[PATCH 4/4] score: Use Resource Handler for MrsP semaphores
Sebastian Huber
Wed May 28 14:29:28 UTC 2014
This enables proper resource dependency tracking and as a side-effect
deadlock detection.
cpukit/score/include/rtems/score/mrsp.h | 14 +-
cpukit/score/include/rtems/score/mrspimpl.h | 127 +++++++++---
doc/user/sem.t | 11 +-
testsuites/smptests/smpmrsp01/init.c | 288 +++++++++++++++++++++++++++
4 files changed, 404 insertions(+), 36 deletions(-)
diff --git a/cpukit/score/include/rtems/score/mrsp.h b/cpukit/score/include/rtems/score/mrsp.h
index 407d5ef..c31d5f6 100644
--- a/cpukit/score/include/rtems/score/mrsp.h
+++ b/cpukit/score/include/rtems/score/mrsp.h
@@ -63,6 +63,7 @@ typedef enum {
MRSP_INVALID_NUMBER = 10,
MRSP_RESOUCE_IN_USE = 12,
MRSP_UNSATISFIED = 13,
+ MRSP_INCORRECT_STATE = 14,
MRSP_INVALID_PRIORITY = 19,
MRSP_NOT_OWNER_OF_RESOURCE = 23,
MRSP_NO_MEMORY = 26
@@ -102,12 +103,9 @@ typedef struct {
typedef struct {
- * @brief The owner of the MRSP resource.
- * In case this field is @c NULL, then this MRSP resource has currently no
- * owner.
+ * @brief Basic resource control.
- Thread_Control *owner;
+ Resource_Control Resource;
* @brief A chain of MrsP rivals waiting for resource ownership.
@@ -117,6 +115,12 @@ typedef struct {
Chain_Control Rivals;
+ * @brief The initial priority of the owner before it was elevated to the
+ * ceiling priority.
+ Priority_Control initial_priority_of_owner;
* @brief One ceiling priority per scheduler instance.
Priority_Control *ceiling_priorities;
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index 76d3bc8..e46309e 100644
--- a/cpukit/score/include/rtems/score/mrspimpl.h
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -21,6 +21,7 @@
+#include <rtems/score/resourceimpl.h>
@@ -41,17 +42,64 @@ extern "C" {
#define MRSP_RIVAL_STATE_TIMEOUT 0x2U
-RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
+RTEMS_INLINE_ROUTINE bool _MRSP_Set_root_visitor(
+ Resource_Node *node,
+ void *arg
+ _Resource_Node_set_root( node, arg );
+ return false;
+RTEMS_INLINE_ROUTINE void _MRSP_Set_root(
+ Resource_Node *top,
+ Resource_Node *root
+ _Resource_Node_set_root( top, root );
+ _Resource_Iterate( top, _MRSP_Set_root_visitor, root );
+RTEMS_INLINE_ROUTINE void _MRSP_Elevate_priority(
MRSP_Control *mrsp,
Thread_Control *new_owner,
Priority_Control ceiling_priority
- ++new_owner->resource_count;
- mrsp->owner = new_owner;
_Thread_Change_priority( new_owner, ceiling_priority, false );
+RTEMS_INLINE_ROUTINE void _MRSP_Restore_priority(
+ const MRSP_Control *mrsp,
+ Thread_Control *thread,
+ if ( thread->resource_count == 0 ) {
+ Priority_Control new_priority = _Scheduler_Highest_priority_of_two(
+ _Scheduler_Get( thread ),
+ initial_priority,
+ thread->real_priority
+ _Thread_Change_priority( thread, new_priority, true );
+RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
+ MRSP_Control *mrsp,
+ Thread_Control *new_owner,
+ Priority_Control initial_priority,
+ Priority_Control ceiling_priority
+ _Resource_Node_add_resource( &new_owner->Resource_node, &mrsp->Resource );
+ _Resource_Set_owner( &mrsp->Resource, &new_owner->Resource_node );
