \
- ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
- ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
- ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
+ ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
+ ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
+ ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
- ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
+ ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
_SPARC_Counter_initialize( \
&ERC32_MEC.Real_Time_Clock_Counter, \
diff --git a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
index 212d5e0..81dfe02 100644
--- a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
+++ b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
@@ -148,7 +148,7 @@ static int erc32_console_first_open(int major, int minor, void *arg)
#if (CONSOLE_USE_INTERRUPTS)
static ssize_t erc32_console_write_support_int(
- int minor, const char *buf, size_t len)
+ int minor, const char *buf, size_t len)
if (len > 0) {
console_data *cd = &Console_Port_Data[minor];
@@ -264,7 +264,7 @@ static void erc32_console_isr_b(
buf[i] = ERC32_MEC.UART_Channel_B;
++i;
- if ( i )
+ if ( i )
rtems_termios_enqueue_raw_characters(cd->termios_data, buf, i);
/* dequeue transmitted chars */
diff --git a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
index f4ad2f1..0226905 100644
--- a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
+++ b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
@@ -112,9 +112,9 @@ int rtems_erc32_sonic_driver_attach(struct rtems_bsdnet_ifconfig *config)
ERC32_MEC.IO_Configuration |=
- (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
+ (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
ERC32_MEC.Control &= ~0x60001; /* Disable DMA time-out, parity & power-down */
- ERC32_MEC.Control |= 0x10000; /* Enable DMA */
+ ERC32_MEC.Control |= 0x10000; /* Enable DMA */
ERC32_MEC.Interrupt_Mask &= ~(1 << (SONIC_VECTOR - 0x10));
return(rtems_sonic_driver_attach( config, &erc32_sonic_configuration ));
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index b2c1b91..775a19f 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -63,8 +63,8 @@ struct rtems_bsdnet_ifconfig;
extern int rtems_erc32_sonic_driver_attach(
-#define RTEMS_BSP_NETWORK_DRIVER_NAME "sonic1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_erc32_sonic_driver_attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME "sonic1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_erc32_sonic_driver_attach
/* Constants */
diff --git a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
index b8408f2..38c2259 100644
--- a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
@@ -160,9 +160,9 @@ void bsp_spurious_initialize()
* paramaters to the program.
- if (( trap == 5 || trap == 6 ) ||
- (( trap >= 0x11 ) && ( trap <= 0x1f )) ||
- (( trap >= 0x70 ) && ( trap <= 0x83 )))
+ if (( trap == 5 || trap == 6 ) ||
+ (( trap >= 0x11 ) && ( trap <= 0x1f )) ||
+ (( trap >= 0x70 ) && ( trap <= 0x83 )))
continue;
set_vector( (rtems_isr_entry) bsp_spurious_handler,
diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
index 6dc965f..09d8a4c 100644
--- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
+++ b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
@@ -50,70 +50,70 @@ void cchip1_set_isr(void *handler, int irqno, void *arg);
#define READ_REG(address) _READ_REG((unsigned int)address)
static __inline__ unsigned int _READ_REG(unsigned int addr) {
- unsigned int tmp;
- __asm__ ("lda [%1]1, %0 "
- : "=r"(tmp)
- : "r"(addr)
- return tmp;
+ unsigned int tmp;
+ __asm__ ("lda [%1]1, %0 "
+ : "=r"(tmp)
+ : "r"(addr)
+ return tmp;
/* PCI bride reg layout on AMBA side */
