Proposed Affinity Changes
Thu May 15 11:30:46 UTC 2014
Hello Joel,
On 2014-05-15 01:55, Joel Sherrill wrote:
> Hi
> Although I think there are only a few code paths to
> address for affinity added to the Priority SMP Scheduler,
the Deterministic Priority SMP Scheduler has already support for thread
processor affinity.  It is _Scheduler_default_Set_affinity().  A thread is
allowed to execute on any processor of a scheduler instance.
Please add support for arbitrary processor affinity sets to the Deterministic
Priority Affinity SMP Scheduler (schedulerpriorityaffinitysmp.c).
> the modifications appear to be very subtle and I want
> to get feedback given the potential impact on other
> schedulers.
> + set_affinity
> + _Scheduler_SMP_Enqueue_ordered()
> + _Scheduler_SMP_Extract()
> + _Scheduler_SMP_Schedule()
> == set_affinity
> set_affinity scheduler support is being discussed in Sebastian's
> change priority patch thread. But basically use the pattern
> he proposed for _Scheduler_Change_priority() but for affinity.
Yes, it should be local to the set affinity operation
(_Scheduler_priority_affinity_SMP_Set_affinity()).
> == _Scheduler_SMP_Extract()
> _Scheduler_SMP_Extract() doesn't appear to need anything
> done.
I deleted this operation.
> ==_Scheduler_SMP_Enqueue_ordered()
> For the enqueue ordered path, this is what I think needs to be
> done. The changes appear to be minor but the interweaving of
> indirect calls and rapid changes means I need some feedback.
> When a node is in the air and we look for highest ready  in
> _Scheduler_SMP_Enqueue_ordered, the highest ready should
> have an affinity for this core.  It is does, then it gets returned
> by (*get_highest_ready)(). If not, we can return NULL is
> returned since we couldn't impact the thread allocated to this
> node.
>     How do you think this filter should be inserted into the framework
>     of indirect calls leading here?
I am not sure if you can use the existing _Scheduler_SMP_Enqueue_ordered().  My
feeling is that you need something completely new.  The current SMP scheduler
uses a simple chain to manage the scheduled threads.
Which algorithm do you use to calculate the subset of ready threads allowed to
execute taking all the affinity sets into account?  I think you have to solve a
matching problem in a bipartite graph:
http://www.rtems.org/wiki/index.php?title=SMP#Theory
You probably have to take all threads in the ready state into account to
determine the new scheduled threads.  You can then use something like this to
allocate an exact processor for them:
static inline void _Scheduler_SMP_Allocate_processor_exact(
   Scheduler_SMP_Context *self,
   Thread_Control *scheduled,
   Thread_Control *victim
   Scheduler_SMP_Node *scheduled_node = _Scheduler_SMP_Node_get( scheduled );
   Per_CPU_Control *cpu_of_scheduled = _Thread_Get_CPU( scheduled );
   Per_CPU_Control *cpu_of_victim = _Thread_Get_CPU( victim );
   Per_CPU_Control *cpu_self = _Per_CPU_Get();
   _Scheduler_SMP_Node_change_state(
     scheduled_node,
     SCHEDULER_SMP_NODE_SCHEDULED
   _Thread_Set_CPU( scheduled, cpu_of_victim );
   _Scheduler_SMP_Update_heir( cpu_self, cpu_of_victim, scheduled );
You can even use this function to do things like this:
_Scheduler_SMP_Allocate_processor_exact(self, executing, other);
_Scheduler_SMP_Allocate_processor_exact(self, other, executing);
> Similarly, if a node is not in the air, we look for lowest scheduled.
> I am thinking that the hard-coded call to
> _Scheduler_SMP_Get_lowest_scheduled() needs to be an indirect
> call so an affinity aware version which scans scheduled to
> find lowest with affinity for this node.
> And is it safe to assume that node == current processor ID?
> So there don't need to be arguments added to the calls?
> Just check affinity against current processor number.
> ==_Scheduler_SMP_Schedule()
> This is only called as a side-effect of _Thread_Change_priority().
> Sebastian.. is this entry point needed after your changes?
The SMP scheduler use now _Scheduler_default_Schedule() which does nothing.
> If needed, then...
> _Scheduler_SMP_Schedule_highest_ready() already is passed
> get_highest_ready().  If we go with what was discussed for
> _Scheduler_SMP_Enqueue_ordered() and use the same
> get_highest_ready() implementation, then (*get_highest_ready)()
> will return a NULL if the highest priority thread does not have
> affinity for the core we are scheduling for.  Returning NULL
> from get_highest_priority appears to be a bad idea for this
> case.
> Plus we need a thread with affinity for the core/node that
> the priority was changed on so we can't assume that
> the processor ID is easily available.
> So there are two hard things I don't see an obvious answer to.
> I think this path has a decision.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
