[PATCH] (2 commits squashed into one) Beagle BSP for review
Ben Gras
beng at shrike-systems.com
Mon Nov 3 19:40:18 UTC 2014
All,
I have new patches with some last-minute smoothings added; removed obsolete
beagle.cfg, TODO, and separated the more generic ARM headers into a
separate commit. The new 3 commits are attached (and in my RTEMS github
repo).
Gedare, there is also a diff w.r.t. the previous submission attached as
requested.
On Mon, Nov 3, 2014 at 3:01 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hi,
> I don't have time to review, but am OK in principle with committing
> this code as it is tested, with the caveat that my previous comments
> be addressed post-merge.
> If you have a diff / commits on top of what you sent before, I'd be
> glad to give those a quick look.
> Thanks for your contribution!
> Gedare
> On Mon, Nov 3, 2014 at 7:20 AM, Ben Gras <beng at shrike-systems.com> wrote:
> > All,
> > Ok, as promised, I rebased and re-tested and have found & included a
> > portable way of making the SD card image (included in sdcard.sh), to be
> > merged with RSB (i.e. some of the tools sdcard.sh relies on are missing
> in
> > mainline RSB). Some of Gedare's initial feedback is processed thanks to
> > Brandon Matthews. It's tested to run on the original beaglebone,
> beaglebone
> > black and qemu linaro. (The assumption is it'll run on the bbxm hardware
> as
> > well as it was before rebasing.)
> > The result is split into 2 patches to show what was Claas's initial work.
> > This makes them a bit unreadable for the final result from the patches
> > unfortunately.
> > As before, see
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> > on how to build all the tools, RTEMS executables, sdcard images, and run
> the
> > test set from linaro qemu.
> > On Sat, Aug 30, 2014 at 5:50 PM, Ben Gras <beng at shrike-systems.com>
> wrote:
> >> All,
> >> OK, that seems like a fruitful way to proceed to me.
> >> Then I will do some minor cleanups, rebase, do all the tests again, and
> >> re-submit. There's just one problem I know of that I want to fix before
> the
> >> first commit happens, and that is that the FAT fs made by mtools doesn't
> >> boot on the HW it seems. (It does on the emulator.) A last-minute
> change -
> >> switching to mtools instead of dosfstools to use to make the SD card
> image
> >> because the latter is so linux-only.
> >> Stay tuned.
> >> On Wed, Aug 20, 2014 at 4:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >>> Ben, As far as getting this merged, all of my comments can be done as
> >>> a follow-on commit. -Gedare
> >>> On Thu, Jul 24, 2014 at 4:28 PM, Ben Gras <beng at shrike-systems.com>
> >>> wrote:
> >>> > Thanks for the fast & detailed review. Let me get back to it/you.
> >>> > In the meantime, any other feedback? From anyone I mean.
> >>> > On Thu, Jul 24, 2014 at 4:45 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >> Hi Ben,
> >>> >> Great work. I have a few comments. I skipped the i2c.h and i2c.c
> >>> >> files. Most of my comments are about style and a few requests to
> >>> >> refactor some of the larger files. The refactoring can be added to
> >>> >> your TODO if you like. Please fix the style issues if it is not a
> >>> >> burden.
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/README
> >>> >> +$ ../claas-rtems/configure --target=arm-rtems4.11
> >>> >> --enable-rtemsbsp="beaglebonewhite beagleboardxm"
> >>> >> Replace claas-rtems with rtems. If RSB support is available, make a
> >>> >> note about it.
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/TODO
> >>> >> open:
> >>> >> + . how to handle the interrupt?
> >>> >> What does this mean?
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/clock.c
> >>> >> Why is the entire file ifdef'd on ARM_MULTILIB_ARCH_V4?
> >>> >> It might be sensible to put the struct definitions in a .h file if
> >>> >> these omap registers might be re-usable.
> >>> >> +static struct omap_timer_registers regs_v2 = {
> >>> >> This might be better to put behind an #if IS_AM335X since it is not
> >>> >> used otherwise?
> >>> >> Avoid more than one blank line in a row.
> >>> >> +static int done = 0;
> >>> >> It would be nice if you got rid of this, but otherwise give it a
> more
> >>> >> useful name like "mmio_init_done"
> >>> >> +static void beagle_clock_handler_install(rtems_interrupt_handler
> isr)
> >>> >> + if (sc != RTEMS_SUCCESSFUL) {
> >>> >> + rtems_fatal_error_occurred(0xdeadbeef);
> >>> >> I think there is some capabilities in ARM for bsp fatal error codes
> >>> >> now. They should be preferred to be used to help debug these fatal
> >>> >> conditions.
> >>> >> +static inline uint32_t
> beagle_clock_nanoseconds_since_last_tick(void)
> >>> >> + return (read_frc() - (uint64_t) last_tick_nanoseconds) *
> 1000000000
> >>> >> / FRCLOCK_HZ;
> >>> >> This line is > 80 characters, please break it or shrink it.
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/console/console-config.c
> >>> >> +#define CONSOLE_UART_LSR (*(volatile unsigned int
> >>> >> *)(BSP_CONSOLE_UART_BASE+0x14))
> >>> >> Line > 80 characters, even with the spacing modified.
> >>> >> +static void beagle_console_init(void)
> >>> >> + while ((CONSOLE_SYSS & 1) == 0)
> >>> >> Is this a fatal loop or is it waiting for hardware to clear
> something?
> >>> >> + if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) ==
> >>> >> CONSOLE_LSR_THRE) {
> >>> >> Again > 80 characters. Is the test logically equivalent to: if (
> >>> >> (CONSOLE_LSR & CONSOLE_LSR_THRE) == CONSOLE_LSR_THRE)
> >>> >> + while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
> >>> >> Is this a fatal loop or is it waiting for hardware?
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
> >>> >> This bsp.h is really long. Probably it should be refactored into
> other
> >>> >> headers, including non-public ones.
> >>> >> +static inline void dsb(void)
> >>> >> + asm volatile("dsb" : : : "memory");
> >>> >> Fix the indentation.
> >>> >> +static inline void flush_data_cache(void)
> >>> >> Perhaps this should be using _CPU_cache_flush_entire_data()? Perhaps
> >>> >> there is a difference in that the cache manager code flushes and
> >>> >> "cleans" the cache...
> >>> >> Excess newlines. Done a few places in this file.
> >>> >> The comments following the defines for various AM33X_INT_ values go
> >>> >> off the end of the 80 column character width. Same for some other
> >>> >> comments following defines for OMAP3_TIMER, AM33X_DMTIMER1, and
> >>> >> AM335X_TIMER_. And further below for the CM_ WKUP and CM_PER_TIMER7
> >>> >> defines, and CLKSEL_TIMER1MS_CLK_SEL_SEL5.
> >>> >> +#define OMAP3_TCLR_AR (1 << 1) /* Autoreload or one-shot
> mode
> >>> >> +#define OMAP3_TCLR_PRE (1 << 5) /* Prescaler on */
> >>> >> +#define OMAP3_TCLR_PTV 2
> >>> >> This PTV is odd compared to the other defines here. Is it 2 ==
> (1<<1),
> >>> >> or is there a typo here?
> >>> >> Tabs are used in the OMAP3_CM_ defines, it should be space
> characters.
> >>> >> Also tabs are used in the read/write actlr, ttbcr, dacr, rrbr0
> >>> >> functions and the refresh_tlb function.
> >>> >> +/* i2c stuff */
> >>> >> +typedef struct {
> >>> >> +} beagle_i2c;
> >>> >> Shouldn't this go in beagle/include/i2c.h?
> >>> >> All of this mmu handling code should be refactored. Where possible,
> it
> >>> >> should use the existing code in arm-cp15.h
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> >>> >> This header defines static, non-inline functions. This doesn't make
> >>> >> sense.
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> >>> >> +static int irqs_enabled[BSP_INTERRUPT_VECTOR_MAX+1];
> >>> >> This is an array of 512 bytes. You could use a bit vector
> comprising 4
> >>> >> unsigned ints for the same purpose.
> >>> >> +volatile static int level = 0;
> >>> >> Unused variable?
> >>> >> +static uint32_t get_mir_reg(int vector, uint32_t *mask)
> >>> >> + if(vector < 0) while(1) ;
> >>> >> Make this a fatal error?
> >>> >> + if(vector < 32) return OMAP3_INTCPS_MIR0;
> >>> >> duplicate code.
> >>> >> + while(1) ;
> >>> >> +rtems_status_code bsp_interrupt_facility_initialize(void)
> >>> >> + mmio_write(omap_intr.base + OMAP3_INTCPS_SYSCONFIG,
> >>> >> OMAP3_SYSCONFIG_AUTOIDLE);
> >>> >> Line length > 80.
> >>> >> +++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> >>> >> +//static uint32_t pagetable[ARM_SECTIONS] __attribute__((aligned
> >>> >> (1024*16)));
> >>> >> commented-out.. delete it?
> >>> >> +BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
> >>> >> __attribute__ ((weak));
> >>> >> More than 80 characters.
> >>> >> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
> >>> >> b/c/src/lib/libbsp/bfin/acinclude.m4
> >>> >> index ab6082e..828fd89 100644
> >>> >> --- a/c/src/lib/libbsp/bfin/acinclude.m4
> >>> >> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
> >>> >> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
> >>> >> b/c/src/lib/libbsp/powerpc/acinclude.m4
> >>> >> index 6442399..e46fa2b 100644
> >>> >> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
> >>> >> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
> >>> >> Don't include these changes. Check your tool versions, and if the
> >>> >> correct version of tools does this, provide a separate patch for
> >>> >> generated files.
> >>> >> -Gedare
> >>> >> On Wed, Jul 23, 2014 at 9:00 PM, Ben Gras <beng at shrike-systems.com>
> >>> >> wrote:
> >>> >> > All,
> >>> >> > Full details on how to reproduce all the work from source
> >>> >> > repositories
> >>> >> > to
> >>> >> > scripts & utilities to write a complete sd card booting RTEMS and
> >>> >> > test
> >>> >> > the
> >>> >> > whole thing:
> >>> >> > I am submitting the attached patch for review for merging. If
> >>> >> > accepted
> >>> >> > for
> >>> >> > merging, please use the top two commits on
> >>> >> > https://github.com/bengras/rtems/tree/beaglebone-wip
> >>> >> > which have the same net effect but preserve Claas' work because of
> >>> >> > the
> >>> >> > earlier commit. The squashed version attached is for more
> convenient
> >>> >> > review.
> >>> >> > I was ironing out more wrinkles but given recent interest it seems
> >>> >> > smarter
> >>> >> > to merge sooner and keep polishing from mainline. Nevertheless I
> >>> >> > have
> >>> >> > put a
> >>> >> > lot of work into getting it into good shape already.
> >>> >> > I have rebased everything on the very latest master and verified
> >>> >> > That building all the tools and utilities from scratch work, using
> >>> >> > the
> >>> >> > RTEMS
> >>> >> > Source Builder repository (Ubuntu + FreeBSD).
> >>> >> > That building the beaglebone and bbxm BSPs and linking them with
> all
> >>> >> > the
> >>> >> > testsuite programs works (Ubuntu + FreeBSD).
> >>> >> > That the beaglexm-emulating linaro qemu executes all of those
> tests
> >>> >> > properly, invoked using a single command line with the scripts in
> >>> >> > the
> >>> >> > RTEMS
> >>> >> > tools repository, even though not all pass currently (Ubuntu +
> >>> >> > FreeBSD).
> >>> >> > That loading & running over JTAG works, both interactively with
> gdb
> >>> >> > and
> >>> >> > in a
> >>> >> > batch using gdb and the test runner.
> >>> >> > That running RTEMS executables using u-boot on the beaglebones
> from
> >>> >> > sd
> >>> >> > card
> >>> >> > work; both with and without MMU enabled at RTEMS start time.
> >>> >> > That Claas' earlier commit builds.
> >>> >> > Thanks so far to Chris and Brandon for help, support, instructions
> >>> >> > and
> >>> >> > advice in various forms :)
> >>> >> > Test results on qemu:
> >>> >> > Passed: 497 Failed: 3 Timeouts: 1 Invalid: 0
> >>> >> > The test results on bbxm over jtag (older):
> >>> >> > Passed: 475 Failed: 7 Timeouts: 10 Invalid: 0
> >>> >> > I want to iron out more wrinkles and build support (ethernet) but
> >>> >> > giving
> >>> >> > the
> >>> >> > bsp more exposure and having it in mainline so i don't have to
> keep
> >>> >> > rebasing
> >>> >> > & testing would be nice at this point.
> >>> >> > _______________________________________________
> >>> >> > devel mailing list
> >>> >> > devel at rtems.org
> >>> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141103/bcb80061/attachment-0001.html>
diff --git a/c/src/lib/libbsp/arm/acinclude.m4 b/c/src/lib/libbsp/arm/acinclude.m4
index a15de34..327650e 100644
--- a/c/src/lib/libbsp/arm/acinclude.m4
+++ b/c/src/lib/libbsp/arm/acinclude.m4
@@ -4,6 +4,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
case "$1" in
altera-cyclone-v )
AC_CONFIG_SUBDIRS([altera-cyclone-v]);;
+ beagle )
+ AC_CONFIG_SUBDIRS([beagle]);;
csb336 )
AC_CONFIG_SUBDIRS([csb336]);;
csb337 )
@@ -42,8 +44,6 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
AC_CONFIG_SUBDIRS([tms570]);;
xilinx-zynq )
AC_CONFIG_SUBDIRS([xilinx-zynq]);;
- beagle )
- AC_CONFIG_SUBDIRS([beagle]);;
AC_MSG_ERROR([Invalid BSP]);;
esac
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8050b88..988c2b3 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -32,7 +32,6 @@ include_bsp_HEADERS += ../../shared/include/irq-generic.h
include_bsp_HEADERS += ../../shared/include/irq-info.h
include_bsp_HEADERS += ../../shared/include/stackalloc.h
include_bsp_HEADERS += ../../shared/include/uart-output-char.h
-include_bsp_HEADERS += ../../shared/tod.h
include_bsp_HEADERS += ../shared/include/arm-a8core-start.h
include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
include_bsp_HEADERS += ../shared/include/arm-errata.h
@@ -41,7 +40,11 @@ include_bsp_HEADERS += ../shared/include/start.h
include_bsp_HEADERS += include/irq.h
include_bsp_HEADERS += include/i2c.h
-include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/arm-cp15.h
+include_libcpu_HEADERS =
+include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/arm-cp15.h
+include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/omap3.h
+include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/am335x.h
+include_libcpu_HEADERS += ../../../libcpu/arm/shared/include/omap_timer.h
# Data #
diff --git a/c/src/lib/libbsp/arm/beagle/README b/c/src/lib/libbsp/arm/beagle/README
index abdb176..9f02c11 100644
--- a/c/src/lib/libbsp/arm/beagle/README
@@ -4,10 +4,6 @@ original beagleboard isn't tested.
wiki: http://www.rtems.org/wiki/index.php/Beagleboard
-My blog post detailing all the building and using; there is more detail there
-than in this README:
-http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
1. *** CONFIGURING ************
bsp-specific build options in the environment at build time:
@@ -28,11 +24,12 @@ usage.