typedef struct {
- unsigned int bar0;
- unsigned int bar1;
- unsigned int bar2;
- unsigned int bar3;
- unsigned int bar4;/* 0x10 */
+ unsigned int bar0;
+ unsigned int bar1;
+ unsigned int bar2;
+ unsigned int bar3;
+ unsigned int bar4;/* 0x10 */
- unsigned int unused[4*3-1];
+ unsigned int unused[4*3-1];
- unsigned int ambabars[1]; /* 0x40 */
+ unsigned int ambabars[1]; /* 0x40 */
} amba_bridge_regs;
/* PCI bride reg layout on PCI side */
typedef struct {
- unsigned int bar4; /* 0x10 */
- unsigned int ilevel;
- unsigned int ipend;
- unsigned int iforce;
- unsigned int istatus;
- unsigned int iclear;
- unsigned int imask;
+ unsigned int bar4; /* 0x10 */
+ unsigned int ilevel;
+ unsigned int ipend;
+ unsigned int iforce;
+ unsigned int istatus;
+ unsigned int iclear;
+ unsigned int imask;
} pci_bridge_regs;
typedef struct {
- pci_bridge_regs *pcib;
- amba_bridge_regs *ambab;
+ pci_bridge_regs *pcib;
+ amba_bridge_regs *ambab;
- /* AT697 PCI */
- unsigned int bars[5];
- int bus, dev, fun;
+ /* AT697 PCI */
+ unsigned int bars[5];
+ int bus, dev, fun;
- /* AMBA bus */
- struct ambapp_bus amba_bus;
- struct ambapp_mmap amba_maps[2];
+ /* AMBA bus */
+ struct ambapp_bus amba_bus;
+ struct ambapp_mmap amba_maps[2];
- /* FT AHB SRAM */
- int ftsram_size; /* kb */
- unsigned int ftsram_start;
- unsigned int ftsram_end;
+ /* FT AHB SRAM */
+ int ftsram_size; /* kb */
+ unsigned int ftsram_start;
+ unsigned int ftsram_end;
} cchip1;
cchip1 cc1;
int init_pcif(void){
- unsigned int com1;
- int i,bus,dev,fun;
- struct ambapp_bus *abus;
+ unsigned int com1;
+ int i,bus,dev,fun;
+ struct ambapp_bus *abus;
if ( BSP_pciFindDevice(0x1AC8, 0x0701, 0, &bus, &dev, &fun) == 0 ) {
@@ -126,247 +126,247 @@ int init_pcif(void){
/* found Companionship PCI board, Set it up: */
- pci_read_config_dword(bus, dev, fun, 0x10, &cc1.bars[0]);
- pci_read_config_dword(bus, dev, fun, 0x14, &cc1.bars[1]);
- pci_read_config_dword(bus, dev, fun, 0x18, &cc1.bars[2]);
- pci_read_config_dword(bus, dev, fun, 0x1c, &cc1.bars[3]);
- pci_read_config_dword(bus, dev, fun, 0x20, &cc1.bars[4]);
+ pci_read_config_dword(bus, dev, fun, 0x10, &cc1.bars[0]);
+ pci_read_config_dword(bus, dev, fun, 0x14, &cc1.bars[1]);
+ pci_read_config_dword(bus, dev, fun, 0x18, &cc1.bars[2]);
+ pci_read_config_dword(bus, dev, fun, 0x1c, &cc1.bars[3]);
+ pci_read_config_dword(bus, dev, fun, 0x20, &cc1.bars[4]);
#ifdef DEBUG
- for(i=0; i<5; i++){
- printk("PCI: BAR%d: 0x%x\n\r",i,cc1.bars[i]);
+ for(i=0; i<5; i++){
+ printk("PCI: BAR%d: 0x%x\n\r",i,cc1.bars[i]);
#endif
- /* Set up PCI ==> AMBA */
- pcib = (void *)cc1.bars[0];
- pcib->bar0 = 0xfc000000;
-/* pcib->bar1 = 0xff000000;*/
+ /* Set up PCI ==> AMBA */
+ pcib = (void *)cc1.bars[0];
+ pcib->bar0 = 0xfc000000;
+ /* pcib->bar1 = 0xff000000;*/
#ifdef BOARD_INFO
- printk("Found CCHIP1 Board at 0x%lx\n\r",(unsigned int)pcib);
+ printk("Found CCHIP1 Board at 0x%lx\n\r",(unsigned int)pcib);
#endif
- /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
- cc1.amba_maps[0].size = 0x04000000;
- cc1.amba_maps[0].local_adr = cc1.bars[1];
- cc1.amba_maps[0].remote_adr = 0xfc000000;
+ /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
+ cc1.amba_maps[0].size = 0x04000000;
+ cc1.amba_maps[0].local_adr = cc1.bars[1];
+ cc1.amba_maps[0].remote_adr = 0xfc000000;
- /* Mark end of table */
- cc1.amba_maps[1].size=0;
- cc1.amba_maps[1].local_adr = 0;
- cc1.amba_maps[1].remote_adr = 0;
+ /* Mark end of table */
+ cc1.amba_maps[1].size=0;
+ cc1.amba_maps[1].local_adr = 0;
+ cc1.amba_maps[1].remote_adr = 0;
- /* Enable I/O and Mem accesses */
- pci_read_config_dword(bus, dev, fun, 0x4, &com1);
- com1 |= 0x3;
- pci_write_config_dword(bus, dev, fun, 0x4, com1);
