Test failures on arm/realview_pbx_a9_qemu
Wed Nov 5 07:14:22 UTC 2014
Hello,
on the latest Git master the following new tests fail on
arm/realview_pbx_a9_qemu due to a timeout after 180 seconds: top, dl01.pre and
dl02.pre.
Attached are the log files.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
*** BEGIN OF TEST TOP ***
 Press ENTER to exit.
uptime:       0.044649
                              CPU USAGE BY THREAD
 ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |  36.531
 0x0A010005 | TA03                |    1 |    1   |      0.015740 |  25.797
 0x0A010002 | TA02                |    2 |    2   |      0.003576 |   5.550
 0x0A010003 | TA01                |    2 |    2   |      0.002941 |   4.340
 0x09010001 | IDLE                |  255 |  255   |      0.000000 |   0.000
 0x0A010004 | CPlt                |    2 |    2   |      0.031269 |  41.980
uptime:       5.071975
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |      4.666756 |  91.491
 0x0A010002 | TA02                |    2 |    2   |      0.244932 |   4.798
 0x0A010005 | TA03                |    1 |    1   |      0.076957 |   1.506
 0x0A010004 | CPlt                |    2 |    2   |      0.050300 |   0.984
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.409
 0x0A010006 | TA04                |    1 |    1   |      0.020513 |   0.400
 0x0A010003 | TA01                |    2 |    2   |      0.005811 |   0.113
uptime:      10.122198
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |      9.254421 |  91.309
 0x0A010002 | TA02                |    2 |    2   |      0.482391 |   4.757
 0x0A010005 | TA03                |    1 |    1   |      0.153558 |   1.508
 0x0A010006 | TA04                |    1 |    1   |      0.102426 |   1.005
 0x0A010004 | CPlt                |    2 |    2   |      0.082041 |   0.805
 0x0A010007 | TA05                |    1 |    1   |      0.025394 |   0.249
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.205
 0x0A010003 | TA01                |    2 |    2   |      0.008698 |   0.085
uptime:      15.192422
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     13.712299 |  90.180
 0x0A010002 | TA02                |    2 |    2   |      0.714520 |   4.698
 0x0A010005 | TA03                |    1 |    1   |      0.230246 |   1.513
 0x0A010006 | TA04                |    1 |    1   |      0.205035 |   1.347
 0x0A010007 | TA05                |    1 |    1   |      0.151795 |   0.997
 0x0A010004 | CPlt                |    2 |    2   |      0.146233 |   0.960
 0x0A010008 | TA06                |    1 |    1   |      0.030486 |   0.200
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.137
 0x0A010003 | TA01                |    2 |    2   |      0.011603 |   0.076
uptime:      20.288588
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     18.041762 |  88.867
 0x0A010002 | TA02                |    2 |    2   |      0.940340 |   4.631
 0x0A010006 | TA04                |    1 |    1   |      0.307732 |   1.515
 0x0A010005 | TA03                |    1 |    1   |      0.307025 |   1.511
 0x0A010007 | TA05                |    1 |    1   |      0.278279 |   1.369
 0x0A010008 | TA06                |    1 |    1   |      0.182447 |   0.897
 0x0A010004 | CPlt                |    2 |    2   |      0.194521 |   0.957
 0x0A010009 | TA07                |    1 |    1   |      0.035367 |   0.174
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.103
 0x0A010003 | TA01                |    2 |    2   |      0.014525 |   0.071
uptime:      25.332898
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     22.196920 |  87.575
 0x0A010002 | TA02                |    2 |    2   |      1.158356 |   4.569
 0x0A010006 | TA04                |    1 |    1   |      0.410517 |   1.619
 0x0A010005 | TA03                |    1 |    1   |      0.383892 |   1.513
 0x0A010007 | TA05                |    1 |    1   |      0.379531 |   1.496
 0x0A010008 | TA06                |    1 |    1   |      0.304433 |   1.200
 0x0A010009 | TA07                |    1 |    1   |      0.211634 |   0.834
