4.11 Branching To Do
Pavel Pisa ppisa4lists at pikron.com
Thu Nov 6 15:58:19 UTC 2014
On Thursday 06 of November 2014 14:57:18 Gedare Bloom wrote:
> Pavel posted about a generic tree framework:
> http://permalink.gmane.org/gmane.os.rtems.devel/1327
> I had some trouble getting inlining to work in the way that tree works
> (in the short time I spent on it):
> http://permalink.gmane.org/gmane.os.rtems.devel/1503
> It is possible that working with the original author may be fruitful.
> I don't know if this has had any movement in Linux.
I am not aware about enhancements in this direction in Linux
kernel. But I consider proposal as right balance between macros
complexity, performance, clean code generated and clean
type safe programing guideline. But I have not used that code.
I have my uLUt for my projects but that is macro monster.
Gedare, could you send me your attempt in some compact form, please?
Ideal for testing as host build on Linux. I cannot promiss, but
I would like to find while to look at the problem.
Best wishes,
               Pavel