+ /* Enable I/O and Mem accesses */
+ pci_read_config_dword(bus, dev, fun, 0x4, &com1);
+ com1 |= 0x3;
+ pci_write_config_dword(bus, dev, fun, 0x4, com1);
- /* Set up AMBA Masters ==> PCI */
- ambab = (void *)(cc1.bars[1]+0x400);
+ /* Set up AMBA Masters ==> PCI */
+ ambab = (void *)(cc1.bars[1]+0x400);
#ifdef DEBUG
- printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",0,ambab->bar0,pcib->bar0);
- printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
- printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
+ printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",0,ambab->bar0,pcib->bar0);
+ printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
+ printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
#endif
- /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
- ambab->ambabars[0] = 0x40000000;
- /* Scan bus for AMBA devices */
- abus = &cc1.amba_bus;
- memset(abus,0,sizeof(*abus));
- ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
- /* Init all msters, max 16 */
- for(i=1; i<16; i++) {
- ambab->ambabars[i] = 0x40000000;
- if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
- break;
- /* Enable PCI Master */
+ /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
+ ambab->ambabars[0] = 0x40000000;
+ /* Scan bus for AMBA devices */
+ abus = &cc1.amba_bus;
+ memset(abus,0,sizeof(*abus));
+ ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
+ /* Init all msters, max 16 */
+ for(i=1; i<16; i++) {
+ ambab->ambabars[i] = 0x40000000;
+ if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
+ break;
+ /* Enable PCI Master */
com1 |= 0x4;
- cc1.pcib = pcib;
- cc1.ambab = ambab;
- cc1.bus = bus;
- cc1.dev = dev;
- cc1.fun = fun;
+ cc1.pcib = pcib;
+ cc1.ambab = ambab;
+ cc1.bus = bus;
+ cc1.dev = dev;
+ cc1.fun = fun;
- return 0;
+ return 0;
#ifndef GAISLER_FTAHBRAM
#define GAISLER_FTAHBRAM 0x50
#endif
int init_onboard_sram(void){
- struct ambapp_ahb_info ahb;
- struct ambapp_apb_info apb;
- unsigned int conf, size;
- /* Find SRAM controller
- * 1. AHB slave interface
- * 2. APB slave interface
- if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
- &apb) != 1 ){
- printk("On Board FT SRAM not found (APB)\n");
- return -1;
- if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
- &ahb) != 1 ){
- printk("On Board FT SRAM not found (AHB)\n");
- return -1;
- /* We have found the controller.
- * Get it going.
- * Get size of SRAM
- conf = *(unsigned int *)apb.start;
- size = (conf >>10) & 0x7;
- /* 2^x kb */
- cc1.ftsram_size = 1<<size;
- cc1.ftsram_start = ahb.start[0];
- cc1.ftsram_end = size*1024 + cc1.ftsram_start;
+ struct ambapp_ahb_info ahb;
+ struct ambapp_apb_info apb;
+ unsigned int conf, size;
+ /* Find SRAM controller
+ * 1. AHB slave interface
+ * 2. APB slave interface
+ if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER,
+ GAISLER_FTAHBRAM, &apb) != 1 ){
+ printk("On Board FT SRAM not found (APB)\n");
+ return -1;
+ if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER,
+ GAISLER_FTAHBRAM, &ahb) != 1 ){
+ printk("On Board FT SRAM not found (AHB)\n");
+ return -1;
+ /* We have found the controller.
+ * Get it going.
+ * Get size of SRAM
+ conf = *(unsigned int *)apb.start;
+ size = (conf >>10) & 0x7;
+ /* 2^x kb */
+ cc1.ftsram_size = 1<<size;
+ cc1.ftsram_start = ahb.start[0];
+ cc1.ftsram_end = size*1024 + cc1.ftsram_start;
#ifdef BOARD_INFO
- printk("Found FT AHB SRAM %dkb at 0x%lx\n",cc1.ftsram_size,cc1.ftsram_start);
+ printk("Found FT AHB SRAM %dkb at 0x%lx\n",cc1.ftsram_size,cc1.ftsram_start);
#endif
- return 0;
+ return 0;
int cchip1_register(void){
- /* Init AT697 PCI Controller */
- init_pci();
- /* Find & init CChip board .