2. *** BUILDING ************
-To build BSPs for the beaglebone white and beagleboard xm:
+To build BSPs for the beaglebone white and beagleboard xm, starting from
+a directory in which you have this source tree in rtems-src:
$ mkdir b-beagle
$ cd b-beagle
-$ ../claas-rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp="beaglebonewhite beagleboardxm"
+$ ../rtems-src/configure --target=arm-rtems4.11 --enable-rtemsbsp="beaglebonewhite beagleboardxm"
$ make all
This should give you .exes somewhere.
@@ -91,13 +88,14 @@ uboot# tftp 0x80800000 rtems-app.img
uboot# dcache off ; icache off
uboot# bootm 0x80800000
4. *** SD CARD ****************
There is a script here that automatically writes an SD card for any of
the beagle targets.
-Let's write one for the Beaglebone Black:
+Let's write one for the Beaglebone Black. Assuming your source tree is
+at $HOME/development/rtems/rtems-src and your bsp is built and linked
+with examples and installed at $HOME/development/rtems/4.11.
% cd $HOME/development/rtems/rtems-src/c/src/lib/libbsp/arm/beagle/simscripts
% sh sdcard.sh $HOME/development/rtems/4.11 $HOME/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/hello/hello.exe
@@ -108,9 +106,10 @@ The script should give you a whole bunch of output, ending in:
There you go. dd that to an SD card and boot!
-The script needs to know whether it's for a Beagleboard xM or one of
-the Beaglebones. This is to know which uboot to use. It will detect this
-from the path the executable is in, so you have to specify the full path.
+The script needs to know whether it's for a Beagleboard xM or one of the
+Beaglebones. This is to know which uboot to use. It will detect this
+from the path the executable is in (in the above example, it contains
+'beagleboneblack'), so you have to specify the full path.
Good luck & enjoy!
diff --git a/c/src/lib/libbsp/arm/beagle/TODO b/c/src/lib/libbsp/arm/beagle/TODO
deleted file mode 100644
index 087b761..0000000
--- a/c/src/lib/libbsp/arm/beagle/TODO
+++ /dev/null
@@ -1,21 +0,0 @@
- . run testsuite
- . test reset xm and clock xm
- . waf compatability
-verified:
- . printk, printf, interrupt uart, timer (+nsec), clocks
- . different Hz
- . warnings
- . timer wraparound is ok
- . reset bbone
- . i turn caches and mmu on
- . works when booted with and without mmu on (cache off/on in uboot)
- . needed vbar; used standard arm_cp15_set_vector_base_address
- . minimize irq.h
- . coding conventions, spacing
- . doxygen
-open:
- . how to handle the interrupt?
- . uboot env
- . minimize Makefile.am
diff --git a/c/src/lib/libbsp/arm/beagle/clock.c b/c/src/lib/libbsp/arm/beagle/clock.c
index d58cb97..92f9a62 100644
--- a/c/src/lib/libbsp/arm/beagle/clock.c
@@ -17,43 +17,11 @@
#include <bsp.h>
-#ifdef ARM_MULTILIB_ARCH_V4
-struct omap_timer_registers;
-struct omap_timer
- uint32_t base;
- int irq_nr;
- struct omap_timer_registers *regs;
- uint32_t TIDR;
- uint32_t TIOCP_CFG;
- uint32_t TISTAT;
- uint32_t TISR;
- uint32_t TIER;
- uint32_t TWER;
- uint32_t TCLR;
- uint32_t TCRR;
- uint32_t TLDR;
- uint32_t TTGR;
- uint32_t TWPS;
- uint32_t TMAR;
- uint32_t TCAR1;
- uint32_t TSICR;
- uint32_t TCAR2;
- uint32_t TPIR;
- uint32_t TNIR;
- uint32_t TCVR;
- uint32_t TOCR;
- uint32_t TOWR;
+#include <libcpu/omap_timer.h>
+#ifdef ARM_MULTILIB_ARCH_V4
-static struct omap_timer_registers regs_v1 = {
+static omap_timer_registers_t regs_v1 = {
.TIDR = OMAP3_TIMER_TIDR,
.TIOCP_CFG = OMAP3_TIMER_TIOCP_CFG,
.TISTAT = OMAP3_TIMER_TISTAT,
@@ -77,7 +45,7 @@ static struct omap_timer_registers regs_v1 = {
/* AM335X has a different ip block for the non 1ms timers */
-static struct omap_timer_registers regs_v2 = {
+static omap_timer_registers_t regs_v2 = {
.TIDR = AM335X_TIMER_TIDR,
.TIOCP_CFG = AM335X_TIMER_TIOCP_CFG,
.TISTAT = AM335X_TIMER_IRQSTATUS_RAW,
@@ -99,19 +67,21 @@ static struct omap_timer_registers regs_v2 = {
.TOCR = -1, /* UNDEF */
.TOWR = -1 /* UNDEF */
/* which timers are in use? target-dependent.
* initialize at compile time.
#if IS_DM3730
-static struct omap_timer dm37xx_timer = {
+static omap_timer_t dm37xx_timer = {
.base = OMAP3_GPTIMER1_BASE,
.irq_nr = OMAP3_GPT1_IRQ,
.regs = ®s_v1
/* free running timer */
-static struct omap_timer dm37xx_fr_timer = {
+static omap_timer_t dm37xx_fr_timer = {
.base = OMAP3_GPTIMER10_BASE,
.irq_nr = OMAP3_GPT10_IRQ,
.regs = ®s_v1
@@ -119,28 +89,28 @@ static struct omap_timer dm37xx_fr_timer = {
static struct omap_timer *fr_timer = &dm37xx_fr_timer;
static struct omap_timer *timer = &dm37xx_timer;
-#endif
+#endif
#if IS_AM335X
/* normal timer */
-static struct omap_timer am335x_timer = {
+static omap_timer_t am335x_timer = {
.base = AM335X_DMTIMER1_1MS_BASE,
.irq_nr = AM335X_INT_TINT1_1MS,
.regs = ®s_v1
-static struct omap_timer am335x_fr_timer = {
+static omap_timer_t am335x_fr_timer = {
.base = AM335X_DMTIMER7_BASE,
.irq_nr = AM335X_INT_TINT7,
.regs = ®s_v2
static struct omap_timer *fr_timer = &am335x_fr_timer;
static struct omap_timer *timer = &am335x_timer;
#endif
diff --git a/c/src/lib/libbsp/arm/beagle/include/bsp.h b/c/src/lib/libbsp/arm/beagle/include/bsp.h
index fc001dd1..cc3d687 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bsp.h
@@ -35,6 +35,9 @@
#include <rtems/irq-extension.h>
+#include <libcpu/omap3.h>
+#include <libcpu/am335x.h>
#define BSP_FEATURE_IRQ_EXTENSION
/* UART base clock frequency */
@@ -56,443 +59,61 @@
static inline void
write32(uint32_t address, uint32_t value)
- REG(address) = value;
+ REG(address) = value;
/* Read an uint32_t from a memory address */
read32(uint32_t address)
- return REG(address);
+ return REG(address);
/* Set a 32 bits value depending on a mask */
static inline void
set32(uint32_t address, uint32_t mask, uint32_t value)
- uint32_t val;
- val = read32(address);
- /* clear the bits */
- val &= ~(mask);
- /* apply the value using the mask */
- val |= (value & mask);
- write32(address, val);
+ uint32_t val;
+ val = read32(address);
+ /* clear the bits */
+ val &= ~(mask);
+ /* apply the value using the mask */
+ val |= (value & mask);
+ write32(address, val);
/* Write a uint16_t value to a memory address. */
static inline void
write16(uint32_t address, uint16_t value)
- REG16(address) = value;
+ REG16(address) = value;
/* Read an uint16_t from a memory address */
static inline uint16_t
read16(uint32_t address)
- return REG16(address);
+ return REG16(address);
/* Data synchronization barrier */
- asm volatile("dsb" : : : "memory");
/* Instruction synchronization barrier */
static inline void isb(void)
- asm volatile("isb" : : : "memory");
+ asm volatile("isb" : : : "memory");
/* flush data cache */
- asm volatile("mov r0, #0; mcr p15, #0, r0, c7, c10, #4" : : : "memory");
+ asm volatile("mov r0, #0; mcr p15, #0, r0, c7, c10, #4" : : : "memory");
-/* Interrupt controller memory map */
-#define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
-#define OMAP3_AM335X_INTR_BASE 0x48200000 /* INTCPS physical address */
-/* Interrupt controller registers */
-#define OMAP3_INTCPS_REVISION 0x000 /* IP revision code */
-#define OMAP3_INTCPS_SYSCONFIG 0x010 /* Controls params */
-#define OMAP3_INTCPS_SYSSTATUS 0x014 /* Status */
-#define OMAP3_INTCPS_SIR_IRQ 0x040 /* Active IRQ number */
-#define OMAP3_INTCPS_SIR_FIQ 0x044 /* Active FIQ number */
-#define OMAP3_INTCPS_CONTROL 0x048 /* New int agreement bits */
-#define OMAP3_INTCPS_PROTECTION 0x04C /* Protection for other regs */
-#define OMAP3_INTCPS_IDLE 0x050 /* Clock auto-idle/gating */
-#define OMAP3_INTCPS_IRQ_PRIORITY 0x060 /* Active IRQ priority level */
-#define OMAP3_INTCPS_FIQ_PRIORITY 0x064 /* Active FIQ priority level */
-#define OMAP3_INTCPS_THRESHOLD 0x068 /* Priority threshold */
-#define OMAP3_INTCPS_ITR0 0x080 /* Raw pre-masking interrupt status */
-#define OMAP3_INTCPS_MIR0 0x084 /* Interrupt mask */
-#define OMAP3_INTCPS_MIR1 0x0A4 /* Interrupt mask */
-#define OMAP3_INTCPS_MIR2 0x0C4 /* Interrupt mask */
-#define OMAP3_INTCPS_MIR3 0x0E4 /* Interrupt mask */
-#define OMAP3_INTCPS_MIR_CLEAR0 0x088 /* Clear interrupt mask bits */
-#define OMAP3_INTCPS_MIR_SET0 0x08C /* Set interrupt mask bits */
-#define OMAP3_INTCPS_ISR_SET0 0x090 /* Set software int bits */
-#define OMAP3_INTCPS_ISR_CLEAR0 0x094 /* Clear software int bits */
-#define OMAP3_INTCPS_PENDING_IRQ0 0x098 /* IRQ status post-masking */
-#define OMAP3_INTCPS_PENDING_IRQ1 0x0b8 /* IRQ status post-masking */
-#define OMAP3_INTCPS_PENDING_IRQ2 0x0d8 /* IRQ status post-masking */
-#define OMAP3_INTCPS_PENDING_IRQ3 0x0f8 /* IRQ status post-masking */
-#define OMAP3_INTCPS_PENDING_FIQ0 0x09C /* FIQ status post-masking */
-#define OMAP3_INTCPS_ILR0 0x100 /* Priority for interrupts */
-/* SYSCONFIG */
-#define OMAP3_SYSCONFIG_AUTOIDLE 0x01 /* SYSCONFIG.AUTOIDLE bit */
-#define OMAP3_INTR_ITR(base,n) \
- (base + OMAP3_INTCPS_ITR0 + 0x20 * (n))
-#define OMAP3_INTR_MIR(base,n) \
- (base + OMAP3_INTCPS_MIR0 + 0x20 * (n))
-#define OMAP3_INTR_MIR_CLEAR(base,n) \
- (base + OMAP3_INTCPS_MIR_CLEAR0 + 0x20 * (n))
-#define OMAP3_INTR_MIR_SET(base,n) \
- (base + OMAP3_INTCPS_MIR_SET0 + 0x20 * (n))
-#define OMAP3_INTR_ISR_SET(base,n) \
- (base + OMAP3_INTCPS_ISR_SET0 + 0x20 * (n))
-#define OMAP3_INTR_ISR_CLEAR(base,n) \
