Test failures on arm/realview_pbx_a9_qemu
Thu Nov 6 14:02:25 UTC 2014
On November 6, 2014 8:00:26 AM CST, Gedare Bloom <gedare at rtems.org> wrote:
>On Thu, Nov 6, 2014 at 7:48 AM, Sebastian Huber
><sebastian.huber at embedded-brains.de> wrote:
>> On 06/11/14 13:42, Joel Sherrill wrote:
>>>> I think it is preferable to turn this top test into a
>>>> >non-interactive test.
>>> Have you run it?
>>> There is no way to automate checking the output.
>> In theory you could redirect the file streams and parse them.  Its
>just a
>> bit time consuming and there are probably more interesting things to
>do.
>All tests we rely on should be non-interactive. Interactive tests
>should be fixed or moved into a separate directory of the testsuite so
>we can ignore them easier when doing automated build & test.
>My two cents.
I had thought of moving them to an interactive directory. If we did this, would it be OK to enable them when samples are enabled? Fileio is one of them
>Gedare
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
