[PATCH] top: Resolve compile errors.
Jennifer Averett jennifer.averett at oarcorp.com
Mon Nov 3 12:58:50 UTC 2014
 cpukit/libmisc/cpuuse/cpuusagetop.c | 83 ++++++++++++++++++++++++++++---------
 1 file changed, 63 insertions(+), 20 deletions(-)
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index 7e7348a..ecafd00 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -30,13 +30,11 @@
  * Common variable to sync the load monitor task.
 static volatile int rtems_cpuusage_top_thread_active;
 typedef struct {
   void                  *context;
   rtems_printk_plugin_t  print;
@@ -44,13 +42,56 @@ typedef struct {
 #define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
+static inline bool Equal_to_uint32_t( uint32_t * lhs, uint32_t * rhs )
+   if ( *lhs == *rhs )
+     return true;
+   else
+     return false;
+static inline void Set_uint32_t( uint32_t * lhs, uint32_t * rhs )
+   *lhs = *rhs;
+static inline bool Less_than_uint32_t( uint32_t * lhs, uint32_t * rhs )
+   if ( *lhs < *rhs )
+    return true;
+   else
+    return false;
+#ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
+  #define _Thread_CPU_usage_Equal_to( _lhs, _rhs ) \
+          _Timestamp_Equal_to( _lhs, _rhs )
+#else
+          Equal_to_uint32_t( _lhs, _rhs )
+#endif
+#define  _Thread_CPU_usage_Set_to_zero( _time ) \
+         _Timestamp_Set_to_zero( _time )
+#else
+         Set_uint32_t( _time, 0 );
+#endif
+#define _Thread_CPU_usage_Less_than( _lhs, _rhs ) \
+        _Timestamp_Less_than( _lhs, _rhs )
+#else
+         Less_than_uint32_t( _lhs, _rhs )
+#endif
  * rtems_cpuusage_top_thread
- *  DESCRIPTION:
  * This function displays the load of the tasks on an ANSI terminal.
 static void
@@ -62,25 +103,29 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
   int                       j;
   int                       k;
   Objects_Information*      information;
-    char                    name[13];
+  char                      name[13];
   int                       task_count = 0;
   uint32_t                  seconds, nanoseconds;
   rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
   Thread_Control*           load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
-  unsigned long long        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
+  Thread_CPU_usage_t        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
+  Thread_CPU_usage_t        zero;
+  Timestamp_Control         uptime;
+  uint32_t                  ival, fval;
-  while (true)
+  while (true) {
-      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
+      Timestamp_Control  total, ran, uptime_at_last_reset;
     #else
       uint32_t           total_units = 0;
     #endif
     rtems_cpuusage_top_thread_active = 1;
+    _Thread_CPU_usage_Set_to_zero( &zero);
     memset (load_tasks, 0, sizeof (load_tasks));
-    memset (load, 0, sizeof (load));
+    for (i=0; i< (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1); i++)
+      _Thread_CPU_usage_Set_to_zero( &load[i] );
      * Iterate over the tasks and sort the highest load tasks
@@ -98,8 +143,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
         for ( k=1 ; k <= information->maximum ; k++ ) {
           the_thread = (Thread_Control *)information->local_table[ k ];
           if ( the_thread ) {
-            Thread_CPU_usage_t l = the_thread->cpu_time_used;
+            Thread_CPU_usage_t usage = the_thread->cpu_time_used;
              *  When not using nanosecond CPU usage resolution, we have to count
@@ -107,14 +151,15 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
              *  guideline as to what each number means proportionally.
             #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
-              total_units += l;
+              total_units += usage;
             #endif
             /* Count the number of tasks and sort this load value */
             task_count++;
             for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
               if (load_tasks[i]) {
-                if ((l == 0) || (l < load[i]))
+                if ( _Thread_CPU_usage_Equal_to( &usage, &zero) ||
+                     _Thread_CPU_usage_Less_than( &usage, &load[i]))
                   continue;
                 for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j--){
                   load_tasks[j + 1] = load_tasks[j];
@@ -122,7 +167,7 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
               load_tasks[i] = the_thread;
-              load[i]  = l;
+              load[i]  = usage;
               break;
@@ -153,13 +198,12 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
         " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
        #else
-         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
+        " ID         | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
        #endif
        "------------+---------------------+---------------+---------------+------------\n"
-    for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++)
+    for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
       if (!load_tasks[i])
         break;
@@ -183,7 +227,6 @@ rtems_cpuusage_top_thread (rtems_task_argument arg)
         Timestamp_Control last;
-        uint32_t          ival, fval;
          * If this is the currently executing thread, account for time
1.8.1.4