- (base + OMAP3_INTCPS_ISR_CLEAR0 + 0x20 * (n))
-#define OMAP3_INTR_PENDING_IRQ(base,n) \
- (base + OMAP3_INTCPS_PENDING_IRQ0 + 0x20 * (n))
-#define OMAP3_INTR_PENDING_FIQ(base,n) \
- (base + OMAP3_INTCPS_PENDING_FIQ0 + 0x20 * (n))
-#define OMAP3_INTR_ILR(base,m) \
- (base + OMAP3_INTCPS_ILR0 + 0x4 * (m))
-#define OMAP3_INTR_ACTIVEIRQ_MASK 0x7f /* Active IRQ mask for SIR_IRQ */
-#define OMAP3_INTR_NEWIRQAGR 0x1 /* New IRQ Generation */
-#define OMAP3_DM337X_NR_IRQ_VECTORS 96
-/* Interrupt mappings */
-#define OMAP3_MCBSP2_ST_IRQ 4 /* Sidestone McBSP2 overflow */
-#define OMAP3_MCBSP3_ST_IRQ 5 /* Sidestone McBSP3 overflow */
-#define OMAP3_SYS_NIRQ 7 /* External source (active low) */
-#define OMAP3_SMX_DBG_IRQ 9 /* L3 interconnect error for debug */
-#define OMAP3_SMX_APP_IRQ 10 /* L3 interconnect error for application */
-#define OMAP3_PRCM_IRQ 11 /* PRCM module */
-#define OMAP3_SDMA0_IRQ 12 /* System DMA request 0 */
-#define OMAP3_SDMA1_IRQ 13 /* System DMA request 1 */
-#define OMAP3_SDMA2_IRQ 14 /* System DMA request 2 */
-#define OMAP3_SDMA3_IRQ 15 /* System DMA request 3 */
-#define OMAP3_MCBSP1_IRQ 16 /* McBSP module 1 */
-#define OMAP3_MCBSP2_IRQ 17 /* McBSP module 2 */
-#define OMAP3_GPMC_IRQ 20 /* General-purpose memory controller */
-#define OMAP3_SGX_IRQ 21 /* 2D/3D graphics module */
-#define OMAP3_MCBSP3_IRQ 22 /* McBSP module 3 */
-#define OMAP3_MCBSP4_IRQ 23 /* McBSP module 4 */
-#define OMAP3_CAM0_IRQ 24 /* Camera interface request 0 */
-#define OMAP3_DSS_IRQ 25 /* Display subsystem module */
-#define OMAP3_MAIL_U0_IRQ 26 /* Mailbox user 0 request */
-#define OMAP3_MCBSP5_IRQ 27 /* McBSP module 5 */
-#define OMAP3_IVA2_MMU_IRQ 28 /* IVA2 MMU */
-#define OMAP3_GPIO1_IRQ 29 /* GPIO module 1 */
-#define OMAP3_GPIO2_IRQ 30 /* GPIO module 2 */
-#define OMAP3_GPIO3_IRQ 31 /* GPIO module 3 */
-#define OMAP3_GPIO4_IRQ 32 /* GPIO module 4 */
-#define OMAP3_GPIO5_IRQ 33 /* GPIO module 5 */
-#define OMAP3_GPIO6_IRQ 34 /* GPIO module 6 */
-#define OMAP3_WDT3_IRQ 36 /* Watchdog timer module 3 overflow */
-#define OMAP3_GPT1_IRQ 37 /* General-purpose timer module 1 */
-#define OMAP3_GPT2_IRQ 38 /* General-purpose timer module 2 */
-#define OMAP3_GPT3_IRQ 39 /* General-purpose timer module 3 */
-#define OMAP3_GPT4_IRQ 40 /* General-purpose timer module 4 */
-#define OMAP3_GPT5_IRQ 41 /* General-purpose timer module 5 */
-#define OMAP3_GPT6_IRQ 42 /* General-purpose timer module 6 */
-#define OMAP3_GPT7_IRQ 43 /* General-purpose timer module 7 */
-#define OMAP3_GPT8_IRQ 44 /* General-purpose timer module 8 */
-#define OMAP3_GPT9_IRQ 45 /* General-purpose timer module 9 */
-#define OMAP3_GPT10_IRQ 46 /* General-purpose timer module 10 */
-#define OMAP3_GPT11_IRQ 47 /* General-purpose timer module 11 */
-#define OMAP3_SPI4_IRQ 48 /* McSPI module 4 */
-#define OMAP3_MCBSP4_TX_IRQ 54 /* McBSP module 4 transmit */
-#define OMAP3_MCBSP4_RX_IRQ 55 /* McBSP module 4 receive */
-#define OMAP3_I2C1_IRQ 56 /* I2C module 1 */
-#define OMAP3_I2C2_IRQ 57 /* I2C module 2 */
-#define OMAP3_HDQ_IRQ 58 /* HDQ/1-Wire */
-#define OMAP3_MCBSP1_TX_IRQ 59 /* McBSP module 1 transmit */
-#define OMAP3_MCBSP1_RX_IRQ 60 /* McBSP module 1 receive */
-#define OMAP3_I2C3_IRQ 61 /* I2C module 3 */
-#define OMAP3_MCBSP2_TX_IRQ 62 /* McBSP module 2 transmit */
-#define OMAP3_MCBSP2_RX_IRQ 63 /* McBSP module 2 receive */
-#define OMAP3_SPI1_IRQ 65 /* McSPI module 1 */
-#define OMAP3_SPI2_IRQ 66 /* McSPI module 2 */
-#define OMAP3_UART1_IRQ 72 /* UART module 1 */
-#define OMAP3_UART2_IRQ 73 /* UART module 2 */
-#define OMAP3_UART3_IRQ 74 /* UART module 3 */
-#define OMAP3_PBIAS_IRQ 75 /* Merged interrupt for PBIASlite 1/2 */
-#define OMAP3_OHCI_IRQ 76 /* OHCI HSUSB MP Host Interrupt */
-#define OMAP3_EHCI_IRQ 77 /* EHCI HSUSB MP Host Interrupt */
-#define OMAP3_TLL_IRQ 78 /* HSUSB MP TLL Interrupt */
-#define OMAP3_MCBSP5_TX_IRQ 81 /* McBSP module 5 transmit */
-#define OMAP3_MCBSP5_RX_IRQ 82 /* McBSP module 5 receive */
-#define OMAP3_MMC1_IRQ 83 /* MMC/SD module 1 */
-#define OMAP3_MMC2_IRQ 86 /* MMC/SD module 2 */
-#define OMAP3_ICR_IRQ 87 /* MPU ICR */
-#define OMAP3_D2DFRINT_IRQ 88 /* 3G coproc (in stacked modem config) */
-#define OMAP3_MCBSP3_TX_IRQ 89 /* McBSP module 3 transmit */
-#define OMAP3_MCBSP3_RX_IRQ 90 /* McBSP module 3 receive */
-#define OMAP3_SPI3_IRQ 91 /* McSPI module 3 */
-#define OMAP3_HSUSB_MC_IRQ 92 /* High-speed USB OTG */
-#define OMAP3_HSUSB_DMA_IRQ 93 /* High-speed USB OTG DMA */
-#define OMAP3_MMC3_IRQ 94 /* MMC/SD module 3 */
-#define AM335X_INT_EMUINT 0 /* Emulation interrupt (EMUICINTR) */
-#define AM335X_INT_COMMTX 1 /* CortexA8 COMMTX */
-#define AM335X_INT_COMMRX 2 /* CortexA8 COMMRX */
-#define AM335X_INT_BENCH 3 /* CortexA8 NPMUIRQ */
-#define AM335X_INT_ELM_IRQ 4 /* Sinterrupt (Error location process completion) */
-#define AM335X_INT_NMI 7 /* nmi_int */
-#define AM335X_INT_L3DEBUG 9 /* l3_FlagMux_top_FlagOut1 */
-#define AM335X_INT_L3APPINT 10 /* l3_FlagMux_top_FlagOut0 */
-#define AM335X_INT_PRCMINT 11 /* irq_mpu */
-#define AM335X_INT_EDMACOMPINT 12 /* tpcc_int_pend_po0 */
-#define AM335X_INT_EDMAMPERR 13 /* tpcc_mpint_pend_po */
-#define AM335X_INT_EDMAERRINT 14 /* tpcc_errint_pend_po */
-#define AM335X_INT_ADC_TSC_GENINT 16 /* gen_intr_pend */
-#define AM335X_INT_USBSSINT 17 /* usbss_intr_pend */
-#define AM335X_INT_USB0 18 /* usb0_intr_pend */
-#define AM335X_INT_USB1 19 /* usb1_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT0 20 /* pr1_host_intr0_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT1 21 /* pr1_host_intr1_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT2 22 /* pr1_host_intr2_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT3 23 /* pr1_host_intr3_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT4 24 /* pr1_host_intr4_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT5 25 /* pr1_host_intr5_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT6 26 /* pr1_host_intr6_intr_pend */
-#define AM335X_INT_PRUSS1_EVTOUT7 27 /* pr1_host_intr7_intr_pend */
-#define AM335X_INT_MMCSD1INT 28 /* MMCSD1 SINTERRUPTN */
-#define AM335X_INT_MMCSD2INT 29 /* MMCSD2 SINTERRUPT */
-#define AM335X_INT_I2C2INT 30 /* I2C2 POINTRPEND */
-#define AM335X_INT_eCAP0INT 31 /* ecap_intr_intr_pend */
-#define AM335X_INT_GPIOINT2A 32 /* GPIO 2 POINTRPEND1 */
-#define AM335X_INT_GPIOINT2B 33 /* GPIO 2 POINTRPEND2 */
-#define AM335X_INT_USBWAKEUP 34 /* USBSS slv0p_Swakeup */
-#define AM335X_INT_LCDCINT 36 /* LCDC lcd_irq */
-#define AM335X_INT_GFXINT 37 /* SGX530 THALIAIRQ */
-#define AM335X_INT_ePWM2INT 39 /* (PWM Subsystem) epwm_intr_intr_pend */
-#define AM335X_INT_3PGSWRXTHR0 40 /* (Ethernet) c0_rx_thresh_pend (RX_THRESH_PULSE) */
-#define AM335X_INT_3PGSWRXINT0 41 /* CPSW (Ethernet) c0_rx_pend */
-#define AM335X_INT_3PGSWTXINT0 42 /* CPSW (Ethernet) c0_tx_pend */
-#define AM335X_INT_3PGSWMISC0 43 /* CPSW (Ethernet) c0_misc_pend */
-#define AM335X_INT_UART3INT 44 /* UART3 niq */
-#define AM335X_INT_UART4INT 45 /* UART4 niq */
-#define AM335X_INT_UART5INT 46 /* UART5 niq */
-#define AM335X_INT_eCAP1INT 47 /* (PWM Subsystem) ecap_intr_intr_pend */
-#define AM335X_INT_DCAN0_INT0 52 /* DCAN0 dcan_intr0_intr_pend */
-#define AM335X_INT_DCAN0_INT1 53 /* DCAN0 dcan_intr1_intr_pend */
-#define AM335X_INT_DCAN0_PARITY 54 /* DCAN0 dcan_uerr_intr_pend */
-#define AM335X_INT_DCAN1_INT0 55 /* DCAN1 dcan_intr0_intr_pend */
-#define AM335X_INT_DCAN1_INT1 56 /* DCAN1 dcan_intr1_intr_pend */
-#define AM335X_INT_DCAN1_PARITY 57 /* DCAN1 dcan_uerr_intr_pend */
-#define AM335X_INT_ePWM0_TZINT 58 /* eHRPWM0 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
-#define AM335X_INT_ePWM1_TZINT 59 /* eHRPWM1 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
-#define AM335X_INT_ePWM2_TZINT 60 /* eHRPWM2 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
-#define AM335X_INT_eCAP2INT 61 /* eCAP2 (PWM Subsystem) ecap_intr_intr_pend */
-#define AM335X_INT_GPIOINT3A 62 /* GPIO 3 POINTRPEND1 */
-#define AM335X_INT_GPIOINT3B 63 /* GPIO 3 POINTRPEND2 */
-#define AM335X_INT_MMCSD0INT 64 /* MMCSD0 SINTERRUPTN */
-#define AM335X_INT_SPI0INT 65 /* McSPI0 SINTERRUPTN */
-#define AM335X_INT_TINT0 66 /* Timer0 POINTR_PEND */
-#define AM335X_INT_TINT1_1MS 67 /* DMTIMER_1ms POINTR_PEND */
-#define AM335X_INT_TINT2 68 /* DMTIMER2 POINTR_PEND */
-#define AM335X_INT_TINT3 69 /* DMTIMER3 POINTR_PEND */
-#define AM335X_INT_I2C0INT 70 /* I2C0 POINTRPEND */
-#define AM335X_INT_I2C1INT 71 /* I2C1 POINTRPEND */
-#define AM335X_INT_UART0INT 72 /* UART0 niq */
-#define AM335X_INT_UART1INT 73 /* UART1 niq */
-#define AM335X_INT_UART2INT 74 /* UART2 niq */
-#define AM335X_INT_RTCINT 75 /* RTC timer_intr_pend */
-#define AM335X_INT_RTCALARMINT 76 /* RTC alarm_intr_pend */
-#define AM335X_INT_MBINT0 77 /* Mailbox0 (mail_u0_irq) initiator_sinterrupt_q_n */
-#define AM335X_INT_M3_TXEV 78 /* Wake M3 Subsystem TXEV */
-#define AM335X_INT_eQEP0INT 79 /* eQEP0 (PWM Subsystem) eqep_intr_intr_pend */
-#define AM335X_INT_MCATXINT0 80 /* McASP0 mcasp_x_intr_pend */
-#define AM335X_INT_MCARXINT0 81 /* McASP0 mcasp_r_intr_pend */
-#define AM335X_INT_MCATXINT1 82 /* McASP1 mcasp_x_intr_pend */
-#define AM335X_INT_MCARXINT1 83 /* McASP1 mcasp_r_intr_pend */
