Run-Time Loader Build Failures
Thu Nov 6 01:32:53 UTC 2014
On 6/11/2014 11:08 am, Joel Sherrill wrote:
> I just thought I would post a summary after the recent updates
> and include all targets in one easy to track email.  Overall about
> 50% of the architectures fail to build for some reason or another.
> + Unrecognized symbol type from a .s file
> bfin (all BSPs), i386 (all BSPs), powerpc (all BSPs)
The i386 is now building. You need to update your rtems-tools to get a
fixed rtems-syms. It seems some assemblers do not handle the .type
statement while other do, or there are some variants that the rtems-syms
did not handle. I have removed inserting a .type statement.
The bfin tools are not build for me. I get:
/opt/work/rtems/rsb/chris/rtems-source-builder.master/rtems/build/bfin-rtems4.11-gcc-4.9.2-newlib-9b9f839addfe16ab0fd11f09a30a28139bfae6d5-1/build/./gcc/xgcc
-B/opt/work/rtems/rsb/chris/rtems-source-builder.master/rtems/build/bfin-rtems4.11-gcc-4.9.2-newlib-9b9f839addfe16ab0fd11f09a30a28139bfae6d5-1/build/./gcc/
-nostdinc
-B/opt/work/rtems/rsb/chris/rtems-source-builder.master/rtems/build/bfin-rtems4.11-gcc-4.9.2-newlib-9b9f839addfe16ab0fd11f09a30a28139bfae6d5-1/build/bfin-rtems4.11/newlib/
-isystem
/opt/work/rtems/rsb/chris/rtems-source-builder.master/rtems/build/bfin-rtems4.11-gcc-4.9.2-newlib-9b9f839addfe16ab0fd11f09a30a28139bfae6d5-1/build/bfin-rtems4.11/newlib/targ-include
-isystem
/opt/work/rtems/rsb/chris/rtems-source-builder.master/rtems/build/bfin-rtems4.11-gcc-4.9.2-newlib-9b9f839addfe16ab0fd11f09a30a28139bfae6d5-1/gcc-4.9.2/newlib/libc/include
-B/opt/work/rtems/4.11/bfin-rtems4.11/bin/
-B/opt/work/rtems/4.11/bfin-rtems4.11/lib/ -isystem
/opt/work/rtems/4.11/bfin-rtems4.11/include -isystem
/opt/work/rtems/4.11/bfin-rtems4.11/sys-include    -g -O2 -O2
-I../../../gcc-4.9.2/libgcc/../newlib/libc/sys/rtems/include -g -O2
-DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -W -Wall -Wno-narrowing
-Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes
-Wold-style-definition  -isystem ./include   -g -DIN_LIBGCC2
-fbuilding-libgcc -fno-stack-protector -Dinhibit_libc  -I. -I.
-I../.././gcc -I../../../gcc-4.9.2/libgcc -I../../../gcc-4.9.2/libgcc/.
-I../../../gcc-4.9.2/libgcc/../gcc
-I../../../gcc-4.9.2/libgcc/../include  -DHAVE_CC_TLS -DUSE_EMUTLS -o
_ge_sf.o -MT _ge_sf.o -MD -MP -MF _ge_sf.dep -DFINE_GRAINED_LIBRARIES
-DL_ge_sf -DFLOAT  -c ../../../gcc-4.9.2/libgcc/fp-bit.c
-fvisibility=hidden -DHIDE_EXPORTS
../../../gcc-4.9.2/libgcc/fp-bit.c: In function '__divsf3':
../../../gcc-4.9.2/libgcc/fp-bit.c:1082:1: internal compiler error: in
cfg_layout_initialize, at cfgrtl.c:4233
