Scheduler Priority Cleanup
Mon May 19 14:33:08 UTC 2014
On Mon, May 19, 2014 at 2:19 AM, Sebastian Huber
> On 2014-05-16 19:48, Joel Sherrill wrote:
>> Hi
>> In reviewing the _Thread_Change_priority and associated
>> changes in anticipation of using them as a pattern for the
>> set affinity code, I have spotted a few things:
>> + _Scheduler_Update() is only called from _Thread_Change_priority()
>> and _Thread_Set_priority().  It should be renamed to reflect priority.
>> This would change _Scheduler_Update() to _Scheduler_Update_priority()
>> as well as the associated Scheduler_Context element and implementations
>> since they should be renamed.
> Yes, this sounds good.
+1
>> + The change_priority, update(_priority), and priority_compare
>> entries in Scheduler_Context are not next to each other. They
>> are also not consistent in naming. They need to be at least
>> reordered.
>> Comments?
> The scheduler operations should be reordered to increase cache efficiency,
> e.g. operations used frequently or are critical should move to the begin of
> the structure to be next to the context pointer.
I agree. The operations table grew naturally as new functions were
added. Ordering based on some profiling about which operations get
called most often/together is good. I suspect change_priority and
update_priority are infrequent, but priority_compare may be common.
> rtems-devel mailing list
> rtems-devel at rtems.org