+ mrsp->initial_priority_of_owner = initial_priority;
+ _MRSP_Elevate_priority( mrsp, new_owner, ceiling_priority );
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Initialize(
MRSP_Control *mrsp,
Priority_Control ceiling_priority,
@@ -77,7 +125,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Initialize(
mrsp->ceiling_priorities[ i ] = ceiling_priority;
- mrsp->owner = NULL;
+ _Resource_Initialize( &mrsp->Resource );
_Chain_Initialize_empty( &mrsp->Rivals );
return MRSP_SUCCESSFUL;
@@ -100,11 +148,6 @@ RTEMS_INLINE_ROUTINE void _MRSP_Set_ceiling_priority(
mrsp->ceiling_priorities[ scheduler_index ] = ceiling_priority;
-RTEMS_INLINE_ROUTINE void _MRSP_Restore_priority( Thread_Control *thread )
- _Thread_Change_priority( thread, thread->real_priority, true );
RTEMS_INLINE_ROUTINE void _MRSP_Add_state(
MRSP_Rival *rival,
unsigned int state
@@ -127,7 +170,9 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout(
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
MRSP_Control *mrsp,
+ Resource_Node *owner,
Thread_Control *executing,
Watchdog_Interval timeout
@@ -137,11 +182,14 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
bool previous_life_protection;
unsigned int state;
- _Thread_Change_priority( executing, ceiling_priority, false );
+ _MRSP_Elevate_priority( mrsp, executing, ceiling_priority );
rival.thread = executing;
_Atomic_Init_uint( &rival.state, MRSP_RIVAL_STATE_WAITING );
_Chain_Append_unprotected( &mrsp->Rivals, &rival.Node );
+ _Resource_Add_rival( &mrsp->Resource, &executing->Resource_node );
+ _Resource_Node_set_dependency( &executing->Resource_node, &mrsp->Resource );
+ _MRSP_Set_root( &executing->Resource_node, owner );
if ( timeout > 0 ) {
_Watchdog_Initialize(
@@ -176,13 +224,15 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
state = _Atomic_Load_uint( &rival.state, ATOMIC_ORDER_RELAXED );
if ( ( state & MRSP_RIVAL_STATE_NEW_OWNER ) != 0 ) {
- ++executing->resource_count;
status = MRSP_SUCCESSFUL;
} else {
- if ( executing->resource_count == 0 ) {
- _MRSP_Restore_priority( executing );
+ Resource_Node *executing_node = &executing->Resource_node;
+ _Resource_Node_extract( executing_node );
+ _Resource_Node_set_dependency( executing_node, NULL );
+ _MRSP_Set_root( executing_node, executing_node );
+ _MRSP_Restore_priority( mrsp, executing, initial_priority );
status = MRSP_TIMEOUT;
@@ -200,27 +250,36 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Obtain(
MRSP_Status status;
const Scheduler_Control *scheduler = _Scheduler_Get( executing );
uint32_t scheduler_index = _Scheduler_Get_index( scheduler );
+ Priority_Control initial_priority = executing->current_priority;
Priority_Control ceiling_priority =
_MRSP_Get_ceiling_priority( mrsp, scheduler_index );
bool priority_ok = !_Scheduler_Is_priority_higher_than(
scheduler,
- executing->current_priority,
+ initial_priority,
ceiling_priority
+ Resource_Node *owner = _Resource_Get_owner( &mrsp->Resource );
if ( !priority_ok) {
return MRSP_INVALID_PRIORITY;
- if ( mrsp->owner == NULL ) {
- _MRSP_Claim_ownership( mrsp, executing, ceiling_priority );
+ if ( owner == NULL ) {
