4.11 Branching To Do
Thu Nov 6 16:04:57 UTC 2014
On Thu, Nov 6, 2014 at 10:58 AM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> On Thursday 06 of November 2014 14:57:18 Gedare Bloom wrote:
>> Pavel posted about a generic tree framework:
>> http://permalink.gmane.org/gmane.os.rtems.devel/1327
>> I had some trouble getting inlining to work in the way that tree works
>> (in the short time I spent on it):
>> http://permalink.gmane.org/gmane.os.rtems.devel/1503
>> It is possible that working with the original author may be fruitful.
>> I don't know if this has had any movement in Linux.
> I am not aware about enhancements in this direction in Linux
> kernel. But I consider proposal as right balance between macros
> complexity, performance, clean code generated and clean
> type safe programing guideline. But I have not used that code.
> I have my uLUt for my projects but that is macro monster.
> Gedare, could you send me your attempt in some compact form, please?
> Ideal for testing as host build on Linux. I cannot promiss, but
> I would like to find while to look at the problem.
I have no clue where the attempt is, if it even still exists. I'll
take a look on my various dev machines, but doubt I'll find it as I
never bothered to backup that code.
-Gedare
> Best wishes,
>                Pavel
