[PATCH] [RSB] Add support for building rtems-or1k tool-chain.
Hesham Moustafa
heshamelmatary at gmail.com
Mon May 26 00:02:49 UTC 2014
On Mon, May 26, 2014 at 12:57 AM, Chris Johns <chris at contemporary.net.au>wrote:
> On 25/05/2014 10:12 am, Hesham ALMatary wrote:
>> From: Hesham AL-Matary <heshamelmatary at gmail.com>
>> Configuration files get the following releases:
>> - binutils-2.24
>> - newlib-2.1.0
>> - gcc-4.8.2
>> - gdb-7.7
>> Patches are mix of OpenRISC original patches and other
>> additions to build the previous releases for RTEMS.
> Thanks. We are look forward to get this into the tool set.
>> rtems/config/4.11/rtems-or1k.bset | 26 ++++++
>> rtems/config/tools/rtems-binutils-2.24-or1k.cfg | 25 ++++++
>> .../tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg | 39 +++++++++
>> rtems/config/tools/rtems-gdb-7.7-or1k.cfg | 28 +++++++
>> source-builder/config/gdb-7-7-or1k.cfg | 95
>> 5 files changed, 213 insertions(+)
>> create mode 100644 rtems/config/4.11/rtems-or1k.bset
>> create mode 100644 rtems/config/tools/rtems-binutils-2.24-or1k.cfg
>> create mode 100644 rtems/config/tools/rtems-gcc-
>> create mode 100644 rtems/config/tools/rtems-gdb-7.7-or1k.cfg
>> create mode 100644 source-builder/config/gdb-7-7-or1k.cfg
>> diff --git a/rtems/config/4.11/rtems-or1k.bset b/rtems/config/4.11/rtems-
>> or1k.bset
>> new file mode 100644
>> index 0000000..dbc95e7
>> --- /dev/null
>> +++ b/rtems/config/4.11/rtems-or1k.bset
>> @@ -0,0 +1,26 @@
>> +# Tools Set for RTEMS or1k 4.11 Stable
>> +%define release 1
>> +%define rtems_arch or1k
>> +# The RTEMS 4.11 BSP to build and test
>> +%define rtems_bsps all
>> +# The RTEMS 4.11 base defines.
>> +%include rtems-4.11-base.bset
>> +# Tools configuration.
>> +4.11/rtems-autotools
>> +devel/expat-2.1.0-1
>> +tools/rtems-binutils-2.24-or1k
>> +tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k
>> +tools/rtems-gdb-7.7-or1k
>> diff --git a/rtems/config/tools/rtems-binutils-2.24-or1k.cfg
>> b/rtems/config/tools/rtems-binutils-2.24-or1k.cfg
>> index 0000000..d1e352a
>> --- /dev/null
>> +++ b/rtems/config/tools/rtems-binutils-2.24-or1k.cfg
>> @@ -0,0 +1,25 @@
>> +# Binutils 2.24.
>> +%include %{_configdir}/checks.cfg
>> +%include %{_configdir}/base.cfg
>> +%define binutils_version 2.24
>> +# Enable deterministic archives by default. This will be the default
>> +# there all tools using this binutils will create deterministic
>> +# archives.
>> +%define with_deterministic_archives 1
>> +# or1k patches
>> +%patch add binutils -p1 https://raw.githubusercontent.
>> com/heshamelmatary/or1k-rtems/master/patches/binutils-2.24-
>> or1k-rtems.diff
> If you move this to the bset file can you use rtems-binutils-2.24.cfg ?
> Build set files support %source and %patch. This localises architecture
> specific patches to that architecture.
> That makes sense. I was just separating the whole process of patching,
custom configurations and building in earlier stages to easily catch up
errors. But now after every thing works fine, I will delete all *or1k*.cfg
files, and make changes as few as possible, most likely it will be just a
new .bset file as you suggested.
>> +# The binutils build instructions. We use 2.xx Release 1.
>> +%include %{_configdir}/binutils-2-1.cfg
>> diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
>> b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
>> index 0000000..be4b7cc
>> --- /dev/null
>> +++ b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-or1k.cfg
> Same here ?
> @@ -0,0 +1,39 @@
>> +# GCC 4.8.2., Newlib-2.1.0
>> +%include %{_configdir}/versions.cfg
>> +%define newlib_version 2.1.0
>> +%define gcc_version 4.8.2
>> +%define mpfr_version 3.0.1
>> +%define mpc_version 0.8.2
>> +%define gmp_version 5.0.5
>> +%define with_threads 1
>> +%define with_plugin 0
>> +%ifn %{defined with_iconv}
>> +%define with_iconv 1
>> +%endif
>> +# Chris's patch to use the POSIX thread model for C++.