+ _MRSP_Claim_ownership(
+ mrsp, executing,
+ initial_priority,
+ ceiling_priority
- } else if ( mrsp->owner == executing ) {
+ } else if ( _Resource_Node_get_root( owner ) == &executing->Resource_node ) {
+ /* Nested access or deadlock */
status = MRSP_UNSATISFIED;
} else if ( wait ) {
status = _MRSP_Wait_for_ownership(
mrsp,
+ owner,
executing,
+ initial_priority,
ceiling_priority,
timeout
@@ -236,25 +295,33 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Release(
- uint32_t resource_count = executing->resource_count;
- if ( mrsp->owner != executing ) {
+ if ( _Resource_Get_owner( &mrsp->Resource ) != &executing->Resource_node ) {
return MRSP_NOT_OWNER_OF_RESOURCE;
- if ( resource_count == 1 ) {
- executing->resource_count = 0;
- } else {
- executing->resource_count = resource_count - 1;
+ if (
+ !_Resource_Is_most_recent_resource_of_node(
+ &executing->Resource_node,
+ &mrsp->Resource
+ return MRSP_INCORRECT_STATE;
+ _Resource_Extract( &mrsp->Resource );
+ _MRSP_Restore_priority( mrsp, executing, mrsp->initial_priority_of_owner );
if ( _Chain_Is_empty( &mrsp->Rivals ) ) {
+ _Resource_Set_owner( &mrsp->Resource, NULL );
} else {
MRSP_Rival *rival = (MRSP_Rival *) _Chain_First( &mrsp->Rivals );
+ Resource_Node *new_owner = &rival->thread->Resource_node;
- mrsp->owner = rival->thread;
+ _Resource_Node_extract( new_owner );
+ _Resource_Node_set_dependency( new_owner, NULL );
+ _MRSP_Set_root( new_owner, new_owner );
+ _Resource_Node_add_resource( new_owner, &mrsp->Resource );
+ _Resource_Set_owner( &mrsp->Resource, new_owner );
_MRSP_Add_state( rival, MRSP_RIVAL_STATE_NEW_OWNER );
@@ -263,7 +330,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Release(
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Destroy( MRSP_Control *mrsp )
- if ( mrsp->owner != NULL ) {
+ if ( _Resource_Get_owner( &mrsp->Resource ) != NULL ) {
return MRSP_RESOUCE_IN_USE;
diff --git a/doc/user/sem.t b/doc/user/sem.t
index 95fa4b9..6bd22dd 100644
--- a/doc/user/sem.t
+++ b/doc/user/sem.t
@@ -751,6 +751,10 @@ willing to be blocked waiting for the semaphore. If it is set to
If the semaphore is available or the @code{@value{RPREFIX}NO_WAIT} option
component is set, then timeout is ignored.
+Deadlock situations are detected for MrsP semaphores and the
+ at code{@value{RPREFIX}UNSATISFIED} status code will be returned on SMP
+configurations in this case.
@subheading NOTES:
The following semaphore acquisition option constants
are defined by RTEMS:
@@ -806,7 +810,8 @@ procedure Semaphore_Release (
@subheading DIRECTIVE STATUS CODES:
@code{@value{RPREFIX}SUCCESSFUL} - semaphore released successfully@*
@code{@value{RPREFIX}INVALID_ID} - invalid semaphore id@*
- at code{@value{RPREFIX}NOT_OWNER_OF_RESOURCE} - calling task does not own semaphore
+ at code{@value{RPREFIX}NOT_OWNER_OF_RESOURCE} - calling task does not own semaphore@*
+ at code{@value{RPREFIX}INCORRECT_STATE} - invalid unlock order
@subheading DESCRIPTION:
@@ -838,6 +843,10 @@ calling task having its priority lowered. This will occur if
the calling task holds no other binary semaphores and it has
inherited a higher priority.
