Including paravirtualization headers in RTEMS
Cláudio Silva claudiodcsilva at gmail.com
Sun May 25 18:39:50 UTC 2014
Sorry all, miss send. Returning to where I was:
Yes, Partitions are fully linked executables created "off-line". No
linking occurs in run-time. The partition elf is simply loaded in to
memory by a partition loader or by the bootloader.
Typically, you have a thin abstraction layer defining simple functions
that will trap into the partitioning kernel. Something like:
https://github.com/t-crest/ospat/blob/master/libpok/middleware/portqueueingsend.c
In POK + RTEMS case, this library is being compiled by POK's compiler
and then linked to each partitions' executable. When this partition is
an RTEMS one, the remaining binaries (RTEMS+Application) were compiled
with the RTEMS' compiler. Therefore you are linking two sets of
binaries produced by different compilers.
I guess this is also true for the recently submitted Xtratum BSP.
We have several options available:
- Let the two binaries (RTEMS + abstraction lib), compiled with
different compilers, to be linked together (how it is currently
happening)
- Compile the partitioning kernel abstraction layer with the RTEMS
compiler - this will result in a complex configuration and build
procedure.
- Implement the functionality of the abstraction layer completely
inside RTEMS as part of the libbsp/libcpu - This can be a good
solution for the CPU/TImer/Interrupt part of the abstraction layer.
However, for other elements like the queueing and sampling port APIs
that have no match inside RTEMS...
Best Regards,
Cláudio
On Sun, May 25, 2014 at 7:22 PM, Cláudio Silva <claudiodcsilva at gmail.com> wrote:
> Hello Chris,
> memory by a partition loader or the bootloader.
> On Sat, May 24, 2014 at 12:27 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 23/05/2014 6:46 pm, Philipp Eppelt wrote:
>>>> On 05/21/2014 03:54 PM, Gedare Bloom wrote:> On Wed, May 21, 2014 at 4:04
>>>> AM, Christian Mauderer
>>>>> <Christian.Mauderer at embedded-brains.de> wrote:
>>>>>> First of all: Thanks for your comments. You will find answers below.
>>>>>> Am 20.05.2014 16:58, schrieb Gedare Bloom:
>>>>>> That is correct. It's part of XtratuM. Is there some preferred way of
>>>>>> marking such headers?
>>>>> Not that I know of. We have discussed a similar issue with the POK
>>>>> paravirtualization project. The problem is to allow external code
>>>>> linking to RTEMS. The design should be considered carefully and
>>>>> probably discussed in a separate thread.
>>> To pick up this discussion, I like first to picture the problem, second
>>> to collect possible solutions and third name some known problems with
>>> the solutions.
>> Thank you for posting this email. I followed the links and looked at the
>> code and realised I need to ask more questions.
>>> In a paravirtualized environment we need to make function calls from our
>>> guest system to the host system. The implementation of these functions
>>> rely sole on the host system.
>> Are they function calls ? To me a function call assumes some sort of linking
>> process between the guest and the host system either static or via some form
>> of runtime binding, ie a link editor. I also assume a guest is an RTEMS
>> partition executable and the host is the POK microkernel providing the
>> partitioned environment in some sort of protective environment.
>>> Hence, at compile time the guest system is missing the implementation of
>>> this host specific functions.
>> My understanding is partitions are loaded into an ELF image that POK loads
>> and executes. Is there some sort of linking happening when the partition is
>> written into the ELF image or when it is being loaded ?
>> For me this is the really important because I am wanting to first understand
>> the which pieces of code are compiled into object files and by which
>> compilers and then archived into static libraries and then linked to any
>> RTEMS code compiled with an RTEMS compiler. I do not understand if there are
>> function calls into the POK kernel or syscall type calls which I consider an
>> ABI, ie a trap or VM exception.
>> If I can understand these needs I will be in a better position to help with
>> the remaining topics in this email.
>> Chris
>>> To provide the guest system with the function implementation there are a
>>> couple of possible solutions.
>>> (A) Provide a host library
>>> The host compiles a library containing the function implementations
>>> including all dependencies. This host library is passed to the guest
>>> system, to resolve the `undefined reference` errors during link time.
>>> In the case of POK+RTEMS the resulting RTEMS binary is a valid POK
>>> partition and can run without further modifications.
>>> The recently propose XantruM BSP seems to follow a similar approach.
>>> (B) Use function stubs and build a jump table in the host
>>> The guest system makes use of function stubs, written into a special
>>> section in the binary to build. This section is analysed by the host
>>> system to intercept function calls  and replace them with the host
>>> implementation of the calls.
>>> This approach is used in L4Linux and I gave it a shot in L4RTEMS.
>>> [1] shows the macro for the function stubs, [2] the hosts resolver part.
>>> (C) add your solution
>>> Problems with the solutions
>>> P(A) Dependencies and foreign code
>>> The library is host code, which has to be maintained, which can get out
>>> of sync between BSP and host. Licensing is another question.
>>> To my knowledge this approach won't get merged upstream.
>>> P(B) Support by the host system
>>> The host system needs a piece of code, loading the guest binary and
>>> providing it with knowledge about the environment (external_resolver).
>>> We haven't discussed this approach in detail.
>>> I hope, this gives a good overview and we can have a fruitful discussion.
>>> Cheers,
>>> Philipp
>>> [1]
>>> https://github.com/phipse/L4RTEMS/blob/master/c/src/lib/libbsp/l4vcpu/pc386/startup/l4lib.h
>>> [2]
>>> https://github.com/phipse/L4RTEMS/blob/f5a32ed0121b3e5f0ac8ae4c53e636eab2257fb1/l4/pkg/RTEMS_wrapper/server/src/res.c
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