 0x0A010004 | CPlt                |    2 |    2   |      0.246613 |   0.972
 0x0A01000A | TA08                |    1 |    1   |      0.040459 |   0.159
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.082
 0x0A010003 | TA01                |    2 |    2   |      0.017466 |   0.068
uptime:      30.449054
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     26.166310 |  85.897
 0x0A010002 | TA02                |    2 |    2   |      1.365609 |   4.482
 0x0A010006 | TA04                |    1 |    1   |      0.513391 |   1.684
 0x0A010007 | TA05                |    1 |    1   |      0.506614 |   1.662
 0x0A010005 | TA03                |    1 |    1   |      0.461687 |   1.514
 0x0A010008 | TA06                |    1 |    1   |      0.456997 |   1.499
 0x0A010009 | TA07                |    1 |    1   |      0.388113 |   1.273
 0x0A010004 | CPlt                |    2 |    2   |      0.299529 |   0.982
 0x0A01000A | TA08                |    1 |    1   |      0.242184 |   0.794
 0x0A01000B | TA09                |    1 |    1   |      0.045341 |   0.148
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.068
 0x0A010003 | TA01                |    2 |    2   |      0.020423 |   0.066
uptime:      35.503546
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     29.924283 |  84.254
 0x0A010002 | TA02                |    2 |    2   |      1.562154 |   4.397
 0x0A010007 | TA05                |    1 |    1   |      0.633896 |   1.784
 0x0A010006 | TA04                |    1 |    1   |      0.616353 |   1.734
 0x0A010008 | TA06                |    1 |    1   |      0.609649 |   1.715
 0x0A010005 | TA03                |    1 |    1   |      0.539780 |   1.519
 0x0A010009 | TA07                |    1 |    1   |      0.529257 |   1.489
 0x0A01000A | TA08                |    1 |    1   |      0.403844 |   1.133
 0x0A010004 | CPlt                |    2 |    2   |      0.320201 |   0.898
 0x0A01000B | TA09                |    1 |    1   |      0.271474 |   0.762
 0x0A01000C | TA10                |    1 |    1   |      0.050432 |   0.141
 0x0A010003 | TA01                |    2 |    2   |      0.023450 |   0.065
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.058
uptime:      40.633793
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     33.433140 |  82.252
 0x0A010002 | TA02                |    2 |    2   |      1.746519 |   4.296
 0x0A010008 | TA06                |    1 |    1   |      0.762389 |   1.875
 0x0A010007 | TA05                |    1 |    1   |      0.761266 |   1.872
 0x0A010006 | TA04                |    1 |    1   |      0.719404 |   1.769
 0x0A010009 | TA07                |    1 |    1   |      0.705767 |   1.735
 0x0A010005 | TA03                |    1 |    1   |      0.617961 |   1.519
 0x0A01000A | TA08                |    1 |    1   |      0.606273 |   1.490
 0x0A01000B | TA09                |    1 |    1   |      0.497695 |   1.223
 0x0A010004 | CPlt                |    2 |    2   |      0.423541 |   1.041
 0x0A01000C | TA10                |    1 |    1   |      0.302023 |   0.742
 0x0A01000D | TA11                |    1 |    1   |      0.055314 |   0.135
 0x0A010003 | TA01                |    2 |    2   |      0.026494 |   0.065
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.051
uptime:      45.694132
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     36.693846 |  80.280
 0x0A010002 | TA02                |    2 |    2   |      1.919172 |   4.198
 0x0A010008 | TA06                |    1 |    1   |      0.915217 |   2.002
 0x0A010007 | TA05                |    1 |    1   |      0.889753 |   1.946
 0x0A010009 | TA07                |    1 |    1   |      0.882696 |   1.928
 0x0A010006 | TA04                |    1 |    1   |      0.822147 |   1.796
 0x0A01000A | TA08                |    1 |    1   |      0.808791 |   1.766
 0x0A010005 | TA03                |    1 |    1   |      0.695601 |   1.517
 0x0A01000B | TA09                |    1 |    1   |      0.678733 |   1.480
 0x0A01000C | TA10                |    1 |    1   |      0.503356 |   1.098