- * Also scan AMBA Plug&Play info for us.
- if ( init_pcif() ){
- printk("Failed to initialize CCHIP board\n\r");
- return -1;
- /* Set interrupt common board stuff */
- cchip1_irq_init();
- /* Find on board SRAM */
- if ( init_onboard_sram() ){
- printk("Failed to register On Board SRAM. It is needed by b1553BRM\n");
- return -1;
- /* Register interrupt install functions */
- b1553brm_pci_int_reg = cchip1_set_isr;
- occan_pci_int_reg = cchip1_set_isr;
- grspw_pci_int_reg = cchip1_set_isr;
- apbuart_pci_int_reg = cchip1_set_isr;
- /* register the BRM PCI driver, use 16k FTSRAM... */
- if ( b1553brm_pci_register(&cc1.amba_bus,0,0,3,cc1.ftsram_start,0xffa00000) ){
- printk("Failed to register BRM PCI driver\n");
- return -1;
- /* register the BRM PCI driver, no DMA memory... */
- if ( occan_pci_register(&cc1.amba_bus) ){
- printk("Failed to register OC_CAN PCI driver\n");
- return -1;
- /* register the GRSPW PCI driver, use malloc... */
- if ( grspw_pci_register(&cc1.amba_bus,0,0xe0000000) ){
- printk("Failed to register GRSPW PCI driver\n");
- return -1;
- /* register the APBUART PCI driver, no DMA memory */
- if ( apbuart_pci_register(&cc1.amba_bus) ){
- printk("Failed to register APBUART PCI driver\n");
- return -1;
- return 0;
+ /* Init AT697 PCI Controller */
+ init_pci();
+ /* Find & init CChip board .
+ * Also scan AMBA Plug&Play info for us.
+ if ( init_pcif() ){
+ printk("Failed to initialize CCHIP board\n\r");
+ return -1;
+ /* Set interrupt common board stuff */
+ cchip1_irq_init();
+ /* Find on board SRAM */
+ if ( init_onboard_sram() ){
+ printk("Failed to register On Board SRAM. It is needed by b1553BRM\n");
+ return -1;
+ /* Register interrupt install functions */
+ b1553brm_pci_int_reg = cchip1_set_isr;
+ occan_pci_int_reg = cchip1_set_isr;
+ grspw_pci_int_reg = cchip1_set_isr;
+ apbuart_pci_int_reg = cchip1_set_isr;
+ /* register the BRM PCI driver, use 16k FTSRAM... */
+ if ( b1553brm_pci_register(&cc1.amba_bus,0,0,3,cc1.ftsram_start,0xffa00000) ){
+ printk("Failed to register BRM PCI driver\n");
+ return -1;
+ /* register the BRM PCI driver, no DMA memory... */
+ if ( occan_pci_register(&cc1.amba_bus) ){
+ printk("Failed to register OC_CAN PCI driver\n");
+ return -1;
+ /* register the GRSPW PCI driver, use malloc... */
+ if ( grspw_pci_register(&cc1.amba_bus,0,0xe0000000) ){
+ printk("Failed to register GRSPW PCI driver\n");
+ return -1;
+ /* register the APBUART PCI driver, no DMA memory */
+ if ( apbuart_pci_register(&cc1.amba_bus) ){
+ printk("Failed to register APBUART PCI driver\n");
+ return -1;
+ return 0;
static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v);
static unsigned int cchip1_spurious_cnt;
typedef struct {
- unsigned int (*handler)(int irqno, void *arg);
- void *arg;
+ unsigned int (*handler)(int irqno, void *arg);
+ void *arg;
} int_handler;
static int_handler int_handlers[16];
void cchip1_irq_init(void){
- /* Configure AT697 ioport bit 7 to input pci irq */
+ /* Configure AT697 ioport bit 7 to input pci irq */
regs->PIO_Direction &= ~(1<<7);
regs->PIO_Interrupt = 0x87; /* level sensitive */
/* Set up irq controller (mask all IRQs) */
- cc1.pcib->imask = 0x0000;
- cc1.pcib->ipend = 0;
- cc1.pcib->iclear = 0xffff;
- cc1.pcib->iforce = 0;
- cc1.pcib->ilevel = 0x0;
+ cc1.pcib->imask = 0x0000;
+ cc1.pcib->ipend = 0;
+ cc1.pcib->iclear = 0xffff;
+ cc1.pcib->iforce = 0;
+ cc1.pcib->ilevel = 0x0;
- memset(int_handlers,0,sizeof(int_handlers));
+ memset(int_handlers,0,sizeof(int_handlers));
- /* Reset spurious counter */
- cchip1_spurious_cnt = 0;
+ /* Reset spurious counter */
+ cchip1_spurious_cnt = 0;
- /* Register interrupt handler */
- set_vector(cchip1_interrupt_dispatcher,LEON_TRAP_TYPE(CCHIP_IRQ),1);
+ /* Register interrupt handler */
+ set_vector(cchip1_interrupt_dispatcher,LEON_TRAP_TYPE(CCHIP_IRQ),1);
void cchip1_set_isr(void *handler, int irqno, void *arg){
- int_handlers[irqno].handler = handler;
