[PATCH 3/4] capture01: Add SMP support into capture engine.
Tue Nov 4 16:18:34 UTC 2014
The commit message is a bit too vague and maybe misleading. It should
reflect this changes the capture test to use the SMP support
-Gedare
On Tue, Nov 4, 2014 at 8:39 AM, Jennifer Averett
<jennifer.averett at oarcorp.com> wrote:
>  testsuites/libtests/capture01/init.c | 249 ++---------------------------------
>  1 file changed, 12 insertions(+), 237 deletions(-)
> diff --git a/testsuites/libtests/capture01/init.c b/testsuites/libtests/capture01/init.c
> index a725e26..e1e1e84 100644
> --- a/testsuites/libtests/capture01/init.c
> +++ b/testsuites/libtests/capture01/init.c
> @@ -33,229 +33,6 @@ rtems_task Init(rtems_task_argument argument);
>  const char rtems_test_name[] = "CAPTURE 1";
> -static void cwlist(void);
> -static void ctrace(void);
> -static void cwlist ()
> -  rtems_capture_control_t* control = rtems_capture_get_control_list ();
> -  rtems_task_priority      ceiling = rtems_capture_watch_get_ceiling ();
> -  rtems_task_priority      floor = rtems_capture_watch_get_floor ();
> -  fprintf (stdout, "watch priority ceiling is %" PRId32 "\n", ceiling);
> -  fprintf (stdout, "watch priority floor is %" PRId32 "\n", floor);
> -  fprintf (stdout, "global watch is %s\n",
> -          rtems_capture_watch_global_on () ? "enabled" : "disabled");
> -  fprintf (stdout, "total %" PRId32 "\n", rtems_capture_control_count ());
> -  while (control)
> -    uint32_t flags;
> -    int      f;
> -    int      fshowed;
> -    int      lf;
> -    fprintf (stdout, " ");
> -    rtems_monitor_dump_id (rtems_capture_control_id (control));
> -    rtems_monitor_dump_name (rtems_capture_control_name (control));
> -    flags = rtems_capture_control_flags (control);
> -    fprintf (stdout, " %c%c ",
> -             rtems_capture_watch_global_on () ? 'g' : '-',
> -             flags & RTEMS_CAPTURE_WATCH ? 'w' : '-');
> -    flags = rtems_capture_control_to_triggers (control);
> -    fprintf (stdout, " T:%c%c%c%c%c%c%c",
> -             flags & RTEMS_CAPTURE_SWITCH    ? 'S' : '-',
> -             flags & RTEMS_CAPTURE_CREATE ? 'C' : '-',
> -             flags & RTEMS_CAPTURE_START ? 'S' : '-',
> -             flags & RTEMS_CAPTURE_RESTART ? 'R' : '-',
> -             flags & RTEMS_CAPTURE_DELETE ? 'D' : '-',
> -             flags & RTEMS_CAPTURE_BEGIN ? 'B' : '-',
> -             flags & RTEMS_CAPTURE_EXITTED ? 'E' : '-');
> -    flags = rtems_capture_control_from_triggers (control);
> -    fprintf (stdout, " F:%c%c%c%c%c",
> -             flags & RTEMS_CAPTURE_DELETE  ? 'D' : '-');
> -    for (f = 0, fshowed = 0, lf = 1; f < RTEMS_CAPTURE_TRIGGER_TASKS; f++)
> -      if (rtems_capture_control_by_valid (control, f))
> -        if (lf && ((fshowed % 3) == 0))
> -          fprintf (stdout, "\n");
> -          lf = 0;
> -        fprintf (stdout, "  %2i:", f);
> -        rtems_monitor_dump_name (rtems_capture_control_by_name (control, f));
> -        fprintf (stdout, "/");
> -        rtems_monitor_dump_id (rtems_capture_control_by_id (control, f));
> -        flags = rtems_capture_control_by_triggers (control, f);
> -        fprintf (stdout, ":%c%c%c%c%c",
> -        fshowed++;
> -        lf = 1;
> -    if (lf)
> -    control = rtems_capture_next_control (control);
> - * rtems_catpure_cli_print_uptime
> - *  DESCRIPTION::148
> - * This function prints the nanosecond uptime to stdout.
