[PATCH 3/3] smpschedaffinity05: Change semaphore attributes.
Wed Nov 12 15:39:09 UTC 2014
On 11/12/2014 9:10 AM, Gedare Bloom wrote:
> Are there still tests for when the lock would be held despite the
> context switch? Just want to make sure we're not removing some
> test-case.
That wasn't the purpose of this test. It was to abuse the affinity
algorithm and cause migrations. Daniel Cederman found a bug
in the semaphore used to protect the data used to control the
threads and migration.
If you have another scenario in mind, please post it so we
can at least file a PR to add the case.
--joel
> On Wed, Nov 12, 2014 at 9:48 AM, Jennifer Averett
> <jennifer.averett at oarcorp.com> wrote:
>> Change semaphore attributes to resolve problem where semaphore is not
>> released upon a context switch.
>>  testsuites/smptests/smpschedaffinity05/init.c | 9 +++------
>>  1 file changed, 3 insertions(+), 6 deletions(-)
>> diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
>> index 754c226..9fddb58 100644
>> --- a/testsuites/smptests/smpschedaffinity05/init.c
>> +++ b/testsuites/smptests/smpschedaffinity05/init.c
>> @@ -145,14 +145,11 @@ static void test(void)
>>    sc = rtems_semaphore_create(
>>      rtems_build_name('S', 'E', 'M', '0'),
>>      1,                                               /* initial count = 1 */
>> -    RTEMS_LOCAL                   |
>> -    RTEMS_SIMPLE_BINARY_SEMAPHORE |
>> -    RTEMS_NO_INHERIT_PRIORITY     |
>> -    RTEMS_NO_PRIORITY_CEILING     |
>> -    RTEMS_FIFO,
>> +    RTEMS_BINARY_SEMAPHORE |
>> +    RTEMS_MULTIPROCESSOR_RESOURCE_SHARING,
>>      0,
>>      &task_sem
>>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> 1.8.1.4
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
