[PATCH 1/4] capture: Move logging of task record to occur after filter check.
Jennifer Averett
jennifer.averett at oarcorp.com
Tue Nov 4 13:39:08 UTC 2014
The catpture task record is now logged just prior to the first
log entry using that task instead of the first time the task
is seen. This involved splitting the record task method into
an initialize task and a record task.
cpukit/libmisc/capture/capture.c | 39 +++++++++++++------
cpukit/libmisc/capture/capture.h | 24 +++++++++++-
cpukit/libmisc/capture/capture_user_extension.c | 51 +++++++++++++------------
3 files changed, 78 insertions(+), 36 deletions(-)
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 28fa1dd..a83bc90 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -313,26 +313,35 @@ rtems_capture_create_control (rtems_name name, rtems_id id)
return control;
-void rtems_capture_record_task( rtems_tcb* tcb )
+void rtems_capture_initialize_task( rtems_tcb* tcb )
rtems_capture_control_t* control;
- rtems_capture_task_record_t rec;
- void* ptr;
- rtems_object_get_classic_name( tcb->Object.id, &rec.name );
+ rtems_name name;
* We need to scan the default control list to initialise
* this control if it is a new task.
+ rtems_object_get_classic_name( tcb->Object.id, &name );
if (tcb->Capture.control == NULL) {
for (control = capture_controls; control != NULL; control = control->next)
if (rtems_capture_match_name_id (control->name, control->id,
- rec.name, tcb->Object.id))
+ name, tcb->Object.id))
tcb->Capture.control = control;
+ tcb->Capture.flags |= RTEMS_CAPTURE_INIT_TASK;
+void rtems_capture_record_task( rtems_tcb* tcb )
+ rtems_capture_task_record_t rec;
+ void* ptr;
+ rtems_object_get_classic_name( tcb->Object.id, &rec.name );
rec.stack_size = tcb->Start.Initial_stack.size;
rec.start_priority = _RTEMS_tasks_Priority_from_Core(
tcb->Start.initial_priority
@@ -1224,6 +1233,8 @@ rtems_capture_release (uint32_t count)
rtems_capture_record_t* rec;
uint32_t counted;
size_t ptr_size = 0;
+ size_t rel_size = 0;
+ rtems_status_code ret_val = RTEMS_SUCCESSFUL;
rtems_interrupt_lock_acquire (&capture_lock, &lock_context);
@@ -1237,26 +1248,32 @@ rtems_capture_release (uint32_t count)
ptr = rtems_capture_buffer_peek( &capture_records, &ptr_size );
_Assert(ptr_size >= (count * sizeof(*rec) ));
- ptr_size = 0;
+ rel_size = 0;
while (counted--)
rec = (rtems_capture_record_t*) ptr;
- ptr_size += rec->size;
+ rel_size += rec->size;
+ _Assert( rel_size <= ptr_size );
ptr += rec->size;
+ if (rel_size > ptr_size ) {
+ ret_val = RTEMS_INVALID_NUMBER;
+ rel_size = ptr_size;
capture_count -= count;
if (count)
- rtems_capture_buffer_free( &capture_records, ptr_size );
+ rtems_capture_buffer_free( &capture_records, rel_size );
capture_flags &= ~RTEMS_CAPTURE_READER_ACTIVE;
rtems_interrupt_lock_release (&capture_lock, &lock_context);
- return RTEMS_SUCCESSFUL;
+ return ret_val;
diff --git a/cpukit/libmisc/capture/capture.h b/cpukit/libmisc/capture/capture.h
index a4c3310..f907686 100644
--- a/cpukit/libmisc/capture/capture.h
+++ b/cpukit/libmisc/capture/capture.h
@@ -141,7 +141,8 @@ typedef struct rtems_capture_control_s
* Task flags.
#define RTEMS_CAPTURE_TRACED (1U << 0)
-#define RTEMS_CAPTURE_RECORD_TASK (1U << 1)
+#define RTEMS_CAPTURE_INIT_TASK (1U << 1)
+#define RTEMS_CAPTURE_RECORD_TASK (1U << 2)
* @brief Capture record.
