[PATCH] SMP: make IPI fatal code unique
Sebastian Huber
Fri May 23 13:53:08 UTC 2014
On 2014-05-23 14:27, Daniel Hellstrom wrote:
> The same smp fatal code is used in percpu
> _Per_CPU_State_change(). In order to determine which CPU
> requested a fatal shutdown and which CPU responds to it a
> unique code should be used.
> A unique code makes it also possible to handle the CPUs
> differently in the fatal exception handler.
Thanks, patch checked in.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