-#define AM335X_INT_ePWM0INT 86 /* (PWM Subsystem) epwm_intr_intr_pend */
-#define AM335X_INT_ePWM1INT 87 /* (PWM Subsystem) epwm_intr_intr_pend */
-#define AM335X_INT_eQEP1INT 88 /* (PWM Subsystem) eqep_intr_intr_pend */
-#define AM335X_INT_eQEP2INT 89 /* (PWM Subsystem) eqep_intr_intr_pend */
-#define AM335X_INT_DMA_INTR_PIN2 90 /* External DMA/Interrupt Pin2 pi_x_dma_event_intr2 (xdma_event_intr2) */
-#define AM335X_INT_WDT1INT 91 /* (Public Watchdog) WDTIMER1 PO_INT_PEND */
-#define AM335X_INT_TINT4 92 /* DMTIMER4 POINTR_PEN */
-#define AM335X_INT_TINT5 93 /* DMTIMER5 POINTR_PEN */
-#define AM335X_INT_TINT6 94 /* DMTIMER6 POINTR_PEND */
-#define AM335X_INT_TINT7 95 /* DMTIMER7 POINTR_PEND */
-#define AM335X_INT_GPIOINT0A 96 /* GPIO 0 POINTRPEND1 */
-#define AM335X_INT_GPIOINT0B 97 /* GPIO 0 POINTRPEND2 */
-#define AM335X_INT_GPIOINT1A 98 /* GPIO 1 POINTRPEND1 */
-#define AM335X_INT_GPIOINT1B 99 /* GPIO 1 POINTRPEND2 */
-#define AM335X_INT_GPMCINT 100 /* GPMC gpmc_sinterrupt */
-#define AM335X_INT_DDRERR0 101 /* EMIF sys_err_intr_pend */
-#define AM335X_INT_TCERRINT0 112 /* TPTC0 tptc_erint_pend_po */
-#define AM335X_INT_TCERRINT1 113 /* TPTC1 tptc_erint_pend_po */
-#define AM335X_INT_TCERRINT2 114 /* TPTC2 tptc_erint_pend_po */
-#define AM335X_INT_ADC_TSC_PENINT 115 /* ADC_TSC pen_intr_pend */
-#define AM335X_INT_SMRFLX_Sabertooth 120 /* Smart Reflex 0 intrpen */
-#define AM335X_INT_SMRFLX_Core 121 /* Smart Reflex 1 intrpend */
-#define AM335X_INT_DMA_INTR_PIN0 123 /* pi_x_dma_event_intr0 (xdma_event_intr0) */
-#define AM335X_INT_DMA_INTR_PIN1 124 /* pi_x_dma_event_intr1 (xdma_event_intr1) */
-#define AM335X_INT_SPI1INT 125 /* McSPI1 SINTERRUPTN */
-#define OMAP3_AM335X_NR_IRQ_VECTORS 125
-/* General-purpose timer register map */
-#define OMAP3_GPTIMER1_BASE 0x48318000 /* GPTIMER1 physical address */
-#define OMAP3_GPTIMER2_BASE 0x49032000 /* GPTIMER2 physical address */
-#define OMAP3_GPTIMER3_BASE 0x49034000 /* GPTIMER3 physical address */
-#define OMAP3_GPTIMER4_BASE 0x49036000 /* GPTIMER4 physical address */
-#define OMAP3_GPTIMER5_BASE 0x49038000 /* GPTIMER5 physical address */
-#define OMAP3_GPTIMER6_BASE 0x4903A000 /* GPTIMER6 physical address */
-#define OMAP3_GPTIMER7_BASE 0x4903C000 /* GPTIMER7 physical address */
-#define OMAP3_GPTIMER8_BASE 0x4903E000 /* GPTIMER8 physical address */
-#define OMAP3_GPTIMER9_BASE 0x49040000 /* GPTIMER9 physical address */
-#define OMAP3_GPTIMER10_BASE 0x48086000 /* GPTIMER10 physical address */
-#define OMAP3_GPTIMER11_BASE 0x48088000 /* GPTIMER11 physical address */
-/* General-purpose timer registers */
-#define OMAP3_TIMER_TIDR 0x000 /* IP revision code */
-#define OMAP3_TIMER_TIOCP_CFG 0x010 /* Controls params for GP timer L4 interface */
-#define OMAP3_TIMER_TISTAT 0x014 /* Status (excl. interrupt status) */
-#define OMAP3_TIMER_TISR 0x018 /* Pending interrupt status */
-#define OMAP3_TIMER_TIER 0x01C /* Interrupt enable */
-#define OMAP3_TIMER_TWER 0x020 /* Wakeup enable */
-#define OMAP3_TIMER_TCLR 0x024 /* Controls optional features */
-#define OMAP3_TIMER_TCRR 0x028 /* Internal counter value */
-#define OMAP3_TIMER_TLDR 0x02C /* Timer load value */
-#define OMAP3_TIMER_TTGR 0x030 /* Triggers counter reload */
-#define OMAP3_TIMER_TWPS 0x034 /* Indicates if Write-Posted pending */
-#define OMAP3_TIMER_TMAR 0x038 /* Value to be compared with counter */
-#define OMAP3_TIMER_TCAR1 0x03C /* First captured value of counter register */
-#define OMAP3_TIMER_TSICR 0x040 /* Control posted mode and functional SW reset */
-#define OMAP3_TIMER_TCAR2 0x044 /* Second captured value of counter register */
-#define OMAP3_TIMER_TPIR 0x048 /* Positive increment (1 ms tick) */
-#define OMAP3_TIMER_TNIR 0x04C /* Negative increment (1 ms tick) */
-#define OMAP3_TIMER_TCVR 0x050 /* Defines TCRR is sub/over-period (1 ms tick) */
-#define OMAP3_TIMER_TOCR 0x054 /* Masks tick interrupt */
-#define OMAP3_TIMER_TOWR 0x058 /* Number of masked overflow interrupts */
-#define AM335X_DMTIMER0_BASE 0x44E05000 /* DMTimer0 Registers */
-#define AM335X_DMTIMER1_1MS_BASE 0x44E31000 /* DMTimer1 1ms Registers (Accurate 1ms timer) */
-#define AM335X_DMTIMER2_BASE 0x48040000 /* DMTimer2 Registers */
-#define AM335X_DMTIMER3_BASE 0x48042000 /* DMTimer3 Registers */
-#define AM335X_DMTIMER4_BASE 0x48044000 /* DMTimer4 Registers */
-#define AM335X_DMTIMER5_BASE 0x48046000 /* DMTimer5 Registers */
-#define AM335X_DMTIMER6_BASE 0x48048000 /* DMTimer6 Registers */
-#define AM335X_DMTIMER7_BASE 0x4804A000 /* DMTimer7 Registers */
-/* General-purpose timer registers AM335x non 1MS timers have different offsets */
-#define AM335X_TIMER_TIDR 0x000 /* IP revision code */
-#define AM335X_TIMER_TIOCP_CFG 0x010 /* Controls params for GP timer L4 interface */
-#define AM335X_TIMER_IRQSTATUS_RAW 0x024 /* Timer IRQSTATUS Raw Register */
-#define AM335X_TIMER_IRQSTATUS 0x028 /* Timer IRQSTATUS Register */
-#define AM335X_TIMER_IRQENABLE_SET 0x02C /* Timer IRQENABLE Set Register */
-#define AM335X_TIMER_IRQENABLE_CLR 0x030 /* Timer IRQENABLE Clear Register */
-#define AM335X_TIMER_IRQWAKEEN 0x034 /* Timer IRQ Wakeup Enable Register */
-#define AM335X_TIMER_TCLR 0x038 /* Controls optional features */
-#define AM335X_TIMER_TCRR 0x03C /* Internal counter value */
-#define AM335X_TIMER_TLDR 0x040 /* Timer load value */
-#define AM335X_TIMER_TTGR 0x044 /* Triggers counter reload */
-#define AM335X_TIMER_TWPS 0x048 /* Indicates if Write-Posted pending */
-#define AM335X_TIMER_TMAR 0x04C /* Value to be compared with counter */
-#define AM335X_TIMER_TCAR1 0x050 /* First captured value of counter register */
-#define AM335X_TIMER_TSICR 0x054 /* Control posted mode and functional SW reset */
-#define AM335X_TIMER_TCAR2 0x058 /* Second captured value of counter register */
-/* Interrupt status register fields */
-#define OMAP3_TISR_MAT_IT_FLAG (1 << 0) /* Pending match interrupt status */
-#define OMAP3_TISR_OVF_IT_FLAG (1 << 1) /* Pending overflow interrupt status */
-#define OMAP3_TISR_TCAR_IT_FLAG (1 << 2) /* Pending capture interrupt status */
-/* Interrupt enable register fields */
-#define OMAP3_TIER_MAT_IT_ENA (1 << 0) /* Enable match interrupt */
-#define OMAP3_TIER_OVF_IT_ENA (1 << 1) /* Enable overflow interrupt */
-#define OMAP3_TIER_TCAR_IT_ENA (1 << 2) /* Enable capture interrupt */
-/* Timer control fields */
-#define OMAP3_TCLR_ST (1 << 0) /* Start/stop timer */
-#define OMAP3_TCLR_AR (1 << 1) /* Autoreload or one-shot mode */
-#define OMAP3_TCLR_PRE (1 << 5) /* Prescaler on */
-#define OMAP3_TCLR_PTV 2
-#define OMAP3_TCLR_OVF_TRG (1 << 10) /* Overflow trigger */
-#define OMAP3_CM_CLKSEL_GFX 0x48004b40
-#define OMAP3_CM_CLKEN_PLL 0x48004d00
-#define OMAP3_CM_FCLKEN1_CORE 0x48004A00
-#define OMAP3_CM_CLKSEL_CORE 0x48004A40 /* GPT10 src clock sel. */
-#define OMAP3_CM_FCLKEN_PER 0x48005000
-#define OMAP3_CM_CLKSEL_PER 0x48005040
-#define OMAP3_CM_CLKSEL_WKUP 0x48004c40 /* GPT1 source clock selection */
-#define CM_MODULEMODE_MASK (0x3 << 0)
-#define CM_MODULEMODE_ENABLE (0x2 << 0)
-#define CM_MODULEMODE_DISABLED (0x0 << 0)
-#define CM_CLKCTRL_IDLEST (0x3 << 16)
-#define CM_CLKCTRL_IDLEST_FUNC (0x0 << 16)
-#define CM_CLKCTRL_IDLEST_TRANS (0x1 << 16)
-#define CM_CLKCTRL_IDLEST_IDLE (0x2 << 16)
-#define CM_CLKCTRL_IDLEST_DISABLE (0x3 << 16)
-#define CM_WKUP_BASE 0x44E00400 /* Clock Module Wakeup Registers */
-#define CM_WKUP_TIMER1_CLKCTRL (CM_WKUP_BASE + 0xC4) /* This register manages the TIMER1 clocks. [Memory Mapped] */
-#define CM_PER_BASE 0x44E00000 /* Clock Module Peripheral Registers */
-#define CM_PER_TIMER7_CLKCTRL (CM_PER_BASE + 0x7C) /* This register manages the TIMER7 clocks. [Memory Mapped] */
-/* CM_DPLL registers */
-#define CM_DPLL_BASE 0x44E00500 /* Clock Module PLL Registers */
-#define CLKSEL_TIMER1MS_CLK (CM_DPLL_BASE + 0x28)
-#define CLKSEL_TIMER1MS_CLK_SEL_MASK (0x7 << 0)
-#define CLKSEL_TIMER1MS_CLK_SEL_SEL1 (0x0 << 0) /* Select CLK_M_OSC clock */
-#define CLKSEL_TIMER1MS_CLK_SEL_SEL2 (0x1 << 0) /* Select CLK_32KHZ clock */
-#define CLKSEL_TIMER1MS_CLK_SEL_SEL3 (0x2 << 0) /* Select TCLKIN clock */
-#define CLKSEL_TIMER1MS_CLK_SEL_SEL4 (0x3 << 0) /* Select CLK_RC32K clock */
-#define CLKSEL_TIMER1MS_CLK_SEL_SEL5 (0x4 << 0) /* Selects the CLK_32768 from 32KHz Crystal Osc */
-#define CLKSEL_TIMER7_CLK (CM_DPLL_BASE + 0x04)
-#define CLKSEL_TIMER7_CLK_SEL_MASK (0x3 << 0)
-#define CLKSEL_TIMER7_CLK_SEL_SEL1 (0x0 << 0) /* Select TCLKIN clock */
-#define CLKSEL_TIMER7_CLK_SEL_SEL2 (0x1 << 0) /* Select CLK_M_OSC clock */
-#define CLKSEL_TIMER7_CLK_SEL_SEL3 (0x2 << 0) /* Select CLK_32KHZ clock */
-#define CLKSEL_TIMER7_CLK_SEL_SEL4 (0x3 << 0) /* Reserved */
-#define OMAP3_CLKSEL_GPT1 (1 << 0)
-#define OMAP3_CLKSEL_GPT10 (1 << 6)
-#define OMAP3_CLKSEL_GPT11 (1 << 7)
#define TIMER_FREQ 1000 /* clock frequency for OMAP timer (1ms) */
#define TIMER_COUNT(freq) (TIMER_FREQ/(freq)) /* initial value for counter*/
@@ -518,96 +139,91 @@ static inline void flush_data_cache(void)
#define SYSTEM_CLOCK_192 19200000
#define SYSTEM_CLOCK_96 96000000
-#define OMAP34XX_CORE_L4_IO_BASE 0x48000000
#if !defined(IS_DM3730) && !defined(IS_AM335X)
#error Unrecognized BSP configured.
