[PATCH 4/4] smpcapture01: New test.
Jennifer Averett jennifer.averett at oarcorp.com
Tue Nov 4 13:39:11 UTC 2014
 testsuites/smptests/Makefile.am                   |   1 +
 testsuites/smptests/configure.ac                  |   1 +
 testsuites/smptests/smpcapture01/Makefile.am      |  19 ++
 testsuites/smptests/smpcapture01/init.c           | 273 ++++++++++++++++++++++
 testsuites/smptests/smpcapture01/smpcapture01.doc |  28 +++
 testsuites/smptests/smpcapture01/smpcapture01.scn |  45 ++++
 6 files changed, 367 insertions(+)
 create mode 100644 testsuites/smptests/smpcapture01/Makefile.am
 create mode 100644 testsuites/smptests/smpcapture01/init.c
 create mode 100644 testsuites/smptests/smpcapture01/smpcapture01.doc
 create mode 100644 testsuites/smptests/smpcapture01/smpcapture01.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 1e72d43..87c3d7f 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -12,6 +12,7 @@ SUBDIRS += smp09
 SUBDIRS += smpaffinity01
 SUBDIRS += smpatomic01
 SUBDIRS += smpcache01
+SUBDIRS += smpcapture01
 SUBDIRS += smpfatal01
 SUBDIRS += smpfatal02
 SUBDIRS += smpfatal03
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 9b6d99b..e7b96ae 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -67,6 +67,7 @@ smp09/Makefile
 smpaffinity01/Makefile
 smpatomic01/Makefile
 smpcache01/Makefile
+smpcapture01/Makefile
 smpfatal01/Makefile
 smpfatal02/Makefile
 smpfatal03/Makefile
diff --git a/testsuites/smptests/smpcapture01/Makefile.am b/testsuites/smptests/smpcapture01/Makefile.am
new file mode 100644
index 0000000..084f404
--- /dev/null
+++ b/testsuites/smptests/smpcapture01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpcapture01
+smpcapture01_SOURCES = init.c
+dist_rtems_tests_DATA = smpcapture01.scn smpcapture01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpcapture01_OBJECTS)
+LINK_LIBS = $(smpcapture01_LDLIBS)
+smpcapture01$(EXEEXT): $(smpcapture01_OBJECTS) $(smpcapture01_DEPENDENCIES)
+	@rm -f smpcapture01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index 0000000..f635efa
--- /dev/null
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -0,0 +1,273 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ * The init task UT1 should start on cpu 3 and has priority:affinity set
+ * 7:{2,3} The test creates 4 more tasks TA1 - TA4
+ * with priorty:affinity sets 8:{2,3}, 5:{0,1}, 6:{0,3}, and 9:{1}.
+ * This should result in cpu:task  0:TA3, 1:TA2, 2:TA1, 3:UT1 with
+ * TA4 waiting on a cpu.
+ * The test then raises the priority of TA4 to 4, resulting
+ * in the following cpu:task 0:TA2, 1:TA4, 2:UT1, 3:TA3 with
+ * TA1 waiting on a CPU.  The tasks are then terminated.
+ * The capture engine is set up read and report the results.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/captureimpl.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPCAPTURE 1";
+#define NUM_CPUS   4
+#define TASK_COUNT 5
+struct task_data_t {
+  rtems_id            id;
+  cpu_set_t           cpuset;
+  rtems_task_priority priority;
+  bool                ran;
+  int                 expected_cpu;
+  int                 actual_cpu;
+  int                 migrate_cpu;
+static struct task_data_t task_data[TASK_COUNT] = {
+  {0x0, {{0xc}}, 7, false,  3, -1,  2},
+  {0x0, {{0xf}}, 8, false,  2, -1, -1},
+  {0x0, {{0x3}}, 5, false,  1, -1,  0},
+  {0x0, {{0x9}}, 6, false,  0, -1,  3},
+  {0x0, {{0x2}}, 9, false, -1, -1,  1}
+rtems_id           task_sem;
+ * Spin loop to allow tasks to delay without yeilding the
+ * processor.