- int_handlers[irqno].arg = arg;
+ int_handlers[irqno].handler = handler;
+ int_handlers[irqno].arg = arg;
#ifdef DEBUG
- printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
- irqno,(unsigned int)handler,irqno,(unsigned int)arg);
+ printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
+ irqno,(unsigned int)handler,irqno,(unsigned int)arg);
#endif
- cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
+ cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v){
- unsigned int pending = READ_REG(&cc1.pcib->ipend);
- unsigned int clr = pending;
- int irq=1;
+ unsigned int pending = READ_REG(&cc1.pcib->ipend);
+ unsigned int clr = pending;
+ int irq=1;
- if ( !pending ){
+ if ( !pending ){
#ifdef PRINT_SPURIOUS
- printk("Spurious IRQ %d: %d\n",v,cchip1_spurious_cnt);
+ printk("Spurious IRQ %d: %d\n",v,cchip1_spurious_cnt);
#endif
- cchip1_spurious_cnt++;
- return;
+ cchip1_spurious_cnt++;
+ return;
#ifdef DEBUG_IRQS
printk("CCIRQ: 0x%x\n",(unsigned int)pending);
#endif
- /* IRQ 0 doesn't exist */
- irq=1;
- pending = pending>>1;
- while ( pending ){
- if ( (pending & 1) && (handler=int_handlers[irq].handler) ){
- handler(irq,int_handlers[irq].arg);
- irq++;
+ /* IRQ 0 doesn't exist */
+ irq=1;
+ pending = pending>>1;
+ while ( pending ){
+ if ( (pending & 1) && (handler=int_handlers[irq].handler) ){
+ handler(irq,int_handlers[irq].arg);
+ irq++;
- cc1.pcib->iclear = clr;
+ cc1.pcib->iclear = clr;
- /*LEON_Clear_interrupt( brd->irq );*/
+ /*LEON_Clear_interrupt( brd->irq );*/
diff --git a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
index 70e8e81..ab4efa0 100644
--- a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
@@ -47,7 +47,7 @@ extern int CLOCK_SPEED;
#define Clock_driver_support_initialize_hardware() \
do { \
LEON_REG.Timer_Reload_1 = \
- rtems_configuration_get_microseconds_per_tick() - 1; \
+ rtems_configuration_get_microseconds_per_tick() - 1; \
LEON_REG.Timer_Control_1 = ( \
LEON_REG_TIMER_COUNTER_ENABLE_COUNTING | \
diff --git a/c/src/lib/libbsp/sparc/leon2/console/console.c b/c/src/lib/libbsp/sparc/leon2/console/console.c
index 0a4059e..cac21a6 100644
--- a/c/src/lib/libbsp/sparc/leon2/console/console.c
+++ b/c/src/lib/libbsp/sparc/leon2/console/console.c
@@ -322,7 +322,7 @@ rtems_device_driver console_initialize(
LEON_REG.UART_Control_1 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
LEON_REG.UART_Control_2 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE |
- LEON_REG_UART_CTRL_RI; /* rx irq default enable for remote debugger */
+ LEON_REG_UART_CTRL_RI; /* rx irq default enable for remote debugger */
LEON_REG.UART_Status_1 = 0;
LEON_REG.UART_Status_2 = 0;
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 8e40903..0bb0eef 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -69,7 +69,7 @@ extern int rtems_leon_open_eth_driver_attach(
extern int rtems_smc91111_driver_attach_leon2(
-#define RTEMS_BSP_NETWORK_DRIVER_NAME "open_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_NAME "open_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH \
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 \
diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
index d498aaf..25826bd 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
@@ -102,49 +102,49 @@ extern "C" {
typedef struct {
- volatile unsigned int Memory_Config_1;
- volatile unsigned int Memory_Config_2;
- volatile unsigned int Edac_Control;
- volatile unsigned int Failed_Address;
- volatile unsigned int Memory_Status;
- volatile unsigned int Cache_Control;
- volatile unsigned int Power_Down;
- volatile unsigned int Write_Protection_1;
- volatile unsigned int Write_Protection_2;
- volatile unsigned int Leon_Configuration;
- volatile unsigned int dummy2;
- volatile unsigned int dummy3;
- volatile unsigned int dummy4;
- volatile unsigned int dummy5;
- volatile unsigned int dummy6;
- volatile unsigned int dummy7;
