lm32 rtl-error.c causes gcc ICE
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Nov  3 21:25:06 UTC 2014
Hi
I suppose this needs to be narrowed down and fed into gcc's bugzilla.
But I wanted to here from Chris first.
lm32-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I..
-I../../cpukit/../../../lm32_evr/lib/include -DRTEMS_RTL_RAP_LOADER=1
-DRTEMS_RTL_ELF_LOADER=1   -O0 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
libdl_a-rtl-obj.o -MD -MP -MF .deps/libdl_a-rtl-obj.Tpo -c -o
libdl_a-rtl-obj.o `test -f 'rtl-obj.c' || echo
'../../../../../../rtems/c/src/../../cpukit/libdl/'`rtl-obj.c
0x70a8b5 _fatal_insn(char const*, rtx_def const*, char const*, int, char
const*)
    ../../gcc-4.9.1/gcc/rtl-error.c:109
0x70a8e9 _fatal_insn_not_found(rtx_def const*, char const*, int, char
const*)
    ../../gcc-4.9.1/gcc/rtl-error.c:117
0x93096e insn_default_length(rtx_def*)
/users/joel/rtems-4.11-work/rtems-source-builder/rtems/build/lm32-rtems4.11-gcc-4.9.1-newlib-19-Aug-2014-1/build/gcc/insn-attrtab.c:143
0x595e8a shorten_branches(rtx_def*)
    ../../gcc-4.9.1/gcc/final.c:1191
0x5962ef rest_of_handle_shorten_branches
    ../../gcc-4.9.1/gcc/final.c:4519
0x5962ef execute
    ../../gcc-4.9.1/gcc/final.c:4548
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <http://gcc.gnu.org/bugs.html> for instructions.