 0x0A010004 | CPlt                |    2 |    2   |      0.452375 |   0.986
 0x0A01000D | TA11                |    1 |    1   |      0.331313 |   0.722
 0x0A01000E | TA12                |    1 |    1   |      0.060406 |   0.131
 0x0A010003 | TA01                |    2 |    2   |      0.029556 |   0.064
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.045
uptime:      50.854349
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     39.661125 |  77.969
 0x0A010002 | TA02                |    2 |    2   |      2.077161 |   4.083
 0x0A010008 | TA06                |    1 |    1   |      1.068134 |   2.099
 0x0A010009 | TA07                |    1 |    1   |      1.059960 |   2.083
 0x0A010007 | TA05                |    1 |    1   |      1.018967 |   2.002
 0x0A01000A | TA08                |    1 |    1   |      1.011426 |   1.987
 0x0A010006 | TA04                |    1 |    1   |      0.924669 |   1.817
 0x0A01000B | TA09                |    1 |    1   |      0.905136 |   1.778
 0x0A010005 | TA03                |    1 |    1   |      0.772909 |   1.518
 0x0A01000C | TA10                |    1 |    1   |      0.755541 |   1.484
 0x0A01000D | TA11                |    1 |    1   |      0.607401 |   1.193
 0x0A010004 | CPlt                |    2 |    2   |      0.562744 |   1.105
 0x0A01000E | TA12                |    1 |    1   |      0.361863 |   0.710
 0x0A01000F | TA13                |    1 |    1   |      0.065287 |   0.128
 0x0A010003 | TA01                |    2 |    2   |      0.032635 |   0.064
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.041
uptime:      55.985096
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     42.333294 |  75.597
 0x0A010002 | TA02                |    2 |    2   |      2.221002 |   3.965
 0x0A010009 | TA07                |    1 |    1   |      1.237285 |   2.209
 0x0A010008 | TA06                |    1 |    1   |      1.221139 |   2.180
 0x0A01000A | TA08                |    1 |    1   |      1.214120 |   2.167
 0x0A010007 | TA05                |    1 |    1   |      1.148269 |   2.049
 0x0A01000B | TA09                |    1 |    1   |      1.131602 |   2.020
 0x0A010006 | TA04                |    1 |    1   |      1.027403 |   1.832
 0x0A01000C | TA10                |    1 |    1   |      1.007953 |   1.797
 0x0A010005 | TA03                |    1 |    1   |      0.850288 |   1.516
 0x0A01000D | TA11                |    1 |    1   |      0.828359 |   1.476
 0x0A01000E | TA12                |    1 |    1   |      0.663400 |   1.182
 0x0A010004 | CPlt                |    2 |    2   |      0.598891 |   1.067
 0x0A01000F | TA13                |    1 |    1   |      0.391153 |   0.697
 0x0A010010 | TA14                |    1 |    1   |      0.070379 |   0.125
 0x0A010003 | TA01                |    2 |    2   |      0.036083 |   0.064
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.037
uptime:      61.114910
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     44.665206 |  73.068
 0x0A010002 | TA02                |    2 |    2   |      2.346790 |   3.838
 0x0A01000A | TA08                |    1 |    1   |      1.417027 |   2.317
 0x0A010009 | TA07                |    1 |    1   |      1.415235 |   2.314
 0x0A010008 | TA06                |    1 |    1   |      1.374338 |   2.247
 0x0A01000B | TA09                |    1 |    1   |      1.358375 |   2.221
 0x0A010007 | TA05                |    1 |    1   |      1.276957 |   2.088
 0x0A01000C | TA10                |    1 |    1   |      1.260426 |   2.061
 0x0A010006 | TA04                |    1 |    1   |      1.130101 |   1.847
 0x0A01000D | TA11                |    1 |    1   |      1.104602 |   1.806
 0x0A010005 | TA03                |    1 |    1   |      0.928193 |   1.517
 0x0A01000E | TA12                |    1 |    1   |      0.904834 |   1.479
 0x0A01000F | TA13                |    1 |    1   |      0.717134 |   1.172
 0x0A010004 | CPlt                |    2 |    2   |      0.717378 |   1.172
 0x0A010010 | TA14                |    1 |    1   |      0.421702 |   0.689
