[PATCH] score: Multiprocessor Resource Sharing Protocol
Gedare Bloom
gedare at rtems.org
Wed May 21 14:53:25 UTC 2014
On Wed, May 21, 2014 at 8:09 AM, Sebastian Huber
> Add basic support for the Multiprocessor Resource Sharing Protocol
> (MrsP).
> The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
> Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
> Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
> Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
> generalization of the Priority Ceiling Protocol to SMP systems. Each
> MrsP semaphore uses a ceiling priority per scheduler instance. These
> ceiling priorities can be specified with rtems_semaphore_set_priority().
> A task obtaining or owning a MrsP semaphore will execute with the
> ceiling priority for its scheduler instance as specified by the MrsP
> semaphore object. Tasks waiting to get ownership of a MrsP semaphore
> will not relinquish the processor voluntarily. In case the owner of a
> MrsP semaphore gets preempted it can ask all tasks waiting for this
> semaphore to help out and temporarily borrow the right to execute on one
> of their assigned processors.
> The help out feature is not implemented with this patch.
> cpukit/rtems/Makefile.am | 1 +
> cpukit/rtems/include/rtems/rtems/attr.h | 14 +
> cpukit/rtems/include/rtems/rtems/attrimpl.h | 31 ++
> cpukit/rtems/include/rtems/rtems/sem.h | 46 +++
> cpukit/rtems/include/rtems/rtems/semimpl.h | 9 +
> cpukit/rtems/src/semcreate.c | 38 ++-
> cpukit/rtems/src/semdelete.c | 21 +-
> cpukit/rtems/src/semflush.c | 7 +-
> cpukit/rtems/src/semobtain.c | 19 +-
> cpukit/rtems/src/semrelease.c | 14 +-
> cpukit/rtems/src/semsetpriority.c | 116 +++++++
> cpukit/sapi/include/confdefs.h | 14 +-
> cpukit/score/Makefile.am | 2 +
> cpukit/score/include/rtems/score/mrsp.h | 135 ++++++++
> cpukit/score/include/rtems/score/mrspimpl.h | 301 +++++++++++++++++
> cpukit/score/include/rtems/score/schedulerimpl.h | 10 +
> cpukit/score/preinstall.am | 8 +
> doc/user/Makefile.am | 2 +-
> doc/user/conf.t | 32 ++
> doc/user/sem.t | 198 +++++++++++-
> testsuites/smptests/Makefile.am | 1 +
> testsuites/smptests/configure.ac | 1 +
> testsuites/smptests/smpmrsp01/Makefile.am | 19 ++
> testsuites/smptests/smpmrsp01/init.c | 287 +++++++++++++++++
> testsuites/smptests/smpmrsp01/smpmrsp01.doc | 15 +
> testsuites/smptests/smpmrsp01/smpmrsp01.scn | 2 +
> testsuites/sptests/Makefile.am | 1 +
> testsuites/sptests/configure.ac | 1 +
> testsuites/sptests/spmrsp01/Makefile.am | 19 ++
> testsuites/sptests/spmrsp01/init.c | 374 ++++++++++++++++++++++
> testsuites/sptests/spmrsp01/spmrsp01.doc | 13 +
> testsuites/sptests/spmrsp01/spmrsp01.scn | 8 +
> 32 files changed, 1743 insertions(+), 16 deletions(-)
> create mode 100644 cpukit/rtems/src/semsetpriority.c
> create mode 100644 cpukit/score/include/rtems/score/mrsp.h
> create mode 100644 cpukit/score/include/rtems/score/mrspimpl.h
> create mode 100644 testsuites/smptests/smpmrsp01/Makefile.am
> create mode 100644 testsuites/smptests/smpmrsp01/init.c
> create mode 100644 testsuites/smptests/smpmrsp01/smpmrsp01.doc
> create mode 100644 testsuites/smptests/smpmrsp01/smpmrsp01.scn
> create mode 100644 testsuites/sptests/spmrsp01/Makefile.am
> create mode 100644 testsuites/sptests/spmrsp01/init.c
> create mode 100644 testsuites/sptests/spmrsp01/spmrsp01.doc
> create mode 100644 testsuites/sptests/spmrsp01/spmrsp01.scn
> diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
> index f73c929..e818d68 100644
> --- a/cpukit/rtems/src/semflush.c
> +++ b/cpukit/rtems/src/semflush.c
> @@ -43,12 +43,17 @@ rtems_status_code rtems_semaphore_flush(
> Semaphore_Control *the_semaphore;
> Objects_Locations location;
> + rtems_attribute attribute_set;
> the_semaphore = _Semaphore_Get( id, &location );
> switch ( location ) {
> case OBJECTS_LOCAL:
> - if ( !_Attributes_Is_counting_semaphore(the_semaphore->attribute_set) ) {
> + attribute_set = the_semaphore->attribute_set;
> + if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
> + _Objects_Put( &the_semaphore->Object );
> + return RTEMS_NOT_DEFINED;
> + } else if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
> _CORE_mutex_Flush(
> &the_semaphore->Core_control.mutex,
> SEND_OBJECT_WAS_DELETED,
Need #if defined(RTEMS_SMP)...#endif here.
