[PATCH 2/2] bsps/sparc: Add XtratuM BSP.
Christian Mauderer
Christian.Mauderer at embedded-brains.de
Thu May 22 12:19:35 UTC 2014
Am 21.05.2014 15:54, schrieb Gedare Bloom:
> On Wed, May 21, 2014 at 4:04 AM, Christian Mauderer
> <Christian.Mauderer at embedded-brains.de> wrote:
>> First of all: Thanks for your comments. You will find answers below.
>> Am 20.05.2014 16:58, schrieb Gedare Bloom:
>>> On Tue, May 20, 2014 at 5:16 AM, Christian Mauderer
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>>>> c/src/lib/libbsp/shared/include/fatal.h | 6 +-
>>>> c/src/lib/libbsp/sparc/acinclude.m4 | 2 +
>>>> c/src/lib/libbsp/sparc/shared/irq_asm.S | 97 ++++++++++++++++
>>>> c/src/lib/libbsp/sparc/shared/start/start.S | 58 +++++++++-
>>>> .../lib/libbsp/sparc/shared/startup/linkcmds.base | 19 ++++
>>>> c/src/lib/libbsp/sparc/xtratum/Makefile.am | 119 ++++++++++++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/README | 8 ++
>>>> c/src/lib/libbsp/sparc/xtratum/bsp_specs | 17 +++
>>>> .../sparc/xtratum/clock/clock-xtratum-exec.c | 23 ++++
>>>> .../libbsp/sparc/xtratum/clock/clock-xtratum-hw.c | 21 ++++
>>>> .../lib/libbsp/sparc/xtratum/clock/clock-xtratum.h | 103 +++++++++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/configure.ac | 33 ++++++
>>>> .../libbsp/sparc/xtratum/console/console-config.c | 27 +++++
>>>> .../libbsp/sparc/xtratum/console/printk-support.c | 28 +++++
>>>> .../sparc/xtratum/console/xtratum-hyper-console.c | 71 ++++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/include/bsp.h | 52 +++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/include/cache_.h | 113 +++++++++++++++++++
>>>> .../sparc/xtratum/include/clock-xtratum-exec.h | 26 +++++
>>>> c/src/lib/libbsp/sparc/xtratum/include/irq.h | 2 +
>>>> c/src/lib/libbsp/sparc/xtratum/include/tm27.h | 30 +++++
>>>> .../sparc/xtratum/include/xtratum-hyper-console.h | 30 +++++
>>>> c/src/lib/libbsp/sparc/xtratum/include/xtratum.h | 87 +++++++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/irq/irq.c | 77 +++++++++++++
>>>> .../libbsp/sparc/xtratum/make/custom/xtratum.cfg | 55 +++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/preinstall.am | 123 +++++++++++++++++++++
>>>> .../libbsp/sparc/xtratum/startup/bsppredriver.c | 7 ++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c | 52 +++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c | 104 +++++++++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c | 22 ++++
>>>> .../libbsp/sparc/xtratum/startup/example_xm_cf.xml | 66 +++++++++++
>>>> .../lib/libbsp/sparc/xtratum/startup/isr-en-dis.S | 50 +++++++++
>>>> .../libbsp/sparc/xtratum/startup/linkcmds.xtratum | 20 ++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/psr.c | 26 +++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/setvec.c | 61 ++++++++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/spurious.c | 35 ++++++
>>>> c/src/lib/libbsp/sparc/xtratum/startup/tbr.c | 30 +++++
>>>> c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c | 36 ++++++
>>>> cpukit/score/cpu/sparc/rtems/score/cpu.h | 11 +-
>>>> testsuites/smptests/smpfatal08/init.c | 3 +-
>>>> 39 files changed, 1735 insertions(+), 15 deletions(-)
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/Makefile.am
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/README
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/bsp_specs
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/configure.ac
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/console-config.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/bsp.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/cache_.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/clock-xtratum-exec.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/irq.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/tm27.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/irq/irq.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/preinstall.am