- volatile unsigned int Timer_Counter_1;
- volatile unsigned int Timer_Reload_1;
- volatile unsigned int Timer_Control_1;
- volatile unsigned int Watchdog;
- volatile unsigned int Timer_Counter_2;
- volatile unsigned int Timer_Reload_2;
- volatile unsigned int Timer_Control_2;
- volatile unsigned int dummy8;
- volatile unsigned int Scaler_Counter;
- volatile unsigned int Scaler_Reload;
- volatile unsigned int dummy9;
- volatile unsigned int dummy10;
- volatile unsigned int UART_Channel_1;
- volatile unsigned int UART_Status_1;
- volatile unsigned int UART_Control_1;
- volatile unsigned int UART_Scaler_1;
- volatile unsigned int UART_Channel_2;
- volatile unsigned int UART_Status_2;
- volatile unsigned int UART_Control_2;
- volatile unsigned int UART_Scaler_2;
- volatile unsigned int Interrupt_Mask;
- volatile unsigned int Interrupt_Pending;
- volatile unsigned int Interrupt_Force;
- volatile unsigned int Interrupt_Clear;
- volatile unsigned int PIO_Data;
- volatile unsigned int PIO_Direction;
- volatile unsigned int PIO_Interrupt;
+ volatile unsigned int Memory_Config_1;
+ volatile unsigned int Memory_Config_2;
+ volatile unsigned int Edac_Control;
+ volatile unsigned int Failed_Address;
+ volatile unsigned int Memory_Status;
+ volatile unsigned int Cache_Control;
+ volatile unsigned int Power_Down;
+ volatile unsigned int Write_Protection_1;
+ volatile unsigned int Write_Protection_2;
+ volatile unsigned int Leon_Configuration;
+ volatile unsigned int dummy2;
+ volatile unsigned int dummy3;
+ volatile unsigned int dummy4;
+ volatile unsigned int dummy5;
+ volatile unsigned int dummy6;
+ volatile unsigned int dummy7;
+ volatile unsigned int Timer_Counter_1;
+ volatile unsigned int Timer_Reload_1;
+ volatile unsigned int Timer_Control_1;
+ volatile unsigned int Watchdog;
+ volatile unsigned int Timer_Counter_2;
+ volatile unsigned int Timer_Reload_2;
+ volatile unsigned int Timer_Control_2;
+ volatile unsigned int dummy8;
+ volatile unsigned int Scaler_Counter;
+ volatile unsigned int Scaler_Reload;
+ volatile unsigned int dummy9;
+ volatile unsigned int dummy10;
+ volatile unsigned int UART_Channel_1;
+ volatile unsigned int UART_Status_1;
+ volatile unsigned int UART_Control_1;
+ volatile unsigned int UART_Scaler_1;
+ volatile unsigned int UART_Channel_2;
+ volatile unsigned int UART_Status_2;
+ volatile unsigned int UART_Control_2;
+ volatile unsigned int UART_Scaler_2;
+ volatile unsigned int Interrupt_Mask;
+ volatile unsigned int Interrupt_Pending;
+ volatile unsigned int Interrupt_Force;
+ volatile unsigned int Interrupt_Clear;
+ volatile unsigned int PIO_Data;
+ volatile unsigned int PIO_Direction;
+ volatile unsigned int PIO_Interrupt;
} LEON_Register_Map;
#endif
@@ -396,9 +396,9 @@ static __inline__ int bsp_irq_fixup(int irq)
/* Load 32-bit word by forcing a cache-miss */
static inline unsigned int leon_r32_no_cache(uintptr_t addr)
- unsigned int tmp;
- __asm__ volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr));
- return tmp;
+ unsigned int tmp;
+ __asm__ volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr));
+ return tmp;
#endif /* !ASM */
diff --git a/c/src/lib/libbsp/sparc/leon2/include/rasta.h b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
index c0c339c..b7eccb4 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/rasta.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
@@ -100,18 +100,18 @@ struct uart_reg {
void uart_register(unsigned int baseaddr);
-rtems_device_driver uart_initialize(rtems_device_major_number major,
- rtems_device_minor_number minor, void *arg);
+rtems_device_driver uart_initialize(rtems_device_major_number major,
+ rtems_device_minor_number minor, void *arg);
rtems_device_driver uart_open(rtems_device_major_number major,
rtems_device_driver uart_close(rtems_device_major_number major,
rtems_device_driver uart_read(rtems_device_major_number major,
rtems_device_driver uart_write(rtems_device_major_number major,