+The MrsP semaphores must be released in the reversed obtain order, otherwise
+the @code{@value{RPREFIX}INCORRECT_STATE} status code will be returned on SMP
@c
@c
@c
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index 4f6637a..b5590ed 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -44,6 +44,7 @@ typedef struct {
rtems_id mrsp_ids[MRSP_COUNT];
rtems_id scheduler_ids[CPU_COUNT];
rtems_id worker_ids[2 * CPU_COUNT];
+ rtems_id timer_id;
volatile bool stop_worker[CPU_COUNT];
counter counters[2 * CPU_COUNT];
Thread_Control *worker_task;
@@ -357,6 +358,290 @@ static void test_mrsp_nested_obtain_error(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void test_mrsp_unlock_order_error(void)
+ rtems_status_code sc;
+ rtems_id id_a;
+ rtems_id id_b;
+ puts("test MrsP unlock order error");
+ sc = rtems_semaphore_create(
+ rtems_build_name(' ', ' ', ' ', 'A'),
+ 1,
+ RTEMS_MULTIPROCESSOR_RESOURCE_SHARING
+ | RTEMS_BINARY_SEMAPHORE,
+ 1,
+ &id_a
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_build_name(' ', ' ', ' ', 'B'),
+ 1,
+ 1,
+ &id_b
+ sc = rtems_semaphore_obtain(id_a, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_semaphore_obtain(id_b, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_semaphore_release(id_a);
+ rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+ sc = rtems_semaphore_release(id_b);
+ sc = rtems_semaphore_delete(id_a);
+ sc = rtems_semaphore_delete(id_b);
+static void deadlock_timer(rtems_id id, void *arg)
+ test_context *ctx = &test_instance;
+ sc = rtems_task_suspend(ctx->worker_ids[0]);
+static void deadlock_worker(rtems_task_argument arg)
+ sc = rtems_semaphore_obtain(ctx->mrsp_ids[1], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_timer_fire_after(ctx->timer_id, 2, deadlock_timer, NULL);
+ sc = rtems_semaphore_obtain(ctx->mrsp_ids[0], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_semaphore_release(ctx->mrsp_ids[0]);
+ sc = rtems_semaphore_release(ctx->mrsp_ids[1]);
+ sc = rtems_event_transient_send(ctx->main_task_id);
+ rtems_task_suspend(RTEMS_SELF);
+ rtems_test_assert(0);
+static void test_mrsp_deadlock_error(void)
+ rtems_task_priority prio = 2;
+ puts("test MrsP deadlock error");
+ assert_prio(RTEMS_SELF, prio);
+ sc = rtems_timer_create(
+ rtems_build_name('M', 'R', 'S', 'P'),
+ &ctx->timer_id
+ 1,
+ prio,
+ &ctx->mrsp_ids[0]
+ 1,
+ prio,
+ &ctx->mrsp_ids[1]
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ prio,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->worker_ids[0]
+ sc = rtems_task_start(ctx->worker_ids[0], deadlock_worker, 0);
+ sc = rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
+ rtems_test_assert(sc == RTEMS_UNSATISFIED);
+ sc = rtems_task_resume(ctx->worker_ids[0]);
+ sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_task_delete(ctx->worker_ids[0]);
+ sc = rtems_semaphore_delete(ctx->mrsp_ids[0]);
+ sc = rtems_semaphore_delete(ctx->mrsp_ids[1]);
+ sc = rtems_timer_delete(ctx->timer_id);
+static void test_mrsp_multiple_obtain(void)
+ rtems_id sem_a_id;
+ rtems_id sem_b_id;
+ rtems_id sem_c_id;
+ puts("test MrsP multiple obtain");
+ change_prio(RTEMS_SELF, 4);
+ 1,
+ 3,
+ &sem_a_id
+ 1,
+ 2,
+ &sem_b_id
+ rtems_build_name(' ', ' ', ' ', 'C'),
+ 1,
+ 1,
+ &sem_c_id
+ assert_prio(RTEMS_SELF, 4);
+ sc = rtems_semaphore_obtain(sem_a_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ assert_prio(RTEMS_SELF, 3);
+ sc = rtems_semaphore_obtain(sem_b_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ assert_prio(RTEMS_SELF, 2);
+ sc = rtems_semaphore_obtain(sem_c_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ assert_prio(RTEMS_SELF, 1);
+ sc = rtems_semaphore_release(sem_c_id);
+ sc = rtems_semaphore_release(sem_b_id);
+ sc = rtems_semaphore_release(sem_a_id);
+ change_prio(RTEMS_SELF, 3);
+ sc = rtems_semaphore_delete(sem_a_id);
+ sc = rtems_semaphore_delete(sem_b_id);
+ sc = rtems_semaphore_delete(sem_c_id);
+ change_prio(RTEMS_SELF, 2);
static uint32_t simple_random(uint32_t v)
v *= 1664525;
@@ -589,6 +874,9 @@ static void Init(rtems_task_argument arg)
test_mrsp_flush_error();
test_mrsp_initially_locked_error();
test_mrsp_nested_obtain_error();
+ test_mrsp_unlock_order_error();
+ test_mrsp_deadlock_error();
+ test_mrsp_multiple_obtain();
test_mrsp_obtain_and_release();
test_mrsp_load();
1.7.7