 0x0A010011 | TA15                |    1 |    1   |      0.075611 |   0.123
 0x0A010003 | TA01                |    2 |    2   |      0.039199 |   0.064
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.034
uptime:      66.246141
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     46.634417 |  70.381
 0x0A010002 | TA02                |    2 |    2   |      2.455032 |   3.704
 0x0A01000A | TA08                |    1 |    1   |      1.619881 |   2.444
 0x0A010009 | TA07                |    1 |    1   |      1.594403 |   2.405
 0x0A01000B | TA09                |    1 |    1   |      1.585690 |   2.392
 0x0A010008 | TA06                |    1 |    1   |      1.527431 |   2.304
 0x0A01000C | TA10                |    1 |    1   |      1.512987 |   2.280
 0x0A010007 | TA05                |    1 |    1   |      1.404681 |   2.117
 0x0A01000D | TA11                |    1 |    1   |      1.380934 |   2.081
 0x0A010006 | TA04                |    1 |    1   |      1.232888 |   1.857
 0x0A01000E | TA12                |    1 |    1   |      1.207085 |   1.818
 0x0A010005 | TA03                |    1 |    1   |      1.006816 |   1.517
 0x0A01000F | TA13                |    1 |    1   |      0.977958 |   1.473
 0x0A010010 | TA14                |    1 |    1   |      0.773265 |   1.165
 0x0A010004 | CPlt                |    2 |    2   |      0.761962 |   1.147
 0x0A010011 | TA15                |    1 |    1   |      0.451371 |   0.679
 0x0A010012 | TA16                |    1 |    1   |      0.080521 |   0.121
 0x0A010003 | TA01                |    2 |    2   |      0.042344 |   0.063
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.031
uptime:      71.492045
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     48.325630 |  67.583
 0x0A010002 | TA02                |    2 |    2   |      2.548057 |   3.563
 0x0A01000A | TA08                |    1 |    1   |      1.822822 |   2.548
 0x0A01000B | TA09                |    1 |    1   |      1.813121 |   2.535
 0x0A010009 | TA07                |    1 |    1   |      1.773688 |   2.480
 0x0A01000C | TA10                |    1 |    1   |      1.765636 |   2.463
 0x0A010008 | TA06                |    1 |    1   |      1.680641 |   2.345
 0x0A01000D | TA11                |    1 |    1   |      1.657354 |   2.312
 0x0A010007 | TA05                |    1 |    1   |      1.532493 |   2.138
 0x0A01000E | TA12                |    1 |    1   |      1.509424 |   2.105
 0x0A010006 | TA04                |    1 |    1   |      1.336000 |   1.863
 0x0A01000F | TA13                |    1 |    1   |      1.304066 |   1.819
 0x0A010005 | TA03                |    1 |    1   |      1.085318 |   1.514
 0x0A010010 | TA14                |    1 |    1   |      1.054565 |   1.471
 0x0A010011 | TA15                |    1 |    1   |      0.827188 |   1.153
 0x0A010004 | CPlt                |    2 |    2   |      0.855025 |   1.192
 0x0A010012 | TA16                |    1 |    1   |      0.482163 |   0.672
 0x0A010013 | TA17                |    1 |    1   |      0.085585 |   0.119
 0x0A010003 | TA01                |    2 |    2   |      0.045508 |   0.063
 0x0A010001 | UI1                 |    1 |    1   |      0.020957 |   0.029
uptime:      76.705864
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     49.652280 |  64.719
 0x0A010002 | TA02                |    2 |    2   |      2.622517 |   3.418
 0x0A01000B | TA09                |    1 |    1   |      2.040822 |   2.659
 0x0A01000A | TA08                |    1 |    1   |      2.025853 |   2.640
 0x0A01000C | TA10                |    1 |    1   |      2.018402 |   2.620
 0x0A010009 | TA07                |    1 |    1   |      1.952822 |   2.535
 0x0A01000D | TA11                |    1 |    1   |      1.934000 |   2.510
 0x0A010008 | TA06                |    1 |    1   |      1.833911 |   2.380
 0x0A01000E | TA12                |    1 |    1   |      1.811879 |   2.351
 0x0A010007 | TA05                |    1 |    1   |      1.660602 |   2.155
 0x0A01000F | TA13                |    1 |    1   |      1.630473 |   2.116