#endif
#if IS_DM3730
-#define BSP_DEVICEMEM_START 0x48000000
-#define BSP_DEVICEMEM_END 0x5F000000
+#define BSP_DEVICEMEM_START 0x48000000
+#define BSP_DEVICEMEM_END 0x5F000000
#endif
#if IS_AM335X
-#define BSP_DEVICEMEM_START 0x44000000
-#define BSP_DEVICEMEM_END 0x57000000
+#define BSP_DEVICEMEM_START 0x44000000
+#define BSP_DEVICEMEM_END 0x57000000
#endif
/* per-target uart config */
#if IS_AM335X
-#define BSP_CONSOLE_UART 1
-#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_1
-#define BSP_CONSOLE_UART_IRQ OMAP3_UART1_IRQ
-#define BEAGLE_BASE_UART_1 0x44E09000
-#define BEAGLE_BASE_UART_2 0x48022000
-#define BEAGLE_BASE_UART_3 0x48024000
+#define BSP_CONSOLE_UART 1
+#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_1
+#define BSP_CONSOLE_UART_IRQ OMAP3_UART1_IRQ
+#define BEAGLE_BASE_UART_1 0x44E09000
+#define BEAGLE_BASE_UART_2 0x48022000
+#define BEAGLE_BASE_UART_3 0x48024000
#endif
#if IS_DM3730
-#define BSP_CONSOLE_UART 3
-#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_3
-#define BSP_CONSOLE_UART_IRQ OMAP3_UART3_IRQ
-#define BEAGLE_BASE_UART_1 0x4806A000
-#define BEAGLE_BASE_UART_2 0x4806C000
-#define BEAGLE_BASE_UART_3 0x49020000
+#define BSP_CONSOLE_UART 3
+#define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_3
+#define BSP_CONSOLE_UART_IRQ OMAP3_UART3_IRQ
+#define BEAGLE_BASE_UART_1 0x4806A000
+#define BEAGLE_BASE_UART_2 0x4806C000
+#define BEAGLE_BASE_UART_3 0x49020000
#endif
/* i2c stuff */
typedef struct {
- uint32_t rx_or_tx;
- uint32_t stat;
- uint32_t ctrl;
- uint32_t clk_hi;
- uint32_t clk_lo;
- uint32_t adr;
- uint32_t rxfl;
- uint32_t txfl;
- uint32_t rxb;
- uint32_t txb;
- uint32_t s_tx;
- uint32_t s_txfl;
+ uint32_t rx_or_tx;
+ uint32_t stat;
+ uint32_t ctrl;
+ uint32_t clk_hi;
+ uint32_t clk_lo;
+ uint32_t adr;
+ uint32_t rxfl;
+ uint32_t txfl;
+ uint32_t rxb;
+ uint32_t txb;
+ uint32_t s_tx;
+ uint32_t s_txfl;
} beagle_i2c;
/* sctlr */
/* Read System Control Register */
static inline uint32_t read_sctlr()
- uint32_t ctl;
- asm volatile("mrc p15, 0, %[ctl], c1, c0, 0 @ Read SCTLR\n\t"
- : [ctl] "=r" (ctl));
+ uint32_t ctl;
- return ctl;
+ asm volatile("mrc p15, 0, %[ctl], c1, c0, 0 @ Read SCTLR\n\t"
+ : [ctl] "=r" (ctl));
+ return ctl;
/* Write System Control Register */
static inline void write_sctlr(uint32_t ctl)
- asm volatile("mcr p15, 0, %[ctl], c1, c0, 0 @ Write SCTLR\n\t"
- : : [ctl] "r" (ctl));
- isb();
+ asm volatile("mcr p15, 0, %[ctl], c1, c0, 0 @ Write SCTLR\n\t"
+ : : [ctl] "r" (ctl));
+ isb();
/* Read Auxiliary Control Register */
static inline uint32_t read_actlr()
- uint32_t ctl;
+ uint32_t ctl;
- asm volatile("mrc p15, 0, %[ctl], c1, c0, 1 @ Read ACTLR\n\t"
- return ctl;
+ asm volatile("mrc p15, 0, %[ctl], c1, c0, 1 @ Read ACTLR\n\t"
+ return ctl;
/* Write Auxiliary Control Register */
static inline void write_actlr(uint32_t ctl)
- asm volatile("mcr p15, 0, %[ctl], c1, c0, 1 @ Write ACTLR\n\t"
- isb();
+ asm volatile("mcr p15, 0, %[ctl], c1, c0, 1 @ Write ACTLR\n\t"
+ isb();
/* Write Translation Table Base Control Register */
@@ -640,146 +256,75 @@ static inline void write_dacr(uint32_t dacr)
isb();
-#define ARM_TTBR_ADDR_MASK (0xffffc000)
-#define ARM_TTBR_OUTER_NC (0x0 << 3) /* Non-cacheable*/
-#define ARM_TTBR_OUTER_WBWA (0x1 << 3) /* Outer Write-Back */
-#define ARM_TTBR_OUTER_WT (0x2 << 3) /* Outer Write-Through */
-#define ARM_TTBR_OUTER_WBNWA (0x3 << 3) /* Outer Write-Back */
-#define ARM_TTBR_FLAGS_CACHED ARM_TTBR_OUTER_WBWA
static inline void refresh_tlb(void)
- dsb();
+ dsb();
- /* Invalidate entire unified TLB */
- asm volatile("mcr p15, 0, %[zero], c8, c7, 0 @ TLBIALL\n\t" : : [zero] "r" (0));
+ /* Invalidate entire unified TLB */
+ asm volatile("mcr p15, 0, %[zero], c8, c7, 0 @ TLBIALL\n\t"
+ : : [zero] "r" (0));
-#if 0
- /* Invalidate entire data TLB */
- asm volatile("mcr p15, 0, %[zero], c8, c6, 0" : : [zero] "r" (0));
+ /* Invalidate all instruction caches to PoU.
+ * Also flushes branch target cache. */
+ asm volatile("mcr p15, 0, %[zero], c7, c5, 0"
- /* Invalidate entire instruction TLB */
- asm volatile("mcr p15, 0, %[zero], c8, c5, 0" : : [zero] "r" (0));
-#endif
- * Invalidate all instruction caches to PoU.
- * Also flushes branch target cache.
- asm volatile("mcr p15, 0, %[zero], c7, c5, 0" : : [zero] "r" (0));
- /* Invalidate entire branch predictor array */
- asm volatile("mcr p15, 0, %[zero], c7, c5, 6" : : [zero] "r" (0)); /* flush BTB */
+ /* Invalidate entire branch predictor array */
+ asm volatile("mcr p15, 0, %[zero], c7, c5, 6"
+ : : [zero] "r" (0)); /* flush BTB */
- dsb();
- isb();
+ dsb();
+ isb();
/* Read Translation Table Base Register 0 */
static inline uint32_t read_ttbr0()
- uint32_t bar;
+ uint32_t bar;
- asm volatile("mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"
- : [bar] "=r" (bar));
+ asm volatile("mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"
+ : [bar] "=r" (bar));
- return bar & ARM_TTBR_ADDR_MASK;
+ return bar & ARM_TTBR_ADDR_MASK;
static inline uint32_t read_ttbr0_unmasked()
- uint32_t bar;
+ uint32_t bar;
- return bar;
+ return bar;
/* Write Translation Table Base Register 0 */
static inline void write_ttbr0(uint32_t bar)
- dsb();
- isb();
- /* In our setup TTBR contains the base address *and* the flags
- but other pieces of the kernel code expect ttbr to be the
- base address of the l1 page table. We therefore add the
- flags here and remove them in the read_ttbr0 */
- uint32_t v = (bar & ARM_TTBR_ADDR_MASK ) | ARM_TTBR_FLAGS_CACHED;
- asm volatile("mcr p15, 0, %[bar], c2, c0, 0 @ Write TTBR0\n\t"
- : : [bar] "r" (v));
- refresh_tlb();
+ dsb();
+ isb();
+ /* In our setup TTBR contains the base address *and* the flags
+ but other pieces of the kernel code expect ttbr to be the
+ base address of the l1 page table. We therefore add the
+ flags here and remove them in the read_ttbr0 */
+ uint32_t v = (bar & ARM_TTBR_ADDR_MASK ) | ARM_TTBR_FLAGS_CACHED;
+ asm volatile("mcr p15, 0, %[bar], c2, c0, 0 @ Write TTBR0\n\t"
+ : : [bar] "r" (v));
+ refresh_tlb();
-/* cpu control flags */
-/* CPU control register (CP15 register 1) */
-#define CPU_CONTROL_MMU_ENABLE 0x00000001 /* M: MMU/Protection unit enable */
-#define CPU_CONTROL_AFLT_ENABLE 0x00000002 /* A: Alignment fault enable */
-#define CPU_CONTROL_DC_ENABLE 0x00000004 /* C: IDC/DC enable */
-#define CPU_CONTROL_WBUF_ENABLE 0x00000008 /* W: Write buffer enable */
-#define CPU_CONTROL_32BP_ENABLE 0x00000010 /* P: 32-bit exception handlers */
-#define CPU_CONTROL_32BD_ENABLE 0x00000020 /* D: 32-bit addressing */
-#define CPU_CONTROL_LABT_ENABLE 0x00000040 /* L: Late abort enable */
-#define CPU_CONTROL_BEND_ENABLE 0x00000080 /* B: Big-endian mode */
-#define CPU_CONTROL_SYST_ENABLE 0x00000100 /* S: System protection bit */
-#define CPU_CONTROL_ROM_ENABLE 0x00000200 /* R: ROM protection bit */
-#define CPU_CONTROL_CPCLK 0x00000400 /* F: Implementation defined */
-#define CPU_CONTROL_SWP_ENABLE 0x00000400 /* SW: SWP{B} perform normally. */
-#define CPU_CONTROL_BPRD_ENABLE 0x00000800 /* Z: Branch prediction enable */
-#define CPU_CONTROL_IC_ENABLE 0x00001000 /* I: IC enable */
-#define CPU_CONTROL_VECRELOC 0x00002000 /* V: Vector relocation */
-#define CPU_CONTROL_ROUNDROBIN 0x00004000 /* RR: Predictable replacement */
-#define CPU_CONTROL_V4COMPAT 0x00008000 /* L4: ARMv4 compat LDR R15 etc */
-#define CPU_CONTROL_FI_ENABLE 0x00200000 /* FI: Low interrupt latency */
-#define CPU_CONTROL_UNAL_ENABLE 0x00400000 /* U: unaligned data access */
-#define CPU_CONTROL_XP_ENABLE 0x00800000 /* XP: extended page table */
-#define CPU_CONTROL_V_ENABLE 0x01000000 /* VE: Interrupt vectors enable */
-#define CPU_CONTROL_EX_BEND 0x02000000 /* EE: exception endianness */
-#define CPU_CONTROL_NMFI 0x08000000 /* NMFI: Non maskable FIQ */
-#define CPU_CONTROL_TR_ENABLE 0x10000000 /* TRE: */
-#define CPU_CONTROL_AF_ENABLE 0x20000000 /* AFE: Access flag enable */
-#define CPU_CONTROL_TE_ENABLE 0x40000000 /* TE: Thumb Exception enable */
-#define CPU_CONTROL_IDC_ENABLE CPU_CONTROL_DC_ENABLE
-/* VM bits */
-/* Big page (1MB section) specific flags. */
-#define ARM_VM_SECTION (1 << 1) /* 1MB section */
-#define ARM_VM_SECTION_PRESENT (1 << 1) /* Section is present */
-#define ARM_VM_SECTION_B (1 << 2) /* B Bit */
-#define ARM_VM_SECTION_C (1 << 3) /* C Bit */
-#define ARM_VM_SECTION_DOMAIN (0xF << 5) /* Domain Number */
-#define ARM_VM_SECTION_SUPER (0x1 << 10) /* Super access only AP[1:0] */
-#define ARM_VM_SECTION_USER (0x3 << 10) /* Super/User access AP[1:0] */
-#define ARM_VM_SECTION_TEX0 (1 << 12) /* TEX[0] */
-#define ARM_VM_SECTION_TEX1 (1 << 13) /* TEX[1] */
-#define ARM_VM_SECTION_TEX2 (1 << 14) /* TEX[2] */
-#define ARM_VM_SECTION_RO (1 << 15) /* Read only access AP[2] */
-#define ARM_VM_SECTION_SHAREABLE (1 << 16) /* Shareable */
-#define ARM_VM_SECTION_NOTGLOBAL (1 << 17) /* Not Global */
-/* inner and outer write-back, write-allocate */
-#define ARM_VM_SECTION_WB (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX0 | ARM_VM_SECTION_B )
-/* inner and outer write-through, no write-allocate */
-#define ARM_VM_SECTION_WT (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX1 | ARM_VM_SECTION_C )
-/* Inner , Write through, No Write Allocate Outer - Write Back, Write Allocate */
-#define ARM_VM_SECTION_WTWB (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX0 | ARM_VM_SECTION_C )
-/* shareable device */
-#define ARM_VM_SECTION_CACHED ARM_VM_SECTION_WTWB
-#define ARM_VM_SECTION_DEVICE (ARM_VM_SECTION_B)
/* Behaviour on fatal error; default: test-friendly.
* set breakpoint to bsp_fatal_extension.
-/* don't do this to allow tests to fail noninteractively */
-/* #define BSP_PRESS_KEY_FOR_RESET 1 */
-#define BSP_PRINT_EXCEPTION_CONTEXT 1 /* human-readable exception info */
-#define BSP_RESET_BOARD_AT_EXIT 1 /* causes qemu to exit, signaling end of test */
+/* Enabling BSP_PRESS_KEY_FOR_RESET prevents noninteractive testing */
+/*#define BSP_PRESS_KEY_FOR_RESET 1 */
+#define BSP_PRINT_EXCEPTION_CONTEXT 1
+ /* human-readable exception info */
+#define BSP_RESET_BOARD_AT_EXIT 1
+ /* causes qemu to exit, signaling end of test */
diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
index 6055eb8..8aa00df 100644
--- a/c/src/lib/libbsp/arm/beagle/irq.c
@@ -83,7 +83,6 @@ static uint32_t get_mir_reg(int vector, uint32_t *mask)
- if(vector < 32) return OMAP3_INTCPS_MIR0;
if(vector < 64) return OMAP3_INTCPS_MIR1;
if(vector < 96) return OMAP3_INTCPS_MIR2;
if(vector < 128) return OMAP3_INTCPS_MIR3;
diff --git a/c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg b/c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg
index 06c13ee..0000000
--- a/c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg
+++ /dev/null
@@ -1,5 +0,0 @@
-# Config file for BeagleBoard
-include $(RTEMS_ROOT)/make/custom/beagle.inc
diff --git a/c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg b/c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg
index 447a51e..ec0d2d2 100644
--- a/c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg
+++ b/c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg
@@ -1,2 +1,2 @@
-# Config file for Original BeagleBoard
+# Config file for BeagleBoard XM
diff --git a/c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg b/c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg
index 447a51e..f947dce 100644
--- a/c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg
+++ b/c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg
@@ -1,2 +1,2 @@
+# Config file for BeagleBone Black
diff --git a/c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg b/c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg
index 447a51e..4b035c0 100644
--- a/c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg
+++ b/c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg
@@ -1,2 +1,2 @@
+# Config file for Original BeagleBone (aka BeagleBone White)
diff --git a/c/src/lib/libbsp/arm/beagle/preinstall.am b/c/src/lib/libbsp/arm/beagle/preinstall.am
index 50957d8..dd1ec95 100644
--- a/c/src/lib/libbsp/arm/beagle/preinstall.am
+++ b/c/src/lib/libbsp/arm/beagle/preinstall.am
@@ -8,15 +8,15 @@ endif
PREINSTALL_DIRS =
DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES = $(TMPINSTALL_FILES)
all-am: $(PREINSTALL_FILES)
PREINSTALL_FILES =
-CLEANFILES += $(PREINSTALL_FILES)
+CLEANFILES = $(PREINSTALL_FILES)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES += $(TMPINSTALL_FILES)
$(PROJECT_LIB)/$(dirstamp):
@$(MKDIR_P) $(PROJECT_LIB)
@@ -82,10 +82,6 @@ $(PROJECT_INCLUDE)/bsp/uart-output-char.h: ../../shared/include/uart-output-char
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart-output-char.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart-output-char.h
-$(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
$(PROJECT_INCLUDE)/bsp/arm-a8core-start.h: ../shared/include/arm-a8core-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-a8core-start.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-a8core-start.h
@@ -118,6 +114,18 @@ $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: ../../../libcpu/arm/shared/include/arm-cp1
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
+$(PROJECT_INCLUDE)/libcpu/omap3.h: ../../../libcpu/arm/shared/include/omap3.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/omap3.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/omap3.h
+$(PROJECT_INCLUDE)/libcpu/am335x.h: ../../../libcpu/arm/shared/include/am335x.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/am335x.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/am335x.h
+$(PROJECT_INCLUDE)/libcpu/omap_timer.h: ../../../libcpu/arm/shared/include/omap_timer.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/omap_timer.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/omap_timer.h
$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh b/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
index 58ac911..becd2c7 100644
--- a/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
@@ -2,10 +2,9 @@
TMPDIR=tmp_sdcard_dir.$$
FATIMG=$TMPDIR/bbxm_boot_fat.img
+SIZE=65536
OFFSET=2048
-FATSIZE_KB=2880
-FATSIZE=`expr $FATSIZE_KB \* 2`
-SIZE=`expr $FATSIZE + $OFFSET`
+FATSIZE=`expr $SIZE - $OFFSET`
UENV=uEnv.txt
rm -rf $TMPDIR
@@ -52,15 +51,11 @@ set -e
IMG=${imgtype}_`basename $2`-sdcard.img
# Make an empty image
-dd if=/dev/zero of=$IMG bs=512 seek=$SIZE count=1
-# Make an ms-dos FS image
-rm -f $FATIMG
-export MTOOLSRC=$TMPDIR/mtools-conf
-echo "drive a:
- file=\"$FATIMG\"
- fat_bits=16
-" >$MTOOLSRC
-$PREFIX/bin/mformat -C -f $FATSIZE_KB a:
+dd if=/dev/zero of=$IMG bs=512 seek=`expr $SIZE - 1` count=1
+dd if=/dev/zero of=$FATIMG bs=512 seek=`expr $FATSIZE - 1` count=1
+# Make an ms-dos FS on it
+$PREFIX/bin/newfs_msdos -r 1 -m 0xf8 -c 4 -F16 -h 64 -u 32 -S 512 -s $FATSIZE -o 0 ./$FATIMG