@@ -598,6 +599,15 @@ const char*
rtems_capture_event_text (int event);
+ * @brief Capture initialize task
+ * This function initializes capture control in the tcb.
+ * @param[in] tcb is the task control block for the task
+void rtems_capture_initialize_task( rtems_tcb* tcb );
* @brief Capture record task.
* This function records a new capture task record.
@@ -619,6 +629,18 @@ static inline bool rtems_capture_task_recorded( rtems_tcb* tcb ) {
+ * @brief Capture task initialized
+ * This function returns true if this task information has been
+ * initialized.
+static inline bool rtems_capture_task_initialized( rtems_tcb* tcb ) {
+ return ( (tcb->Capture.flags & RTEMS_CAPTURE_INIT_TASK) != 0 );
* @brief Capture get task id.
* This function returns the task id.
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
index 4c7bc1d..69b8d48 100644
--- a/cpukit/libmisc/capture/capture_user_extension.c
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -95,6 +95,9 @@ static inline void rtems_capture_record (
if (rtems_capture_filter( tcb, events) )
return;
+ if (!rtems_capture_task_recorded (tcb))
+ rtems_capture_record_task (tcb);
rtems_capture_begin_add_record (tcb, events, size, &ptr);
rtems_capture_end_add_record ( ptr );
@@ -141,13 +144,13 @@ rtems_capture_create_task (rtems_tcb* ct,
* been created before the capture engine was open. Add them.
- if (!rtems_capture_task_recorded (ct))
- rtems_capture_record_task (ct);
+ if (!rtems_capture_task_initialized (ct))
+ rtems_capture_initialize_task (ct);
* Create the new task's capture control block.
- rtems_capture_record_task (nt);
+ rtems_capture_initialize_task (nt);
if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
@@ -170,11 +173,11 @@ rtems_capture_start_task (rtems_tcb* ct,
if (st == NULL)
- rtems_capture_record_task (st);
+ rtems_capture_initialize_task (st);
if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
@@ -195,11 +198,11 @@ rtems_capture_restart_task (rtems_tcb* ct,
- if (!rtems_capture_task_recorded (rt))
- rtems_capture_record_task (rt);
+ if (!rtems_capture_task_initialized (rt))
+ rtems_capture_initialize_task (rt);
if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
@@ -215,11 +218,11 @@ static void
rtems_capture_delete_task (rtems_tcb* ct,
rtems_tcb* dt)
- if (!rtems_capture_task_recorded (dt))
- rtems_capture_record_task (dt);
+ if (!rtems_capture_task_initialized (dt))
+ rtems_capture_initialize_task (dt);
if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
@@ -239,8 +242,8 @@ rtems_capture_begin_task (rtems_tcb* bt)
- if (!rtems_capture_task_recorded (bt))
- rtems_capture_record_task (bt);
+ if (!rtems_capture_task_initialized (bt))
+ rtems_capture_initialize_task (bt);
if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
@@ -258,8 +261,8 @@ rtems_capture_exitted_task (rtems_tcb* et)
- if (!rtems_capture_task_recorded (et))
- rtems_capture_record_task (et);
+ if (!rtems_capture_task_initialized (et))
+ rtems_capture_initialize_task (et);
if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
@@ -276,8 +279,8 @@ rtems_capture_terminated_task (rtems_tcb* tt)
- if (!rtems_capture_task_recorded (tt))
- rtems_capture_record_task (tt);
+ if (!rtems_capture_task_initialized (tt))
+ rtems_capture_initialize_task (tt);
if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
@@ -300,11 +303,11 @@ rtems_capture_switch_task (rtems_tcb* ct,
rtems_capture_time_t time;
- if (!rtems_capture_task_recorded (ht))
- rtems_capture_record_task (ht);
+ if (!rtems_capture_task_initialized (ht))
+ rtems_capture_initialize_task (ht);
* Update the execution time. Assume the time will not overflow
1.8.1.4
