Initially Locked Priority Ceiling Semaphores
Sebastian Huber
Wed May 21 15:08:52 UTC 2014
On 2014-05-21 17:01, Gedare Bloom wrote:
>> if ( initially_locked ) {
>> > the_mutex->nest_count = 1;
>> > the_mutex->holder = executing;
>> > if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
>> > _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
>> > if ( executing->current_priority <
>> > the_mutex->Attributes.priority_ceiling )
>> > return CORE_MUTEX_STATUS_CEILING_VIOLATED;
> Looks like this check ensures the executing thread has got priority at
> least at the priority_ceiling. If it does not, the mutex is not
> initialized.
Yes, this is the error case. In the good case the priority is not changed to
the ceiling priority like for a normal rtems_semaphore_obtain() (see
_CORE_mutex_Seize_interrupt_trylock_body()).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
