[PATCH 2/2] nfs: Add RPCd task affinity config option
Thu Nov 13 09:23:49 UTC 2014
On 13/11/14 10:09, Daniel Cederman wrote:
> @@ -407,6 +410,8 @@ static rtems_interval	ticksPerSec;		/* cached system clock rate (WHO IS ASSUMED
>   rtems_task_priority		rpciodPriority = 0;
> +cpu_set_t            *rpciodCpuset = 0;
> +size_t                rpciodCpusetSize = 0;
>   #if (DEBUG) & DEBUG_MALLOC
>   /* malloc wrappers for debugging */
Missing #ifdef RTEMS_SMP ?
I am not sure if we should really use #ifdef RTEMS_SMP for the #include
<sys/cpuset.h>.  We use also #if defined(__RTEMS_HAVE_SYS_CPUSET_H__) &&
defined(RTEMS_SMP) sometimes.  I would simply force users to update their
Newlib version.
Please fix the spacing and use the coding style of the file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