+static void test_delay(int ticks)
+  rtems_interval start, stop;
+  start = rtems_clock_get_ticks_since_boot();
+  do {
+    stop = rtems_clock_get_ticks_since_boot();
+  } while ( (stop - start) < ticks );
+static void task(rtems_task_argument arg)
+  rtems_status_code   sc;
+  while (true) {
+    sc = rtems_semaphore_obtain (task_sem, RTEMS_NO_WAIT, 0);
+    if (sc == RTEMS_SUCCESSFUL) {
+      task_data[arg].ran = true;
+      task_data[arg].actual_cpu = rtems_get_current_processor();
+      rtems_semaphore_release(task_sem);
+static void set_init_task(void)
+  while( rtems_semaphore_obtain (task_sem, RTEMS_NO_WAIT, 0) != RTEMS_SUCCESSFUL );
+  /* Set Init task data */
+  task_data[0].ran = true;
+  task_data[0].actual_cpu = rtems_get_current_processor();
+static void test(void)
+  rtems_task_argument i;
+  size_t              size;
+  uint32_t            cpu_count;
+  /* Get the number of processors that we are using. */
+  cpu_count = rtems_get_processor_count();
+  if (cpu_count != 4) {
+    printf("Test requires a minimum of 4 cores\n");
+    return;
+  size = sizeof(cpu_set_t);
+  task_data[0].id = rtems_task_self();
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'E', 'M', '0'),
+    1,                                               /* initial count = 1 */
+    RTEMS_LOCAL                   |
+    RTEMS_SIMPLE_BINARY_SEMAPHORE |
+    RTEMS_NO_INHERIT_PRIORITY     |
+    RTEMS_NO_PRIORITY_CEILING     |
+    RTEMS_FIFO,
+    0,
+    &task_sem
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_set_affinity(
+    task_data[ 0 ].id,
+    size,
+    &task_data[0].cpuset
+  /* Create and start tasks on each cpu with the appropriate affinity. */
+  for (i = 1; i < TASK_COUNT; i++) {
+      sc = rtems_task_create(
+        rtems_build_name('T', 'A', '0', '0'+i),
+        task_data[ i ].priority,
+        RTEMS_MINIMUM_STACK_SIZE,
+        RTEMS_DEFAULT_MODES,
+        RTEMS_DEFAULT_ATTRIBUTES,
+        &task_data[ i ].id
+        task_data[ i ].id,
+        size,
+        &task_data[i].cpuset
+      sc = rtems_task_start( task_data[ i ].id, task, i );
+  /* spin for 100 ticks */
+  test_delay(100);
+  set_init_task();
+  i = TASK_COUNT - 1;
+  task_data[ i ].priority = 4;
+  sc = rtems_task_set_priority(
+    &priority
+  test_delay(25);
+  for (i = 0; i < TASK_COUNT; i++) {
+    task_data[ i ].expected_cpu = task_data[ i ].migrate_cpu;
+    task_data[ i ].actual_cpu = -1;
+    task_data[ i ].ran = false;
+  test_delay(25);
+  set_init_task();
+    sc = rtems_task_delete( task_data[ i ].id );
+  test_delay(25);
+static void Init(rtems_task_argument arg)
+  rtems_name          to_name = rtems_build_name('I', 'D', 'L', 'E');;
+  uint32_t            i;
+  TEST_BEGIN();
+  sc = rtems_capture_open (5000, NULL);
+  sc = rtems_capture_watch_ceiling (0);
+  sc = rtems_capture_watch_floor (20);
+  sc = rtems_capture_watch_global (true);
+  sc = rtems_capture_set_trigger (
+    0,
+    0,
+    to_name,
+    0,
+    rtems_capture_from_any,
+    rtems_capture_switch
+     to_name = rtems_build_name('T', 'A', '0', '0'+i);
+      0,
+      0,
+      to_name,
+      0,
+  sc = rtems_capture_control (true);
+  test();
+  sc = rtems_capture_control (false);
+  rtems_capture_print_trace_records ( 22, false );
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_PRIORITY       7
+#define TASK_ALLOCATION_SIZE     (5)
+#define CONFIGURE_MAXIMUM_TASKS  rtems_resource_unlimited(TASK_ALLOCATION_SIZE)
+#define CONFIGURE_EXTRA_TASK_STACKS (75 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS (5)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpcapture01/smpcapture01.doc b/testsuites/smptests/smpcapture01/smpcapture01.doc
index 0000000..e16e321
--- /dev/null
+++ b/testsuites/smptests/smpcapture01/smpcapture01.doc
@@ -0,0 +1,28 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpcapture01
+directives:
+  rtems_capture_open
+  rtems_capture_watch_ceiling
+  rtems_capture_watch_floor
+  rtems_capture_watch_global
+  rtems_capture_set_trigger
+  rtems_capture_control
+concepts:
+ The init task UT1 should start on cpu 3 and has priority:affinity set
+ 7:{2,3} The test creates 4 more tasks TA1 - TA4
+ with priorty:affinity sets 8:{2,3}, 5:{0,1}, 6:{0,3}, and 9:{1}.
+ This should result in cpu:task  0:TA3, 1:TA2, 2:TA1, 3:UT1 with
+ TA4 waiting on a cpu.