# Prepare the executable.
base=`basename $executable`
@@ -78,7 +73,7 @@ $PREFIX/bin/mcopy -bsp -i $FATIMG $TMPDIR/$app ::$app
$PREFIX/bin/mcopy -bsp -i $FATIMG $TMPDIR/$UENV ::$UENV
# Just a single FAT partition (type C) that uses all of the image
-$PREFIX/bin/partition $IMG $OFFSET 'c:0*+'
+$PREFIX/bin/partition -m $IMG $OFFSET c:${FATSIZE}\*
# Put the FAT image into the SD image
dd if=$FATIMG of=$IMG seek=$OFFSET
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
new file mode 100644
index 0000000..4b5ea73
--- /dev/null
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -0,0 +1,276 @@
+ * Copyright (c) 2012 Claas Ziemke. All rights reserved.
+ * Claas Ziemke
+ * Kernerstrasse 11
+ * 70182 Stuttgart
+ * Germany
+ * <claas.ziemke at gmx.net>
+ * http://www.rtems.com/license/LICENSE.
+ * Modified by Ben Gras <beng at shrike-systems.com> to add lots
+ * of beagleboard/beaglebone definitions, delete lpc32xx specific
+ * ones, and merge with some other header files.
+/* Interrupt controller memory map */
+#define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
+#define OMAP3_AM335X_INTR_BASE 0x48200000 /* INTCPS physical address */
+#define AM335X_INT_EMUINT 0
+ /* Emulation interrupt (EMUICINTR) */
+#define AM335X_INT_COMMTX 1
+ /* CortexA8 COMMTX */
+#define AM335X_INT_COMMRX 2
+ /* CortexA8 COMMRX */
+#define AM335X_INT_BENCH 3
+ /* CortexA8 NPMUIRQ */
+#define AM335X_INT_ELM_IRQ 4
+ /* Sinterrupt (Error location process completion) */
+#define AM335X_INT_NMI 7
+ /* nmi_int */
+#define AM335X_INT_L3DEBUG 9
+ /* l3_FlagMux_top_FlagOut1 */
+#define AM335X_INT_L3APPINT 10
+ /* l3_FlagMux_top_FlagOut0 */
+#define AM335X_INT_PRCMINT 11
+ /* irq_mpu */
+#define AM335X_INT_EDMACOMPINT 12
+ /* tpcc_int_pend_po0 */
+#define AM335X_INT_EDMAMPERR 13
+ /* tpcc_mpint_pend_po */
+#define AM335X_INT_EDMAERRINT 14
+ /* tpcc_errint_pend_po */
+#define AM335X_INT_ADC_TSC_GENINT 16
+ /* gen_intr_pend */
+#define AM335X_INT_USBSSINT 17
+ /* usbss_intr_pend */
+#define AM335X_INT_USB0 18
+ /* usb0_intr_pend */
+#define AM335X_INT_USB1 19
+ /* usb1_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT0 20
+ /* pr1_host_intr0_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT1 21
+ /* pr1_host_intr1_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT2 22
+ /* pr1_host_intr2_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT3 23
+ /* pr1_host_intr3_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT4 24
+ /* pr1_host_intr4_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT5 25
+ /* pr1_host_intr5_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT6 26
+ /* pr1_host_intr6_intr_pend */
+#define AM335X_INT_PRUSS1_EVTOUT7 27
+ /* pr1_host_intr7_intr_pend */
+#define AM335X_INT_MMCSD1INT 28
+ /* MMCSD1 SINTERRUPTN */
+#define AM335X_INT_MMCSD2INT 29
+ /* MMCSD2 SINTERRUPT */
+#define AM335X_INT_I2C2INT 30
+ /* I2C2 POINTRPEND */
+#define AM335X_INT_eCAP0INT 31
+ /* ecap_intr_intr_pend */
+#define AM335X_INT_GPIOINT2A 32
+ /* GPIO 2 POINTRPEND1 */
+#define AM335X_INT_GPIOINT2B 33
+ /* GPIO 2 POINTRPEND2 */
+#define AM335X_INT_USBWAKEUP 34
+ /* USBSS slv0p_Swakeup */
+#define AM335X_INT_LCDCINT 36
+ /* LCDC lcd_irq */
+#define AM335X_INT_GFXINT 37
+ /* SGX530 THALIAIRQ */
+#define AM335X_INT_ePWM2INT 39
+ /* (PWM Subsystem) epwm_intr_intr_pend */
+#define AM335X_INT_3PGSWRXTHR0 40
+ /* (Ethernet) c0_rx_thresh_pend (RX_THRESH_PULSE) */
+#define AM335X_INT_3PGSWRXINT0 41
+ /* CPSW (Ethernet) c0_rx_pend */
+#define AM335X_INT_3PGSWTXINT0 42
+ /* CPSW (Ethernet) c0_tx_pend */
+#define AM335X_INT_3PGSWMISC0 43
+ /* CPSW (Ethernet) c0_misc_pend */
+#define AM335X_INT_UART3INT 44
+ /* UART3 niq */
+#define AM335X_INT_UART4INT 45
+ /* UART4 niq */
+#define AM335X_INT_UART5INT 46
+ /* UART5 niq */
+#define AM335X_INT_eCAP1INT 47
+ /* (PWM Subsystem) ecap_intr_intr_pend */
+#define AM335X_INT_DCAN0_INT0 52
+ /* DCAN0 dcan_intr0_intr_pend */
+#define AM335X_INT_DCAN0_INT1 53
+ /* DCAN0 dcan_intr1_intr_pend */
+#define AM335X_INT_DCAN0_PARITY 54
+ /* DCAN0 dcan_uerr_intr_pend */
+#define AM335X_INT_DCAN1_INT0 55
+ /* DCAN1 dcan_intr0_intr_pend */
+#define AM335X_INT_DCAN1_INT1 56
+ /* DCAN1 dcan_intr1_intr_pend */
+#define AM335X_INT_DCAN1_PARITY 57
+ /* DCAN1 dcan_uerr_intr_pend */
+#define AM335X_INT_ePWM0_TZINT 58
+ /* eHRPWM0 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
+#define AM335X_INT_ePWM1_TZINT 59
+ /* eHRPWM1 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
+#define AM335X_INT_ePWM2_TZINT 60
+ /* eHRPWM2 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
+#define AM335X_INT_eCAP2INT 61
+ /* eCAP2 (PWM Subsystem) ecap_intr_intr_pend */
+#define AM335X_INT_GPIOINT3A 62
+ /* GPIO 3 POINTRPEND1 */
+#define AM335X_INT_GPIOINT3B 63
+ /* GPIO 3 POINTRPEND2 */
+#define AM335X_INT_MMCSD0INT 64
+ /* MMCSD0 SINTERRUPTN */
+#define AM335X_INT_SPI0INT 65
+ /* McSPI0 SINTERRUPTN */
+#define AM335X_INT_TINT0 66
+ /* Timer0 POINTR_PEND */
+#define AM335X_INT_TINT1_1MS 67
+ /* DMTIMER_1ms POINTR_PEND */
+#define AM335X_INT_TINT2 68
+ /* DMTIMER2 POINTR_PEND */
+#define AM335X_INT_TINT3 69
+ /* DMTIMER3 POINTR_PEND */
+#define AM335X_INT_I2C0INT 70
+ /* I2C0 POINTRPEND */
+#define AM335X_INT_I2C1INT 71
+ /* I2C1 POINTRPEND */
+#define AM335X_INT_UART0INT 72
+ /* UART0 niq */
+#define AM335X_INT_UART1INT 73
+ /* UART1 niq */
+#define AM335X_INT_UART2INT 74
+ /* UART2 niq */
+#define AM335X_INT_RTCINT 75
+ /* RTC timer_intr_pend */
+#define AM335X_INT_RTCALARMINT 76
+ /* RTC alarm_intr_pend */
+#define AM335X_INT_MBINT0 77
+ /* Mailbox0 (mail_u0_irq) initiator_sinterrupt_q_n */
+#define AM335X_INT_M3_TXEV 78
+ /* Wake M3 Subsystem TXEV */
+#define AM335X_INT_eQEP0INT 79
+ /* eQEP0 (PWM Subsystem) eqep_intr_intr_pend */
+#define AM335X_INT_MCATXINT0 80
+ /* McASP0 mcasp_x_intr_pend */
+#define AM335X_INT_MCARXINT0 81
+ /* McASP0 mcasp_r_intr_pend */
+#define AM335X_INT_MCATXINT1 82
+ /* McASP1 mcasp_x_intr_pend */
+#define AM335X_INT_MCARXINT1 83
+ /* McASP1 mcasp_r_intr_pend */
+#define AM335X_INT_ePWM0INT 86
+#define AM335X_INT_ePWM1INT 87
+#define AM335X_INT_eQEP1INT 88
+ /* (PWM Subsystem) eqep_intr_intr_pend */
+#define AM335X_INT_eQEP2INT 89
+#define AM335X_INT_DMA_INTR_PIN2 90
+ /* External DMA/Interrupt Pin2 */
+#define AM335X_INT_WDT1INT 91
+ /* (Public Watchdog) WDTIMER1 PO_INT_PEND */
+#define AM335X_INT_TINT4 92
+ /* DMTIMER4 POINTR_PEN */
+#define AM335X_INT_TINT5 93
+ /* DMTIMER5 POINTR_PEN */
+#define AM335X_INT_TINT6 94
+ /* DMTIMER6 POINTR_PEND */
+#define AM335X_INT_TINT7 95
+ /* DMTIMER7 POINTR_PEND */
+#define AM335X_INT_GPIOINT0A 96
+ /* GPIO 0 POINTRPEND1 */
+#define AM335X_INT_GPIOINT0B 97
+ /* GPIO 0 POINTRPEND2 */
+#define AM335X_INT_GPIOINT1A 98
+ /* GPIO 1 POINTRPEND1 */
+#define AM335X_INT_GPIOINT1B 99
+ /* GPIO 1 POINTRPEND2 */
+#define AM335X_INT_GPMCINT 100
+ /* GPMC gpmc_sinterrupt */
+#define AM335X_INT_DDRERR0 101
+ /* EMIF sys_err_intr_pend */
+#define AM335X_INT_TCERRINT0 112
+ /* TPTC0 tptc_erint_pend_po */
+#define AM335X_INT_TCERRINT1 113
+ /* TPTC1 tptc_erint_pend_po */
+#define AM335X_INT_TCERRINT2 114
+ /* TPTC2 tptc_erint_pend_po */
+#define AM335X_INT_ADC_TSC_PENINT 115
+ /* ADC_TSC pen_intr_pend */
+#define AM335X_INT_SMRFLX_Sabertooth 120
+ /* Smart Reflex 0 intrpen */
+#define AM335X_INT_SMRFLX_Core 121
+ /* Smart Reflex 1 intrpend */
+#define AM335X_INT_DMA_INTR_PIN0 123
+ /* pi_x_dma_event_intr0 (xdma_event_intr0) */
+#define AM335X_INT_DMA_INTR_PIN1 124
+ /* pi_x_dma_event_intr1 (xdma_event_intr1) */
+#define AM335X_INT_SPI1INT 125
+ /* McSPI1 SINTERRUPTN */
+#define OMAP3_AM335X_NR_IRQ_VECTORS 125
+#define AM335X_DMTIMER0_BASE 0x44E05000
+ /* DMTimer0 Registers */
+#define AM335X_DMTIMER1_1MS_BASE 0x44E31000
+ /* DMTimer1 1ms Registers (Accurate 1ms timer) */
+#define AM335X_DMTIMER2_BASE 0x48040000
+ /* DMTimer2 Registers */
+#define AM335X_DMTIMER3_BASE 0x48042000
+ /* DMTimer3 Registers */
+#define AM335X_DMTIMER4_BASE 0x48044000
+ /* DMTimer4 Registers */
+#define AM335X_DMTIMER5_BASE 0x48046000
+ /* DMTimer5 Registers */
+#define AM335X_DMTIMER6_BASE 0x48048000
+ /* DMTimer6 Registers */
+#define AM335X_DMTIMER7_BASE 0x4804A000
+ /* DMTimer7 Registers */
+/* General-purpose timer registers
+ AM335x non 1MS timers have different offsets */
+#define AM335X_TIMER_TIDR 0x000
+ /* IP revision code */
+#define AM335X_TIMER_TIOCP_CFG 0x010
+ /* Controls params for GP timer L4 interface */
+#define AM335X_TIMER_IRQSTATUS_RAW 0x024
+ /* Timer IRQSTATUS Raw Register */
+#define AM335X_TIMER_IRQSTATUS 0x028
+ /* Timer IRQSTATUS Register */
+#define AM335X_TIMER_IRQENABLE_SET 0x02C
+ /* Timer IRQENABLE Set Register */
+#define AM335X_TIMER_IRQENABLE_CLR 0x030
+ /* Timer IRQENABLE Clear Register */
+#define AM335X_TIMER_IRQWAKEEN 0x034
+ /* Timer IRQ Wakeup Enable Register */
+#define AM335X_TIMER_TCLR 0x038