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/psr.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
>>>> create mode 100644 c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
>>>> diff --git a/c/src/lib/libbsp/shared/include/fatal.h b/c/src/lib/libbsp/shared/include/fatal.h
>>>> index e928bba..8ca90bb 100644
>>>> --- a/c/src/lib/libbsp/shared/include/fatal.h
>>>> +++ b/c/src/lib/libbsp/shared/include/fatal.h
>>>> @@ -101,7 +101,11 @@ typedef enum {
>>>> PPC_FATAL_EXCEPTION_INITIALIZATION = BSP_FATAL_CODE_BLOCK(7),
>>>> /* Libchip fatal codes */
>>>> - DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8)
>>>> + DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8),
>>>> + /* XtratuM fatal codes */
>>>> + XTRATUM_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(9),
>>>> + XTRATUM_FATAL_CPU_SMP_INITIALIZE
>>>> } bsp_fatal_code;
>>>> RTEMS_COMPILER_NO_RETURN_ATTRIBUTE static inline void
>>>> diff --git a/c/src/lib/libbsp/sparc/acinclude.m4 b/c/src/lib/libbsp/sparc/acinclude.m4
>>>> index 4d40305..0e053fa 100644
>>>> --- a/c/src/lib/libbsp/sparc/acinclude.m4
>>>> +++ b/c/src/lib/libbsp/sparc/acinclude.m4
>>>> @@ -8,6 +8,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>> AC_CONFIG_SUBDIRS([leon2]);;
>>>> leon3 )
>>>> AC_CONFIG_SUBDIRS([leon3]);;
>>>> + xtratum )
>>>> + AC_CONFIG_SUBDIRS([xtratum]);;
>>>> AC_MSG_ERROR([Invalid BSP]);;
>>>> esac
>>>> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>>>> index bf2dca9..69522a2 100644
>>>> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
>>>> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>>>> @@ -23,6 +23,10 @@
>>>> #include <rtems/score/percpu.h>
>>>> #include <bspopts.h>
>>>> +#ifdef RTEMS_PARAVIRT_XTRATUM
>>>> +#include <xm.h>
>>> What is this header file? I don't see it in the commit, is it part of
>>> the installed XtratuM?
>> That is correct. It's part of XtratuM. Is there some preferred way of
>> marking such headers?
> Not that I know of. We have discussed a similar issue with the POK
> paravirtualization project. The problem is to allow external code
> linking to RTEMS. The design should be considered carefully and
> probably discussed in a separate thread.
>>>> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>>>> new file mode 100644
>>>> index 0000000..2d4428a
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>>>> @@ -0,0 +1,35 @@
>>>> + * LEON Spurious Trap Handler
>>>> + * This is just enough of a trap handler to let us know what
>>>> + * the likely source of the trap was.
>>>> + * Developed as part of the port of RTEMS to the LEON implementation
>>>> + * of the SPARC by On-Line Applications Research Corporation (OAR)
>>>> + * under contract to the European Space Agency (ESA).
>>>> + * COPYRIGHT (c) 1995. European Space Agency.
>>>> + * Modified for LEON3 BSP.
>>>> + * COPYRIGHT (c) 2004.
>>>> + * Gaisler Research.
>>>> + * This terms of the RTEMS license apply to this file.
>>>> +#include <bsp.h>
>>>> +#include <rtems/bspIo.h>
>>>> +void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
>>>> + uint32_t trap;
>>>> + uint32_t real_trap;
>>>> + const CPU_Interrupt_frame *isf;
>>>> + trap = frame->trap;
>>>> + real_trap = SPARC_REAL_TRAP_NUMBER(trap);
>>>> + isf = frame->isf;
>>>> + printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
>>> I don't think this code will get called ever?
>> The _BSP_Exception_frame_print of the sparc gets called by the
>> _CPU_Exception_frame_print. This again is called by
>> rtems_exception_frame_print which is called i.E. in the
>> bsp_fatal_extension or in spfatal26-test.
> OK. It should get a more suitable file name e.g.
> bspexceptionframeprint.c. I realize the other sparc BSPs implemented
> it in spurious.c, but this BSP does not have a spurious exception
> handler, so it doesn't make a lot of sense to have spurious.c.
Noted. I'll change it as soon as the licensing issue is solved.
> Gedare
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
