Test failures on arm/realview_pbx_a9_qemu
Thu Nov 6 14:00:26 UTC 2014
On Thu, Nov 6, 2014 at 7:48 AM, Sebastian Huber
> On 06/11/14 13:42, Joel Sherrill wrote:
>>> I think it is preferable to turn this top test into a
>>> >non-interactive test.
>> Have you run it?
>> There is no way to automate checking the output.
> In theory you could redirect the file streams and parse them.  Its just a
> bit time consuming and there are probably more interesting things to do.
All tests we rely on should be non-interactive. Interactive tests
should be fixed or moved into a separate directory of the testsuite so
we can ignore them easier when doing automated build & test.
My two cents.
Gedare
> devel mailing list
> devel at rtems.org
