[PATCH 2/2] bsps/sparc: Add XtratuM BSP.
Sebastian Huber
Wed May 21 08:01:11 UTC 2014
Hello Gedare,
thanks for your review.
On 2014-05-20 16:58, Gedare Bloom wrote:
>> @@ -54,7 +58,15 @@ SYM(_CPU_Context_switch):
>> > ld [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
>> > ! save it a bit later so we do not waste a couple of cycles
>> >+#ifdef RTEMS_PARAVIRT_XTRATUM
>> >+ mov %o0, %l6
>> >+ mov sparc_get_psr_nr, %o0
>> >+ __XM_AHC
> I'm guessing these symbols are defined in xm.h?
>> >+ mov %o0, %o2
>> >+ mov %l6, %o0
>> >+#else /* RTEMS_PARAVIRT_XTRATUM */
>> > rd %psr, %o2
>> >+#endif /* RTEMS_PARAVIRT_XTRATUM */
> It would be cleaner code if you can write this get_psr as an assembler
> macro, e.g.
> .macro GET_PSR REG, TMP0
> mov %o0, \TMP
> __XM_AHC
> mov %o0, \REG
> mov \TMP, %o0
> #else
> rd %psr, \REG
> #endif
> Same for some of the other functions that get used multiple times in
> this file, such as set_psr, set_pil, and clear_pil. Putting these in a
> header file would make them useful in start.S also.
I also think that assembler macros could be useful here.
Daniel, what is you opinion with respect to the usage of assembler macros in
this file?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