+ The test then raises the priority of TA4 to 4, resulting
+ in the following cpu:task 0:TA2, 1:TA4, 2:UT1, 3:TA3 with
+ TA1 waiting on a CPU.  The tasks are then terminated.
+ The capture engine is set up read and report the results.  It should
+ show the task switches for a worst case migration of tasks.
diff --git a/testsuites/smptests/smpcapture01/smpcapture01.scn b/testsuites/smptests/smpcapture01/smpcapture01.scn
index 0000000..9f7c639
--- /dev/null
+++ b/testsuites/smptests/smpcapture01/smpcapture01.scn
@@ -0,0 +1,45 @@
+*** BEGIN OF TEST SMPCAPTURE 1 ***
+ 1     0:00:00.008653000            0a010003 TA02   5   5   5 4096  TASK_RECORD
+ 0     0:00:00.008659000            0a010004 TA03   6   6   6 4096  TASK_RECORD
+ 2     0:00:00.008663000            0a010002 TA01   8   8   8 4096  TASK_RECORD
+ 1     0:00:00.008681000          0 0a010003        5   5           SWITCHED_IN
+ 0     0:00:00.008686000          0 0a010004        6   6           SWITCHED_IN
+ 2     0:00:00.008691000          0 0a010002        8   8           SWITCHED_IN
+ 1     0:00:00.008734000      53000 0a010003        5   5           BEGIN
+ 0     0:00:00.008738000      52000 0a010004        6   6           BEGIN
+ 2     0:00:00.008743000      52000 0a010002        8   8           BEGIN
+ 3     0:00:00.008914000            0a010001 UI1    7   7   7 4096  TASK_RECORD
+ 3     0:00:00.008943000          0 0a010001        7   7           CREATED_BY
+ 3     0:00:00.009015000            0a010005 TA04   9   9   9 4096  TASK_RECORD
+ 3     0:00:00.009041000      98000 0a010005        9   9           CREATED
+ 3     0:00:00.009298000     257000 0a010001        7   7           STARTED_BY
+ 3     0:00:00.009326000      28000 0a010005        9   9           STARTED
+ 3     0:00:01.000432000  991106000 0a010001        7   7           SWITCHED_OUT
+ 1     0:00:01.000452000  991718000 0a010003        5   5           SWITCHED_OUT
+ 3     0:00:01.000456000      24000 0a010004        6   6           SWITCHED_IN
+ 0     0:00:01.000473000  991735000 0a010004        6   6           SWITCHED_OUT
+ 1     0:00:01.000476000      24000 0a010005        4   4           SWITCHED_IN
+ 2     0:00:01.000491000  991748000 0a010002        8   8           SWITCHED_OUT
+ 0     0:00:01.000496000      23000 0a010003        5   5           SWITCHED_IN
+ 2     0:00:01.000514000          0 0a010001        7   7           SWITCHED_IN
+ 1     0:00:01.000527000          0 0a010005        4   4           BEGIN
+ 2     0:00:01.500426000  499912000 0a010001        7   7           SWITCHED_OUT
+ 2     0:00:01.500450000      24000 0a010002        7   7           SWITCHED_IN
+ 2     0:00:01.500579000     129000 0a010002        7   7           TERMINATED
+ 2     0:00:01.500731000     152000 0a010002        7   7           SWITCHED_OUT
+ 2     0:00:01.500755000      24000 0a010001        7   7           SWITCHED_IN
+ 2     0:00:01.500966000     211000 0a010001        7   7           SWITCHED_OUT
+ 0     0:00:01.501049000          0 0a010003        7   5           TERMINATED
+ 2     0:00:01.501186000     220000 0a010001        7   7           SWITCHED_IN
+ 0     0:00:01.501200000     151000 0a010003        7   5           SWITCHED_OUT
+ 2     0:00:01.501391000     205000 0a010001        7   7           SWITCHED_OUT
+ 3     0:00:01.501476000          0 0a010004        7   6           TERMINATED
+ 3     0:00:01.501623000     147000 0a010004        7   6           SWITCHED_OUT
+ 3     0:00:01.501649000      26000 0a010001        7   7           SWITCHED_IN
+ 3     0:00:01.501867000     218000 0a010001        7   7           SWITCHED_OUT
+ 1     0:00:01.501945000  501418000 0a010005        7   4           TERMINATED
+ 3     0:00:01.502083000     216000 0a010001        7   7           SWITCHED_IN
+ 1     0:00:01.502136000     191000 0a010005        7   4           SWITCHED_OUT
+*** END OF TEST SMPCAPTURE 1 ***
+Note: Times may differ
1.8.1.4
