[GSOC] rtems GPIO API
Alan Cudmore alan.cudmore at gmail.com
Fri May 23 00:08:06 UTC 2014
Hi Andre,
Please see my comments below:
Alan
On 5/22/2014 6:30 PM, Andre Marques wrote:
> Hello,
> I will start my GSOC project with a GPIO driver for the RPi BSP, and
> part of the GPIO driver code will not be specific to the RPi but to
> any board with a GPIO interface. With code reuse in mind and since I
> did not found any "generic" API for the GPIO interface in the RTEMS
> code base, I intend to propose here an initial *rough* draft of what
> this API may look like.
Do you think a gpio API has advantages over Pierre's driver/ioctl based
driver?
https://github.com/pficheux/raspberry_pi/blob/master/RTEMS/gpio_driver
Feedback from others would be welcome. Pierre offered this as a generic
GPIO driver interface for RTEMS earlier, but did not get much feedback.
> To initialize the API:
> rtems_gpio_initialize (struct gpio_config)
> which would initialize the API with a specific GPIO peripheral
> configuration: number of gpio pins, gpio register addresses, ...
> To set a gpio pin as input or output (the direction would be a macro):
> rtems_gpio_direction (int gpio, int direction)
Does the gpio serve as the GPIO pin number in this API?
> To set a gpio pull resistor (either pull up/down or no pull resistor):
> rtems_gpio_set_Pull (int gpio, int pull)
Maybe use lower case 'p' for this api to be consistent.
> Some GPIO I/O:
> rtems_gpio_set(int gpio)
> rtems_gpio_clr (int gpio)
> rtems_gpio_read_value (int gpio)
Use  rtems_gpio_get instead of read_value?
> And interrupt management:
> rtems_int_enable (int gpio, rtems_interrupt_level int)
> rtems_int_disable (int gpio)
> rtems_int_clear (int gpio)
Do you mean to have rtems_gpio_int_xxx  ?
> Would appreciate some feedback on this.
> --Andre Marques.
> rtems-devel mailing list
> rtems-devel at rtems.org