 0x0A010006 | TA04                |    1 |    1   |      1.438963 |   1.867
 0x0A010010 | TA14                |    1 |    1   |      1.406682 |   1.825
 0x0A010005 | TA03                |    1 |    1   |      1.164117 |   1.510
 0x0A010011 | TA15                |    1 |    1   |      1.128014 |   1.463
 0x0A010004 | CPlt                |    2 |    2   |      0.946620 |   1.228
 0x0A010012 | TA16                |    1 |    1   |      0.803615 |   1.042
 0x0A010013 | TA17                |    1 |    1   |      0.511183 |   0.663
 0x0A010014 | TA18                |    1 |    1   |      0.090466 |   0.117
 0x0A010003 | TA01                |    2 |    2   |      0.048689 |   0.063
uptime:      82.082238
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     50.550489 |  61.575
 0x0A010002 | TA02                |    2 |    2   |      2.671739 |   3.254
 0x0A01000C | TA10                |    1 |    1   |      2.271227 |   2.766
 0x0A01000B | TA09                |    1 |    1   |      2.269452 |   2.764
 0x0A01000A | TA08                |    1 |    1   |      2.229606 |   2.715
 0x0A01000D | TA11                |    1 |    1   |      2.211146 |   2.692
 0x0A010009 | TA07                |    1 |    1   |      2.130501 |   2.594
 0x0A01000E | TA12                |    1 |    1   |      2.114394 |   2.574
 0x0A010008 | TA06                |    1 |    1   |      1.987269 |   2.419
 0x0A01000F | TA13                |    1 |    1   |      1.957836 |   2.383
 0x0A010007 | TA05                |    1 |    1   |      1.789640 |   2.161
 0x0A010010 | TA14                |    1 |    1   |      1.758915 |   2.124
 0x0A010006 | TA04                |    1 |    1   |      1.542015 |   1.862
 0x0A010011 | TA15                |    1 |    1   |      1.504567 |   1.816
 0x0A010005 | TA03                |    1 |    1   |      1.243004 |   1.500
 0x0A010012 | TA16                |    1 |    1   |      1.205538 |   1.455
 0x0A010004 | CPlt                |    2 |    2   |      1.014290 |   1.224
 0x0A010013 | TA17                |    1 |    1   |      0.937020 |   1.131
 0x0A010014 | TA18                |    1 |    1   |      0.541522 |   0.653
 0x0A010015 | TA19                |    1 |    1   |      0.095557 |   0.115
uptime:      88.210814
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                |  255 |  255   |     51.062306 |  57.749
 0x0A010002 | TA02                |    2 |    2   |      2.702127 |   3.055
 0x0A01000C | TA10                |    1 |    1   |      2.574703 |   2.911
 0x0A01000B | TA09                |    1 |    1   |      2.544421 |   2.871
 0x0A01000D | TA11                |    1 |    1   |      2.544088 |   2.871
 0x0A01000E | TA12                |    1 |    1   |      2.477533 |   2.774
 0x0A01000A | TA08                |    1 |    1   |      2.473522 |   2.770
 0x0A01000F | TA13                |    1 |    1   |      2.351418 |   2.633
 0x0A010009 | TA07                |    1 |    1   |      2.345736 |   2.626
 0x0A010010 | TA14                |    1 |    1   |      2.181681 |   2.443
 0x0A010008 | TA06                |    1 |    1   |      2.171452 |   2.431
 0x0A010011 | TA15                |    1 |    1   |      1.956518 |   2.190
 0x0A010007 | TA05                |    1 |    1   |      1.942497 |   2.174
 0x0A010012 | TA16                |    1 |    1   |      1.687931 |   1.889
 0x0A010006 | TA04                |    1 |    1   |      1.665822 |   1.865
 0x0A010013 | TA17                |    1 |    1   |      1.362795 |   1.522
 0x0A010005 | TA03                |    1 |    1   |      1.337786 |   1.480
 0x0A010004 | CPlt                |    2 |    2   |      1.087431 |   1.203
 0x0A010014 | TA18                |    1 |    1   |      0.993243 |   1.098
 0x0A010015 | TA19                |    1 |    1   |      0.571255 |   0.632
qemu: terminating on signal 2 from pid 1000
Type: application/vnd.lotus-freelance
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141105/69f62e8f/attachment-0002.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141105/69f62e8f/attachment-0003.bin>