+ /* Controls optional features */
+#define AM335X_TIMER_TCRR 0x03C
+ /* Internal counter value */
+#define AM335X_TIMER_TLDR 0x040
+ /* Timer load value */
+#define AM335X_TIMER_TTGR 0x044
+ /* Triggers counter reload */
+#define AM335X_TIMER_TWPS 0x048
+ /* Indicates if Write-Posted pending */
+#define AM335X_TIMER_TMAR 0x04C
+ /* Value to be compared with counter */
+#define AM335X_TIMER_TCAR1 0x050
+ /* First captured value of counter register */
+#define AM335X_TIMER_TSICR 0x054
+ /* Control posted mode and functional SW reset */
+#define AM335X_TIMER_TCAR2 0x058
+ /* Second captured value of counter register */
diff --git a/c/src/lib/libcpu/arm/shared/include/omap3.h b/c/src/lib/libcpu/arm/shared/include/omap3.h
index 0000000..2c044a1
--- /dev/null
+++ b/c/src/lib/libcpu/arm/shared/include/omap3.h
@@ -0,0 +1,377 @@
+ * Claas Ziemke
+ * 70182 Stuttgart
+ * Germany
+/* Interrupt controller registers */
+#define OMAP3_INTCPS_REVISION 0x000 /* IP revision code */
+#define OMAP3_INTCPS_SYSCONFIG 0x010 /* Controls params */
+#define OMAP3_INTCPS_SYSSTATUS 0x014 /* Status */
+#define OMAP3_INTCPS_SIR_IRQ 0x040 /* Active IRQ number */
+#define OMAP3_INTCPS_SIR_FIQ 0x044 /* Active FIQ number */
+#define OMAP3_INTCPS_CONTROL 0x048 /* New int agreement bits */
+#define OMAP3_INTCPS_PROTECTION 0x04C /* Protection for other regs */
+#define OMAP3_INTCPS_IDLE 0x050 /* Clock auto-idle/gating */
+#define OMAP3_INTCPS_IRQ_PRIORITY 0x060 /* Active IRQ priority level */
+#define OMAP3_INTCPS_FIQ_PRIORITY 0x064 /* Active FIQ priority level */
+#define OMAP3_INTCPS_THRESHOLD 0x068 /* Priority threshold */
+#define OMAP3_INTCPS_ITR0 0x080 /* Raw pre-masking interrupt status */
+#define OMAP3_INTCPS_MIR0 0x084 /* Interrupt mask */
+#define OMAP3_INTCPS_MIR1 0x0A4 /* Interrupt mask */
+#define OMAP3_INTCPS_MIR2 0x0C4 /* Interrupt mask */
+#define OMAP3_INTCPS_MIR3 0x0E4 /* Interrupt mask */
+#define OMAP3_INTCPS_MIR_CLEAR0 0x088 /* Clear interrupt mask bits */
+#define OMAP3_INTCPS_MIR_SET0 0x08C /* Set interrupt mask bits */
+#define OMAP3_INTCPS_ISR_SET0 0x090 /* Set software int bits */
+#define OMAP3_INTCPS_ISR_CLEAR0 0x094 /* Clear software int bits */
+#define OMAP3_INTCPS_PENDING_IRQ0 0x098 /* IRQ status post-masking */
+#define OMAP3_INTCPS_PENDING_IRQ1 0x0b8 /* IRQ status post-masking */
+#define OMAP3_INTCPS_PENDING_IRQ2 0x0d8 /* IRQ status post-masking */
+#define OMAP3_INTCPS_PENDING_IRQ3 0x0f8 /* IRQ status post-masking */
+#define OMAP3_INTCPS_PENDING_FIQ0 0x09C /* FIQ status post-masking */
+#define OMAP3_INTCPS_ILR0 0x100 /* Priority for interrupts */
+/* SYSCONFIG */
+#define OMAP3_SYSCONFIG_AUTOIDLE 0x01 /* SYSCONFIG.AUTOIDLE bit */
+#define OMAP3_INTR_ITR(base,n) \
+ (base + OMAP3_INTCPS_ITR0 + 0x20 * (n))
+#define OMAP3_INTR_MIR(base,n) \
+ (base + OMAP3_INTCPS_MIR0 + 0x20 * (n))
+#define OMAP3_INTR_MIR_CLEAR(base,n) \
+ (base + OMAP3_INTCPS_MIR_CLEAR0 + 0x20 * (n))
+#define OMAP3_INTR_MIR_SET(base,n) \
+ (base + OMAP3_INTCPS_MIR_SET0 + 0x20 * (n))
+#define OMAP3_INTR_ISR_SET(base,n) \
+ (base + OMAP3_INTCPS_ISR_SET0 + 0x20 * (n))
+#define OMAP3_INTR_ISR_CLEAR(base,n) \
+ (base + OMAP3_INTCPS_ISR_CLEAR0 + 0x20 * (n))
+#define OMAP3_INTR_PENDING_IRQ(base,n) \
+ (base + OMAP3_INTCPS_PENDING_IRQ0 + 0x20 * (n))
+#define OMAP3_INTR_PENDING_FIQ(base,n) \
+ (base + OMAP3_INTCPS_PENDING_FIQ0 + 0x20 * (n))
+#define OMAP3_INTR_ILR(base,m) \
+ (base + OMAP3_INTCPS_ILR0 + 0x4 * (m))
+#define OMAP3_INTR_ACTIVEIRQ_MASK 0x7f /* Active IRQ mask for SIR_IRQ */
+#define OMAP3_INTR_NEWIRQAGR 0x1 /* New IRQ Generation */
+#define OMAP3_DM337X_NR_IRQ_VECTORS 96
+/* Interrupt mappings */
+#define OMAP3_MCBSP2_ST_IRQ 4 /* Sidestone McBSP2 overflow */
+#define OMAP3_MCBSP3_ST_IRQ 5 /* Sidestone McBSP3 overflow */
+#define OMAP3_SYS_NIRQ 7 /* External source (active low) */
+#define OMAP3_SMX_DBG_IRQ 9 /* L3 interconnect error for debug */
+#define OMAP3_SMX_APP_IRQ 10 /* L3 interconnect error for application */
+#define OMAP3_PRCM_IRQ 11 /* PRCM module */
+#define OMAP3_SDMA0_IRQ 12 /* System DMA request 0 */
+#define OMAP3_SDMA1_IRQ 13 /* System DMA request 1 */
+#define OMAP3_SDMA2_IRQ 14 /* System DMA request 2 */
+#define OMAP3_SDMA3_IRQ 15 /* System DMA request 3 */
+#define OMAP3_MCBSP1_IRQ 16 /* McBSP module 1 */
+#define OMAP3_MCBSP2_IRQ 17 /* McBSP module 2 */
+#define OMAP3_GPMC_IRQ 20 /* General-purpose memory controller */
+#define OMAP3_SGX_IRQ 21 /* 2D/3D graphics module */
+#define OMAP3_MCBSP3_IRQ 22 /* McBSP module 3 */
+#define OMAP3_MCBSP4_IRQ 23 /* McBSP module 4 */
+#define OMAP3_CAM0_IRQ 24 /* Camera interface request 0 */
+#define OMAP3_DSS_IRQ 25 /* Display subsystem module */
+#define OMAP3_MAIL_U0_IRQ 26 /* Mailbox user 0 request */
+#define OMAP3_MCBSP5_IRQ 27 /* McBSP module 5 */
+#define OMAP3_IVA2_MMU_IRQ 28 /* IVA2 MMU */
+#define OMAP3_GPIO1_IRQ 29 /* GPIO module 1 */
+#define OMAP3_GPIO2_IRQ 30 /* GPIO module 2 */
+#define OMAP3_GPIO3_IRQ 31 /* GPIO module 3 */
+#define OMAP3_GPIO4_IRQ 32 /* GPIO module 4 */
+#define OMAP3_GPIO5_IRQ 33 /* GPIO module 5 */
+#define OMAP3_GPIO6_IRQ 34 /* GPIO module 6 */
+#define OMAP3_WDT3_IRQ 36 /* Watchdog timer module 3 overflow */
+#define OMAP3_GPT1_IRQ 37 /* General-purpose timer module 1 */
+#define OMAP3_GPT2_IRQ 38 /* General-purpose timer module 2 */
+#define OMAP3_GPT3_IRQ 39 /* General-purpose timer module 3 */
+#define OMAP3_GPT4_IRQ 40 /* General-purpose timer module 4 */
+#define OMAP3_GPT5_IRQ 41 /* General-purpose timer module 5 */
+#define OMAP3_GPT6_IRQ 42 /* General-purpose timer module 6 */
+#define OMAP3_GPT7_IRQ 43 /* General-purpose timer module 7 */
+#define OMAP3_GPT8_IRQ 44 /* General-purpose timer module 8 */
+#define OMAP3_GPT9_IRQ 45 /* General-purpose timer module 9 */
+#define OMAP3_GPT10_IRQ 46 /* General-purpose timer module 10 */
+#define OMAP3_GPT11_IRQ 47 /* General-purpose timer module 11 */
+#define OMAP3_SPI4_IRQ 48 /* McSPI module 4 */
+#define OMAP3_MCBSP4_TX_IRQ 54 /* McBSP module 4 transmit */
+#define OMAP3_MCBSP4_RX_IRQ 55 /* McBSP module 4 receive */
+#define OMAP3_I2C1_IRQ 56 /* I2C module 1 */
+#define OMAP3_I2C2_IRQ 57 /* I2C module 2 */
+#define OMAP3_HDQ_IRQ 58 /* HDQ/1-Wire */
+#define OMAP3_MCBSP1_TX_IRQ 59 /* McBSP module 1 transmit */
+#define OMAP3_MCBSP1_RX_IRQ 60 /* McBSP module 1 receive */
+#define OMAP3_I2C3_IRQ 61 /* I2C module 3 */
+#define OMAP3_MCBSP2_TX_IRQ 62 /* McBSP module 2 transmit */
+#define OMAP3_MCBSP2_RX_IRQ 63 /* McBSP module 2 receive */
+#define OMAP3_SPI1_IRQ 65 /* McSPI module 1 */
+#define OMAP3_SPI2_IRQ 66 /* McSPI module 2 */
+#define OMAP3_UART1_IRQ 72 /* UART module 1 */
+#define OMAP3_UART2_IRQ 73 /* UART module 2 */
+#define OMAP3_UART3_IRQ 74 /* UART module 3 */
+#define OMAP3_PBIAS_IRQ 75 /* Merged interrupt for PBIASlite 1/2 */
+#define OMAP3_OHCI_IRQ 76 /* OHCI HSUSB MP Host Interrupt */
+#define OMAP3_EHCI_IRQ 77 /* EHCI HSUSB MP Host Interrupt */
+#define OMAP3_TLL_IRQ 78 /* HSUSB MP TLL Interrupt */
+#define OMAP3_MCBSP5_TX_IRQ 81 /* McBSP module 5 transmit */
+#define OMAP3_MCBSP5_RX_IRQ 82 /* McBSP module 5 receive */
+#define OMAP3_MMC1_IRQ 83 /* MMC/SD module 1 */
+#define OMAP3_MMC2_IRQ 86 /* MMC/SD module 2 */
+#define OMAP3_ICR_IRQ 87 /* MPU ICR */
+#define OMAP3_D2DFRINT_IRQ 88 /* 3G coproc (in stacked modem config) */
+#define OMAP3_MCBSP3_TX_IRQ 89 /* McBSP module 3 transmit */
+#define OMAP3_MCBSP3_RX_IRQ 90 /* McBSP module 3 receive */
+#define OMAP3_SPI3_IRQ 91 /* McSPI module 3 */
+#define OMAP3_HSUSB_MC_IRQ 92 /* High-speed USB OTG */
+#define OMAP3_HSUSB_DMA_IRQ 93 /* High-speed USB OTG DMA */
+#define OMAP3_MMC3_IRQ 94 /* MMC/SD module 3 */
+/* General-purpose timer register map */
+#define OMAP3_GPTIMER1_BASE 0x48318000
+ /* GPTIMER1 physical address */
+#define OMAP3_GPTIMER2_BASE 0x49032000
+ /* GPTIMER2 physical address */
+#define OMAP3_GPTIMER3_BASE 0x49034000
+ /* GPTIMER3 physical address */
+#define OMAP3_GPTIMER4_BASE 0x49036000
+ /* GPTIMER4 physical address */
+#define OMAP3_GPTIMER5_BASE 0x49038000
+ /* GPTIMER5 physical address */
+#define OMAP3_GPTIMER6_BASE 0x4903A000
+ /* GPTIMER6 physical address */
+#define OMAP3_GPTIMER7_BASE 0x4903C000
+ /* GPTIMER7 physical address */
+#define OMAP3_GPTIMER8_BASE 0x4903E000
+ /* GPTIMER8 physical address */
+#define OMAP3_GPTIMER9_BASE 0x49040000
+ /* GPTIMER9 physical address */
+#define OMAP3_GPTIMER10_BASE 0x48086000
+ /* GPTIMER10 physical address */
+#define OMAP3_GPTIMER11_BASE 0x48088000
+ /* GPTIMER11 physical address */
+/* General-purpose timer registers */
+#define OMAP3_TIMER_TIDR 0x000
+#define OMAP3_TIMER_TIOCP_CFG 0x010
+ /* Controls params for GP timer L4 iface */
+#define OMAP3_TIMER_TISTAT 0x014
+ /* Status (excl. interrupt status) */
+#define OMAP3_TIMER_TISR 0x018
+ /* Pending interrupt status */