>> +%patch add gcc %{rtems_gcc_patches}/gcc-rtems-thread-model-posix-1.diff
>> +# or1k patch for gcc-4.8.2
>> +%patch add gcc -p1 https://raw.githubusercontent.
>> com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.2-or1k-
>> rtems-29-4-2014.diff
>> +# newlib-2.1.0 or1k patch
>> +%patch add newlib -p1 https://raw.githubusercontent.
>> com/heshamelmatary/or1k-rtems/master/patches/newlib-cvs-
>> or1k-rtems-29-4-2014.diff
>> +# The gcc/newlib build instructions. We use 4.8 Release 1.
>> +%include %{_configdir}/gcc-4.8-1.cfg
>> diff --git a/rtems/config/tools/rtems-gdb-7.7-or1k.cfg
>> b/rtems/config/tools/rtems-gdb-7.7-or1k.cfg
>> index 0000000..676e250
>> --- /dev/null
>> +++ b/rtems/config/tools/rtems-gdb-7.7-or1k.cfg
>> @@ -0,0 +1,28 @@
>> +# GDB 7.7.
>> +%define gdb_version 7.7
>> +# Clean up the sim-arange inline code so it builds.
>> +%patch add gdb %{rtems_gdb_patches}/gdb-sim-arange-inline.diff
>> +%patch add gdb %{rtems_gdb_patches}/gdb-sim-cgen-inline.diff
>> +# or1k patch
>> +%patch add gdb -p1 https://raw.githubusercontent.
>> com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
>> +%if %{_build_os} == freebsd
>> + %patch add gdb -p0 %{rtems_gdb_patches}/patch-
>> gdb-python-python-config.py
>> +%endif
>> +# The gdb build instructions. We use 7.xx Release 1.
>> +%include %{_configdir}/gdb-7-7-or1k.cfg
>> diff --git a/source-builder/config/gdb-7-7-or1k.cfg
>> b/source-builder/config/gdb-7-7-or1k.cfg
>> index 0000000..04d748f
>> --- /dev/null
>> +++ b/source-builder/config/gdb-7-7-or1k.cfg
> Just looking at this file I cannot see what has changed ? Why do we need a
> special gdb build script ?
> Chris
> @@ -0,0 +1,95 @@
>> +# GDB 7.xx Version 1.
>> +# This configuration file configure's, make's and install's gdb.
>> +# Select Snapshot Macro Maps
>> +%select gdb-snapshot
>> +%select expat-snapshot
>> +# The description.
>> +Name: %{_target}-gdb-%{gdb_version}-%{release}
>> +Summary: GDB v%{gdb_version} for target %{_target} on host %{_host}
>> +Version: %{gdb_version}
>> +Release: %{release}
>> +URL: http://www.gnu.org/software/gdb/
>> +BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>> +# Source
>> +%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.bz2
>> +# Prepare the source code.
>> +%prep
>> + build_top=$(pwd)
>> + source_dir_gdb="gdb-%{gdb_version}"
>> + %source setup gdb -q -n gdb-%{gdb_version}
>> + %patch setup gdb -p1
>> + cd ${build_top}
>> +%build
>> + build_top=$(pwd)
>> + %{build_directory}
>> + mkdir -p ${build_dir}
>> + cd ${build_dir}
>> + %{host_build_flags}
>> + if test "%{_build}" != "%{_host}" ; then
>> + GDB_LIBS_STATIC="-lexpat"
>> + else
>> + GDB_LIBS="%{_forced_static}"
>> + fi
>> + LIBS_STATIC=${GDB_LIBS_STATIC} \
>> + LIBS=${GDB_LIBS} \
>> + ../${source_dir_gdb}/configure \
>> + --build=%{_build} --host=%{_host} \
>> + --target=%{_target} \
>> + --verbose --disable-nls \
>> + --without-included-gettext \
>> + --disable-win32-registry \
>> + --disable-werror \
>> + --disable-sim \
>> + --with-expat \
>> + --without-python \
>> + --prefix=%{_prefix} --bindir=%{_bindir} \
>> + --exec-prefix=%{_exec_prefix} \
>> + --includedir=%{_includedir} --libdir=%{_libdir} \
>> + --mandir=%{_mandir} --infodir=%{_infodir}
>> + %{__make} %{?_smp_mflags} all
>> + cd ${build_top}
>> +%install
>> + build_top=$(pwd)
>> + %{__rmdir} $SB_BUILD_ROOT
>> + cd ${build_dir}
>> + %{__make} DESTDIR=$SB_BUILD_ROOT install
>> + # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
>> + %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
>> + %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
>> + touch $SB_BUILD_ROOT%{_infodir}/dir
>> + cd ${build_top}
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140526/0879a235/attachment-0001.html>
