rtems-tools: Fix libpath failed for rtems-ld
Sat Nov 8 05:35:39 UTC 2014
On 8/11/2014 1:39 pm, Peng Fan wrote:
> we should not clear input parameter 'se' in rld::split, otherwise paths
> passed using '--lib-path' to rtems-ld will be cleared if standlibs are used.
Thanks for this. I also have a patch for this in my repo. I will push it
once git has been relocated and writes are enabled again.
