[PATCH 8/9] bsp/xilinx-zynq: Add zync_clock_cpu_1x()
Thu Nov 13 09:30:26 UTC 2014
 c/src/lib/libbsp/arm/xilinx-zynq/configure.ac       | 5 +++++
 c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h      | 4 +++-
 c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c | 7 ++++++-
 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
index a6f16cc..580049a 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
@@ -34,6 +34,11 @@ RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[xilinx_zynq_zedboard*],[50000000UL])
 RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[*],[50000000UL])
 RTEMS_BSPOPTS_HELP([ZYNQ_CLOCK_UART],[Zynq UART clock frequency in Hz])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[xilinx_zynq_zc702*],[111111111U])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[xilinx_zynq_zedboard*],[111111111U])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[*],[111111111U])
+RTEMS_BSPOPTS_HELP([ZYNQ_CLOCK_CPU_1X],[Zynq cpu_1x clock frequency in Hz])
 USE_FAST_IDLE=0
 AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_a9_qemu], [USE_FAST_IDLE=1])
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
index d2c0bbb..9a0bfd2 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
@@ -5,7 +5,7 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -67,6 +67,8 @@ extern "C" {
 BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void);
+uint32_t zynq_clock_cpu_1x(void);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c
index 0be515c..ad66640 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c
@@ -1,5 +1,5 @@
  *  Dornierstr. 4
@@ -17,6 +17,11 @@
 #include <bsp/arm-a9mpcore-clock.h>
 #include <bsp/irq-generic.h>
+__attribute__ ((weak)) uint32_t zynq_clock_cpu_1x(void)
+  return ZYNQ_CLOCK_CPU_1X;
 void bsp_start(void)
   a9mpcore_clock_initialize_early();
1.8.4.5
