rtems/src/scheduler* code convention issue
Wed May 28 19:21:26 UTC 2014
On Wed, May 28, 2014 at 12:30 PM, Sebastian Huber
> On 2014-05-28 17:43, Gedare Bloom wrote:
>>> We still have no new rule for "avoidance of deep nesting by using early
>>> >returns" in the wiki page.  So we are still in the situation that
>>> > everyone
>>> >interested in code contributions must deduce this rule himself from the
>>> >"almost 200 API calls which take object ID and have the _Object_Get()
>>> >switch".
>> My vote is to limit nesting to 4 levels of indentation. Early returns
>> or local goto to error/out label should be used when it makes sense.
>> For example:
>> int foo(int bar)
>>    int a = 0; // one level
>>    if ( bar == a ) {
>>      int b = 1; // two levels
>>      while ( a++ < b ) {
>>        int c = 2; // three levels
>>        if ( a == c ) {
>>          goto err; // fourth and deepest level!
>>    return 0;
>> err:
>>    return -1;
> For the cpukit the coding style should enforce that new/changed code looks
> similar enough to the exiting code.  I really don't care how particular
> rules look like since you can find for every rule an arbitrary amount of
> pros and cons.  I think however that it is very important that the rules in
> charge are documented.  I should be possible to give newcomers a document
> that describes the coding style in detail.  It can also be used to judge
> code contributions.
> A "avoidance of deep nesting by using early returns" rule should cover what
> happens if it leads to duplicated clean up code.
I agree completely. My main point is that I don't know what "deep"
means here. You can always refactor code to reduce the depth to 1
nesting level, but no one wants that either. I guess what is the
prevailing sense of the nesting level we have/want?
-Gedare
