[PATCH] libbsp ARM: create abort.h to eliminate warnings Created libbsp/arm/shared/abort/abort.h Edited abort.c and simple_abort.c to include abort.h Changed Raspberry Pi BSP to use abort.c instead of simple_abort.c
Sat Nov 8 17:04:42 UTC 2014
On Sat, Nov 8, 2014 at 11:50 AM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> On 11/5/2014 9:39 AM, Sebastian Huber wrote:
>> On 05/11/14 15:35, Alan Cudmore wrote:
>>> If the ARM BSPs that do not use the shared start.S include the code, but
>>> never
>>> call it, I can remove it, if that is what is best. We could even remove
>>> abort.c
>>> and simple_abort.c completely. Just let me know.
>> It would be best to get rid of these files.
> I did some investigation, and it is not going to be as easy as I thought to
> remove libbsp/arm/shared/abort/*.c
> The following ARM BSPs use score: arm_exc_handler_high.c,
> arm_exc_handler_low.S, which in turn use shared abort.c ( or simple_abort.c
>  csb336,
>  csb337,
>  edb7312,
>  gp32,
>  gumstix,
>  rtx22xx
> I think these will eventually have to be converted to use the ARM shared
> start.S.
Thanks for chasing this down. We should open a bug on this when we can.
> The raspberrypi, beagle, and gdbarmsim BSPs compile the shared/abort files
> but do not use them.
> So for now I can do the following:
> 1. remove the use of shared/abort/abort*.c from raspberrypi, beagle, and
> gdbarmsim ( in Makefile.am )
> 2. include a header file in shared/abort to eliminate future warnings for
> BSPs that use abort.c simple_abort.c
Ok
> Alan
