[PATCH 1/4] Minor conditionals to enable building Scheduler Simulator on GNU/Linux
Wed May 28 12:39:17 UTC 2014
On Wed, May 28, 2014 at 5:00 AM, Sebastian Huber
> On 2014-05-28 00:16, Joel Sherrill wrote:
>> - rtems/score/threadimpl.h: _Thread_Start_multitasking does return
>>    on Scheduler Simulator. Initializing RTEMS returns to the command
>>    interpreter.
>> - rtems/score/smpimpl.h: _SMP_Start_multitasking_on_secondary_processor()
>>    is not applicable on the Scheduler Simulator and the no return
>> attribute
>>    gives a warning.
>> - rtems/score/assert.h: Scheduler Simulator uses glibc assert.h on
>> GNU/Linux.
>>    This will likely need to be adjusted more for other host compilers and
>>    C libraries
>> - threadrestart.c: Disable assert on Scheduler Simulator. Restarting self
>>    returns to the command interpreter.
> I would define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE and _Assert() to nothing
> in case RTEMS_SCHEDSIM is defined.  Do you really need this debugging stuff
> for the scheduler simulator?  I don't think we should propagate oddities of
> the scheduler simulator throughout the code base.
Yes, this was my initial reaction as well. Probably at least you could
make Assert_Not_reached() a nop, or write a wrapper for assert that
depends on schedsim. Can schedsim work more like a real target for
this case of not returning? I guess usually the system ends up in a
fatal or halt state? Maybe you can interpose on that state to return
-Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