+#define OMAP3_TIMER_TIER 0x01C
+ /* Interrupt enable */
+#define OMAP3_TIMER_TWER 0x020
+ /* Wakeup enable */
+#define OMAP3_TIMER_TCLR 0x024
+#define OMAP3_TIMER_TCRR 0x028
+#define OMAP3_TIMER_TLDR 0x02C
+#define OMAP3_TIMER_TTGR 0x030
+#define OMAP3_TIMER_TWPS 0x034
+#define OMAP3_TIMER_TMAR 0x038
+#define OMAP3_TIMER_TCAR1 0x03C
+ /* First captured value of counter reg */
+#define OMAP3_TIMER_TSICR 0x040
+ /* Control posted mode and functional SW rst */
+#define OMAP3_TIMER_TCAR2 0x044
+#define OMAP3_TIMER_TPIR 0x048
+ /* Positive increment (1 ms tick) */
+#define OMAP3_TIMER_TNIR 0x04C
+ /* Negative increment (1 ms tick) */
+#define OMAP3_TIMER_TCVR 0x050
+ /* Defines TCRR is sub/over-period (1 ms tick) */
+#define OMAP3_TIMER_TOCR 0x054
+ /* Masks tick interrupt */
+#define OMAP3_TIMER_TOWR 0x058
+ /* Number of masked overflow interrupts */
+/* Interrupt status register fields */
+#define OMAP3_TISR_MAT_IT_FLAG (1 << 0) /* Pending match interrupt status */
+#define OMAP3_TISR_OVF_IT_FLAG (1 << 1) /* Pending overflow interrupt status */
+#define OMAP3_TISR_TCAR_IT_FLAG (1 << 2) /* Pending capture interrupt status */
+/* Interrupt enable register fields */
+#define OMAP3_TIER_MAT_IT_ENA (1 << 0) /* Enable match interrupt */
+#define OMAP3_TIER_OVF_IT_ENA (1 << 1) /* Enable overflow interrupt */
+#define OMAP3_TIER_TCAR_IT_ENA (1 << 2) /* Enable capture interrupt */
+/* Timer control fields */
+#define OMAP3_TCLR_ST (1 << 0) /* Start/stop timer */
+#define OMAP3_TCLR_AR (1 << 1) /* Autoreload or one-shot mode */
+#define OMAP3_TCLR_PRE (1 << 5) /* Prescaler on */
+#define OMAP3_TCLR_PTV (1 << 1) /* looks like "bleed" from Minix */
+#define OMAP3_TCLR_OVF_TRG (1 << 10) /* Overflow trigger */
+#define OMAP3_CM_CLKSEL_GFX 0x48004b40
+#define OMAP3_CM_CLKEN_PLL 0x48004d00
+#define OMAP3_CM_FCLKEN1_CORE 0x48004A00
+#define OMAP3_CM_CLKSEL_CORE 0x48004A40 /* GPT10 src clock sel. */
+#define OMAP3_CM_FCLKEN_PER 0x48005000
+#define OMAP3_CM_CLKSEL_PER 0x48005040
+#define OMAP3_CM_CLKSEL_WKUP 0x48004c40 /* GPT1 source clock selection */
+#define CM_MODULEMODE_MASK (0x3 << 0)
+#define CM_MODULEMODE_ENABLE (0x2 << 0)
+#define CM_MODULEMODE_DISABLED (0x0 << 0)
+#define CM_CLKCTRL_IDLEST (0x3 << 16)
+#define CM_CLKCTRL_IDLEST_FUNC (0x0 << 16)
+#define CM_CLKCTRL_IDLEST_TRANS (0x1 << 16)
+#define CM_CLKCTRL_IDLEST_IDLE (0x2 << 16)
+#define CM_CLKCTRL_IDLEST_DISABLE (0x3 << 16)
+#define CM_WKUP_BASE 0x44E00400 /* Clock Module Wakeup Registers */
+#define CM_WKUP_TIMER1_CLKCTRL (CM_WKUP_BASE + 0xC4)
+ /* This register manages the TIMER1 clocks. [Memory Mapped] */
+#define CM_PER_BASE 0x44E00000 /* Clock Module Peripheral Registers */
+#define CM_PER_TIMER7_CLKCTRL (CM_PER_BASE + 0x7C)
+ /* This register manages the TIMER7 clocks. [Memory Mapped] */
+/* CM_DPLL registers */
+#define CM_DPLL_BASE 0x44E00500 /* Clock Module PLL Registers */
+#define CLKSEL_TIMER1MS_CLK (CM_DPLL_BASE + 0x28)
+#define CLKSEL_TIMER1MS_CLK_SEL_MASK (0x7 << 0)
+#define CLKSEL_TIMER1MS_CLK_SEL_SEL1 (0x0 << 0)
+ /* Select CLK_M_OSC clock */
+#define CLKSEL_TIMER1MS_CLK_SEL_SEL2 (0x1 << 0)
+ /* Select CLK_32KHZ clock */
+#define CLKSEL_TIMER1MS_CLK_SEL_SEL3 (0x2 << 0)
+ /* Select TCLKIN clock */
+#define CLKSEL_TIMER1MS_CLK_SEL_SEL4 (0x3 << 0)
+ /* Select CLK_RC32K clock */
+#define CLKSEL_TIMER1MS_CLK_SEL_SEL5 (0x4 << 0)
+ /* Selects the CLK_32768 from 32KHz Crystal Osc */
+#define CLKSEL_TIMER7_CLK (CM_DPLL_BASE + 0x04)
+#define CLKSEL_TIMER7_CLK_SEL_MASK (0x3 << 0)
+#define CLKSEL_TIMER7_CLK_SEL_SEL1 (0x0 << 0) /* Select TCLKIN clock */
+#define CLKSEL_TIMER7_CLK_SEL_SEL2 (0x1 << 0) /* Select CLK_M_OSC clock */
+#define CLKSEL_TIMER7_CLK_SEL_SEL3 (0x2 << 0) /* Select CLK_32KHZ clock */
+#define CLKSEL_TIMER7_CLK_SEL_SEL4 (0x3 << 0) /* Reserved */
+#define OMAP3_CLKSEL_GPT1 (1 << 0)
+#define OMAP3_CLKSEL_GPT10 (1 << 6)
+#define OMAP3_CLKSEL_GPT11 (1 << 7)
+#define OMAP34XX_CORE_L4_IO_BASE 0x48000000
+#define ARM_TTBR_ADDR_MASK (0xffffc000)
+#define ARM_TTBR_OUTER_NC (0x0 << 3) /* Non-cacheable*/
+#define ARM_TTBR_OUTER_WBWA (0x1 << 3) /* Outer Write-Back */
+#define ARM_TTBR_OUTER_WT (0x2 << 3) /* Outer Write-Through */
+#define ARM_TTBR_OUTER_WBNWA (0x3 << 3) /* Outer Write-Back */
+#define ARM_TTBR_FLAGS_CACHED ARM_TTBR_OUTER_WBWA
+/* cpu control flags */
+/* CPU control register (CP15 register 1) */
+#define CPU_CONTROL_MMU_ENABLE 0x00000001 /* M: MMU/Protection unit enable */
+#define CPU_CONTROL_AFLT_ENABLE 0x00000002 /* A: Alignment fault enable */
+#define CPU_CONTROL_DC_ENABLE 0x00000004 /* C: IDC/DC enable */
+#define CPU_CONTROL_WBUF_ENABLE 0x00000008 /* W: Write buffer enable */
+#define CPU_CONTROL_32BP_ENABLE 0x00000010 /* P: 32-bit exception handlers */
+#define CPU_CONTROL_32BD_ENABLE 0x00000020 /* D: 32-bit addressing */
+#define CPU_CONTROL_LABT_ENABLE 0x00000040 /* L: Late abort enable */
+#define CPU_CONTROL_BEND_ENABLE 0x00000080 /* B: Big-endian mode */
+#define CPU_CONTROL_SYST_ENABLE 0x00000100 /* S: System protection bit */
+#define CPU_CONTROL_ROM_ENABLE 0x00000200 /* R: ROM protection bit */
+#define CPU_CONTROL_CPCLK 0x00000400 /* F: Implementation defined */
+#define CPU_CONTROL_SWP_ENABLE 0x00000400 /* SW: SWP{B} perform normally. */
+#define CPU_CONTROL_BPRD_ENABLE 0x00000800 /* Z: Branch prediction enable */
+#define CPU_CONTROL_IC_ENABLE 0x00001000 /* I: IC enable */
+#define CPU_CONTROL_VECRELOC 0x00002000 /* V: Vector relocation */
+#define CPU_CONTROL_ROUNDROBIN 0x00004000 /* RR: Predictable replacement */
+#define CPU_CONTROL_V4COMPAT 0x00008000 /* L4: ARMv4 compat LDR R15 etc */
+#define CPU_CONTROL_FI_ENABLE 0x00200000 /* FI: Low interrupt latency */
+#define CPU_CONTROL_UNAL_ENABLE 0x00400000 /* U: unaligned data access */
+#define CPU_CONTROL_XP_ENABLE 0x00800000 /* XP: extended page table */
+#define CPU_CONTROL_V_ENABLE 0x01000000 /* VE: Interrupt vectors enable */
+#define CPU_CONTROL_EX_BEND 0x02000000 /* EE: exception endianness */
+#define CPU_CONTROL_NMFI 0x08000000 /* NMFI: Non maskable FIQ */
+#define CPU_CONTROL_TR_ENABLE 0x10000000 /* TRE: */
+#define CPU_CONTROL_AF_ENABLE 0x20000000 /* AFE: Access flag enable */
+#define CPU_CONTROL_TE_ENABLE 0x40000000 /* TE: Thumb Exception enable */
+#define CPU_CONTROL_IDC_ENABLE CPU_CONTROL_DC_ENABLE
+/* VM bits */
+/* Big page (1MB section) specific flags. */
+#define ARM_VM_SECTION (1 << 1)
+ /* 1MB section */
+#define ARM_VM_SECTION_PRESENT (1 << 1)
+ /* Section is present */
+#define ARM_VM_SECTION_B (1 << 2)
+ /* B Bit */
+#define ARM_VM_SECTION_C (1 << 3)
+ /* C Bit */
+#define ARM_VM_SECTION_DOMAIN (0xF << 5)
+ /* Domain Number */
+#define ARM_VM_SECTION_SUPER (0x1 << 10)
+ /* Super access only AP[1:0] */
+#define ARM_VM_SECTION_USER (0x3 << 10)
+ /* Super/User access AP[1:0] */
+#define ARM_VM_SECTION_TEX0 (1 << 12)
+ /* TEX[0] */
+#define ARM_VM_SECTION_TEX1 (1 << 13)
+ /* TEX[1] */
+#define ARM_VM_SECTION_TEX2 (1 << 14)
+ /* TEX[2] */
+#define ARM_VM_SECTION_RO (1 << 15)
+ /* Read only access AP[2] */
+#define ARM_VM_SECTION_SHAREABLE (1 << 16)
+ /* Shareable */
+#define ARM_VM_SECTION_NOTGLOBAL (1 << 17)
+ /* Not Global */
+#define ARM_VM_SECTION_WB \
+ (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX0 | ARM_VM_SECTION_B )
+/* inner and outer write-back, write-allocate */
+#define ARM_VM_SECTION_WT \
+ (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX1 | ARM_VM_SECTION_C )
+/* inner and outer write-through, no write-allocate */
+#define ARM_VM_SECTION_WTWB \
+ (ARM_VM_SECTION_TEX2 | ARM_VM_SECTION_TEX0 | ARM_VM_SECTION_C )
+/* Inner , Write through, No Write Allocate Outer - Write Back, Write Allocate */
+/* shareable device */
+#define ARM_VM_SECTION_CACHED ARM_VM_SECTION_WTWB
+#define ARM_VM_SECTION_DEVICE (ARM_VM_SECTION_B)
diff --git a/c/src/lib/libcpu/arm/shared/include/omap_timer.h b/c/src/lib/libcpu/arm/shared/include/omap_timer.h
index 0000000..47310b1
--- /dev/null
+++ b/c/src/lib/libcpu/arm/shared/include/omap_timer.h
@@ -0,0 +1,40 @@
+ * @file
+ * @brief Clock driver configuration.
+#include <stdint.h>
+typedef struct omap_timer_registers
+ uint32_t TIDR;
+ uint32_t TIOCP_CFG;
+ uint32_t TISTAT;
+ uint32_t TISR;
+ uint32_t TIER;
+ uint32_t TWER;
+ uint32_t TCLR;
+ uint32_t TCRR;
+ uint32_t TLDR;
+ uint32_t TTGR;
+ uint32_t TWPS;
+ uint32_t TMAR;
+ uint32_t TCAR1;
+ uint32_t TSICR;
+ uint32_t TCAR2;
+ uint32_t TPIR;
+ uint32_t TNIR;
+ uint32_t TCVR;
+ uint32_t TOCR;
+ uint32_t TOWR;
+} omap_timer_registers_t;
+ uint32_t base;
+ int irq_nr;
+ struct omap_timer_registers *regs;
+} omap_timer_t;
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141103/bcb80061/attachment-0003.bin>
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141103/bcb80061/attachment-0004.bin>
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141103/bcb80061/attachment-0005.bin>
