[PATCH 09/12] fsdosfssync01: Stack size for bdbuf SMP workaround
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Wed May 28 06:47:19 UTC 2014
-------- Original-Nachricht --------
Betreff: Re: [PATCH 09/12] fsdosfssync01: Stack size for bdbuf SMP
workaround
Datum: Tue, 27 May 2014 17:11:32 +0200
Von: Ralf Kirchner <ralf.kirchner at embedded-brains.de>
Organisation: embedded-brains GmbH
An: Gedare Bloom <gedare at rtems.org>
Am 27.05.2014 17:04, schrieb Gedare Bloom:
> On Tue, May 27, 2014 at 10:47 AM, Ralf Kirchner
> <ralf.kirchner at embedded-brains.de> wrote:
>> Increase the size of the init task stack for the SMP workaround within bdbuf.
>> testsuites/fstests/fsdosfssync01/init.c | 12 ++++++++++++
>> 1 Datei geändert, 12 Zeilen hinzugefügt(+)
>> diff --git a/testsuites/fstests/fsdosfssync01/init.c b/testsuites/fstests/fsdosfssync01/init.c
>> index b0022e9..022cd2b 100644
>> --- a/testsuites/fstests/fsdosfssync01/init.c
>> +++ b/testsuites/fstests/fsdosfssync01/init.c
>> @@ -170,6 +170,18 @@ size_t rtems_ramdisk_configuration_size = 1;
>> #define CONFIGURE_EXTRA_TASK_STACKS (8 * 1024)
>> +#if defined( RTEMS_SMP )
>> + #if defined( RTEMS_POSIX_API )
>> + /* The single core bdbuf implementation with enabling and disabling preemption
>> + * will not work under SMP. Thus we need to use POSIX mutexes and POSIX
>> + * condition variables as a workaround.
>> + * These require additional stack size.
>> + #define CONFIGURE_INIT_TASK_STACK_SIZE (2 * CPU_STACK_MINIMUM_SIZE)
>> + #endif /* defined( RTEMS_POSIX_API ) */
>> +#endif /* defined( RTEMS_SMP ) */
> This kind of hack in the application configuration is not very
> user-friendly. You should adjust for the required resources in
> confdefs.h instead, by configuring for the required mutexes/condvars
> explicitly.
Hi Gedare,
That is beeing done. Memory for the mutexes and condition variables gets
allocated in confdefs.h.
Here I need more stack (likely because the nesting depth is higher for
mutexes and condition variables than for the single core handling with
semaphores).
And I need this addition stack only for this single test. All other
tests still had sufficient spare stack.
>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> 1.7.10.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Embedded Brains GmbH
Ralf Kirchner Dornierstr. 4
D-82178 Puchheim Germany
email: ralf.kirchner at embedded-brains.de
Phone: +49(0)89/1894741-17
Fax: +49(0)89/1894741-08