> diff --git a/cpukit/rtems/src/semsetpriority.c b/cpukit/rtems/src/semsetpriority.c
> new file mode 100644
> index 0000000..bb3a688
> --- /dev/null
> +++ b/cpukit/rtems/src/semsetpriority.c
> @@ -0,0 +1,116 @@
> + * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#if HAVE_CONFIG_H
> + #include "config.h"
> +#endif
> +#include <rtems/rtems/semimpl.h>
> +#include <rtems/rtems/attrimpl.h>
> +#include <rtems/rtems/tasksimpl.h>
> +#include <rtems/score/schedulerimpl.h>
> +static rtems_status_code _Semaphore_Set_priorities(
Minor nit, should this be named _Semaphore_Set_priority()?
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index 1c97d15..f3e5127 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -1792,6 +1792,17 @@ const rtems_libio_helper rtems_fs_init_helper =
> CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
> CONFIGURE_NETWORKING_SEMAPHORES)
> + #if !defined(RTEMS_SMP) || \
> + !defined(CONFIGURE_MAXIMUM_MULTIPROCESSOR_RESOURCE_SHARING_SEMAPHORES)
Can this be CONFIGURE_MAXIMUM_MRSP_SEMAPHORES?
> diff --git a/cpukit/score/include/rtems/score/mrsp.h b/cpukit/score/include/rtems/score/mrsp.h
> index 0000000..4a790d4
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/mrsp.h
> @@ -0,0 +1,135 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef _RTEMS_SCORE_MRSP_H
> +#define _RTEMS_SCORE_MRSP_H
> +#include <rtems/score/cpuopts.h>
> +#if defined(RTEMS_SMP)
> +#include <rtems/score/atomic.h>
> +#include <rtems/score/chain.h>
> +#include <rtems/score/scheduler.h>
> +#include <rtems/score/thread.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @defgroup ScoreMRSP Multiprocessor Resource Sharing Protocol Handler
> + * @ingroup Score
> + * @brief Multiprocessor Resource Sharing Protocol (MrsP).
> + * The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A. Burns
> + * and A.J. Wellings, A Schedulability Compatible Multiprocessor Resource
> + * Sharing Protocol - MrsP, Proceedings of the 25th Euromicro Conference on
> + * Real-Time Systems (ECRTS 2013), July 2013. It is a generalization of the
> + * Priority Ceiling Protocol to SMP systems. Each MrsP semaphore uses a
> + * ceiling priority per scheduler instance. A task obtaining or owning a MrsP
> + * semaphore will execute with the ceiling priority for its scheduler instance
> + * as specified by the MrsP semaphore object. Tasks waiting to get ownership
> + * of a MrsP semaphore will not relinquish the processor voluntarily. In case
> + * the owner of a MrsP semaphore gets preempted it can ask all tasks waiting
> + * for this semaphore to help out and temporarily borrow the right to execute
> + * on one of their assigned processors.
> + * @brief MRSP status code.
> + * The values are chosen to directly map to RTEMS status codes. In case this
> + * implementation is used for other APIs, then for example the errno values can
> + * be added with a bit shift.
> +typedef enum {
> + MRSP_SUCCESSFUL = 0,
> + MRSP_TIMEOUT = 6,
> + MRSP_RESOUCE_IN_USE = 12,
> + MRSP_UNSATISFIED = 13,
> + MRSP_INVALID_PRIORITY = 19,
> + MRSP_NOT_OWNER_OF_RESOURCE = 23,
> + MRSP_NO_MEMORY = 26
> +} MRSP_Status;
> + * @brief MRSP rival.
> + * The rivals are used by threads waiting for resource ownership. They are
> + * registered in the MRSP control block.
> +typedef struct {
> + * @brief The node for registration in the MRSP rival chain.
> + Chain_Node Node;
> + * @brief Identification of the rival thread.
> + Thread_Control *thread;
> + * @brief The rival state.
> + * Initially no state bits are set. The rival will busy wait until a state
> + * change happens. This an be MRSP_RIVAL_STATE_NEW_OWNER or
"This an be" -> "This can be"
> diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
> index 0000000..7adb88f
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/mrspimpl.h
> @@ -0,0 +1,301 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef _RTEMS_SCORE_MRSPIMPL_H
> +#define _RTEMS_SCORE_MRSPIMPL_H
> +#include <rtems/score/mrsp.h>
> +#include <rtems/score/assert.h>
> +#include <rtems/score/chainimpl.h>
> +#include <rtems/score/watchdogimpl.h>
> +#include <rtems/score/wkspace.h>
> +#ifdef __cplusplus
> +extern "C" {
> + * @addtogroup ScoreMRSP
> +#define MRSP_RIVAL_STATE_NEW_OWNER 0x1U
> +#define MRSP_RIVAL_STATE_TIMEOUT 0x2U
Does it make sense to have MRSP_RIVAL_STATE_WAITING 0x0? Also, the
functions in this file could use some doxygen.
> diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
> index ef91a41..e774319 100644
> --- a/doc/user/Makefile.am
> +++ b/doc/user/Makefile.am
> @@ -96,7 +96,7 @@ sem.texi: sem.t
> -n "Barrier Manager" < $< > $@
> barrier.texi: barrier.t
> - $(BMENU2) -p "Semaphore Manager SEMAPHORE_FLUSH - Unblock all tasks waiting on a semaphore" \
> + $(BMENU2) -p "Semaphore Manager SEMAPHORE_SET_PRIORITY - Set priority by scheduler for a semaphore" \
This should probably say "Set ceiling priority by scheduler"
-Gedare