> -static void
> -rtems_capture_cli_print_timestamp (uint64_t uptime)
> -  uint32_t hours;
> -  uint32_t minutes;
> -  uint32_t seconds;
> -  uint32_t nanosecs;
> -  seconds  = uptime / 1000000000LLU;
> -  minutes  = seconds / 60;
> -  hours    = minutes / 60;
> -  minutes  = minutes % 60;
> -  seconds  = seconds % 60;
> -  nanosecs = uptime % 1000000000;
> -  fprintf (stdout, "%5lu:%02lu:%02lu.%09lu", hours, minutes, seconds, nanosecs);
> -static void
> -rtems_caputre_cli_print_record_task(rtems_capture_record_t* rec)
> -  rtems_capture_task_record_t* task_rec = (rtems_capture_task_record_t*) rec;
> -  rtems_capture_cli_print_timestamp (rec->time);
> -  rtems_monitor_dump_id (rec->task_id);
> -   fprintf (stdout, " %c%c%c%c",
> -            (char) (task_rec->name >> 24) & 0xff,
> -            (char) (task_rec->name >> 16) & 0xff,
> -            (char) (task_rec->name >> 8) & 0xff,
> -            (char) (task_rec->name >> 0) & 0xff);
> -   fprintf (stdout, " %3" PRId32   " %3" PRId32 "\n",
> -            task_rec->start_priority,
> -            task_rec->stack_size);
> -static void
> -rtems_caputure_cli_print_record_std(rtems_capture_record_t* rec, uint64_t diff)
> -  uint32_t                     event;
> -  int                          e;
> -  event = rec->events >> RTEMS_CAPTURE_EVENT_START;
> -  for (e = RTEMS_CAPTURE_EVENT_START; e < RTEMS_CAPTURE_EVENT_END; e++)
> -    if (event & 1)
> -      fprintf (stdout, " %9" PRId64 " ", diff);
> -      fprintf(stdout, "      %3" PRId32 " %3" PRId32 " %s\n",
> -             (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
> -             (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
> -             rtems_capture_event_text (e));
> -    event >>= 1;
> -static void ctrace()
> -  rtems_status_code       sc;
> -  bool                    csv = false;
> -  static int              dump_total = 22;
> -  int                     total;
> -  int                     count;
> -  uint32_t                read;
> -  rtems_capture_record_t* rec;
> -  uint8_t*                ptr;
> -  rtems_capture_time_t    last_t = 0;
> -  total = dump_total;
> -  while (total)
> -    sc = rtems_capture_read (0, 0, &read, &rec);
> -    if (sc != RTEMS_SUCCESSFUL)
> -      fprintf (stdout, "error: trace read failed: %s\n", rtems_status_text (sc));
> -      rtems_capture_flush (0);
> -      return;
> -     * If we have no records then just exist. We still need to release
> -     * the reader lock.
> -    if (read == 0)
> -      rtems_capture_release (read);
> -      break;
> -    count = total < read ? total : read;
> -    ptr = (uint8_t *) rec;
> -    while (count--)
> -      rec = (rtems_capture_record_t*) ptr;
> -      if (csv)
> -        fprintf (stdout, "%08" PRIu32 ",%03" PRIu32
> -                   ",%03" PRIu32 ",%04" PRIx32 ",%" PRId64 "\n",
> -                 rec->task_id,
> -                 (rec->events >> RTEMS_CAPTURE_EVENT_START),
> -                 (uint64_t) rec->time);
> -      else {
> -        if ((rec->events >> RTEMS_CAPTURE_EVENT_START) == 0)
> -          rtems_caputre_cli_print_record_task( rec );
> -        else {
> -          uint64_t diff = 0;
> -          if (last_t)
> -            diff = rec->time - last_t;
> -          last_t = rec->time;
> -          rtems_caputure_cli_print_record_std( rec, diff );
> -      ptr += rec->size;
> -    if (count < total)
> -      total -= count;
> -    else
> -      total = 0;
> -    rtems_capture_release (count);
>  rtems_task Init(
>    rtems_task_argument ignored
> @@ -270,11 +47,6 @@ rtems_task Init(
>    rtems_test_begin();
> -#ifdef RTEMS_SMP
> -  printf("Capture Engine is broken due to recursive interrupt lock usage\n");
> -  assert(0);
> -#endif
>    rtems_task_set_priority(RTEMS_SELF, 20, &old_priority);
>    rtems_task_mode(RTEMS_PREEMPT,  RTEMS_PREEMPT_MASK, &old_mode);
> @@ -291,24 +63,27 @@ rtems_task Init(
>    ASSERT_SC(sc);
>    sc = rtems_capture_set_trigger (
> -    0,
> -    0,
> -    to_name,
> -    0,
> -    rtems_capture_from_any,
> +    0,
> +    0,
> +    to_name,
> +    0,
> +    rtems_capture_from_any,
>      rtems_capture_switch
>    ASSERT_SC(sc);
> -  cwlist();
> +  rtems_capture_print_watch_list();
>    sc = rtems_capture_control (true);
>    ASSERT_SC(sc);
>    capture_test_1();
> -  ctrace();
> -  ctrace();
> +  sc = rtems_capture_control (false);
> +  ASSERT_SC(sc);
> +  rtems_capture_print_trace_records ( 22, false );
>    rtems_test_end();
>    exit( 0 );
> 1.8.1.4
> devel mailing list
> devel at rtems.org
