rtems-tester on realview BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Sat May 31 14:54:55 UTC 2014
On 5/31/2014 5:05 AM, Chris Johns wrote:
> On 31/05/2014 7:23 am, Joel Sherrill wrote:
>> Also <ctl>-c has no impact.
> I have pushed a fix for this. Please try.
Doesn't appear to be any different to me.
Should the machine argument to qemu for the realview BSP also
change?
Why is the serial IO directed to /dev/null? How will the script
get any output? This command works and is what the sim-scripts
use:
qemu-system-arm -no-reboot -net none -nographic -M real-bash-4.2$
qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 -m
256M -kernel
./arm-rtems4.11/c/realview_pbx_a9_qemu/testsuites/samples/hello/hello.exe
> Chris