rtems_device_driver uart_control(rtems_device_major_number major,
struct gpio_reg {
diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
index e4faaff..424f4ca 100644
--- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
+++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
@@ -345,7 +345,7 @@ int rasta_register(void)
/*brm_register(bar0 + BRM_OFFSET, bar1);*/
/* register the BRM RASTA driver, use 128k on RASTA SRAM... */
b1553brm_rasta_int_reg=rasta_interrrupt_register;
- if ( b1553brm_rasta_register(&abus,2,0,3,bar1,0x40000000) ){
+ if ( b1553brm_rasta_register(&abus,2,0,3,bar1,0x40000000) ){
printk("Failed to register BRM RASTA driver\n");
return -1;
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
index 5f7cf27..7a26985 100644
--- a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
@@ -148,8 +148,8 @@ void bsp_spurious_initialize()
continue;
set_vector(
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 6bbd6ed..1be6cc2 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -79,13 +79,13 @@ extern int rtems_leon_greth_driver_attach(
int attach
-#define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH "open_eth1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH \
+#define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH "open_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH \
-#define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111 "smc_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111 "smc_eth1"
rtems_smc91111_driver_attach_leon3
-#define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH "gr_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH "gr_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH \
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index f1b987b..7e8188d 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -287,9 +287,9 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
- unsigned int tmp;
- return tmp;
+ unsigned int tmp;
+ return tmp;
/* Let user override which on-chip APBUART will be debug UART
diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
index e8bdd52..17218be 100644
--- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
@@ -36,7 +36,7 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
int
rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
- int attach)
+ int attach)
unsigned long addr_mctrl = 0;
struct grgpio_regs *io;
@@ -70,10 +70,8 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
addr_mctrl = (unsigned long) apbmctrl.start;
io = (struct grgpio_regs *) apbpio.start;
- printk(
- "Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
- (unsigned int)io,
- (unsigned int)addr_mctrl);
+ printk("Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
+ (unsigned int)io, (unsigned int)addr_mctrl);
/* Setup PIO IRQ */
io->imask |= (1 << leon_scmv91111_configuration.pio);
@@ -83,7 +81,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
/* Setup memory controller I/O waitstates */
*((volatile unsigned int *) addr_mctrl) |=
- 0x10f80000; /* enable I/O area access */
+ 0x10f80000; /* enable I/O area access */
return _rtems_smc91111_driver_attach(config, &leon_scmv91111_configuration);
diff --git a/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c b/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
index 80bf716..5b118f2 100644
--- a/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
+++ b/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
@@ -44,9 +44,9 @@ extern unsigned int LEON3_Atomic_Swap(uint32_t value, uint32_t *address);
__asm__ (
".text\n"
".align 4\n"
-"LEON3_Atomic_Swap:\n"
-" retl\n"
-" swapa [%o1] 1, %o0\n"
+ "LEON3_Atomic_Swap:\n"
+ " retl\n"
+ " swapa [%o1] 1, %o0\n"
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
index 210dee0..9d13010 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
@@ -152,8 +152,8 @@ void bsp_spurious_initialize()
continue;
set_vector(
1.7.9.5
