[PATCH v2 1/2] net: Add network task affinity config
Daniel Cederman cederman at gaisler.com
Thu Nov 13 10:21:01 UTC 2014
This patch adds a default network tasks CPU affinity configuration
option. The network drivers have the option to create their own
daemon tasks with a custom CPU affinity set, or rely on the
default set.
 cpukit/libnetworking/rtems/rtems_bsdnet.h          |  9 ++++++
 cpukit/libnetworking/rtems/rtems_bsdnet_internal.h | 12 ++++++++
 cpukit/libnetworking/rtems/rtems_glue.c            | 34 ++++++++++++++++++++++
 3 files changed, 55 insertions(+)
diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet.h b/cpukit/libnetworking/rtems/rtems_bsdnet.h
index 9dd44fe..3953efa 100644
--- a/cpukit/libnetworking/rtems/rtems_bsdnet.h
+++ b/cpukit/libnetworking/rtems/rtems_bsdnet.h
@@ -11,6 +11,7 @@ extern "C" {
 #endif
+#include <sys/cpuset.h>
  *  If this file is included from inside the Network Stack proper or
@@ -181,6 +182,14 @@ struct rtems_bsdnet_config {
 	unsigned long		tcp_tx_buf_size;
 	unsigned long		tcp_rx_buf_size;
+	 * Default Network Tasks CPU Affinity
+#ifdef RTEMS_SMP
+	cpu_set_t		*network_task_cpuset;
+	size_t			network_task_cpuset_size;
+#endif
diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
index 865b644..5be781b 100644
--- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
+++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
@@ -157,6 +157,18 @@ rtems_id rtems_bsdnet_newproc (
   void  *arg
+#ifdef RTEMS_SMP
+/* As rtems_bsdnet_newproc() but with ability to set CPU affinity too */
+rtems_id rtems_bsdnet_newproc_affinity (
+  char  *name,
+  int   stacksize,
+  void  (*entry)(void *),
+  void  *arg,
+  const cpu_set_t *set,
+  const size_t setsize
+#endif
 rtems_status_code rtems_bsdnet_event_receive (
   rtems_event_set  event_in,
   rtems_option     option_set,
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 8ed17d1..21e4a96 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -56,6 +56,10 @@ Semaphore_Control   *the_networkSemaphore;
 #endif
 static rtems_id networkDaemonTid;
 static uint32_t   networkDaemonPriority;
+#ifdef RTEMS_SMP
+static cpu_set_t  *networkDaemonCpuset = 0;
+static size_t     networkDaemonCpusetSize = 0;
+#endif
 static void networkDaemon (void *task_argument);
@@ -281,6 +285,14 @@ rtems_bsdnet_initialize (void)
 		networkDaemonPriority = rtems_bsdnet_config.network_task_priority;
+	 * Default network task CPU affinity
+#ifdef RTEMS_SMP
+	networkDaemonCpuset = rtems_bsdnet_config.network_task_cpuset;
+	networkDaemonCpusetSize = rtems_bsdnet_config.network_task_cpuset_size;
+#endif
 	 * Set the memory allocation limits
 	if (rtems_bsdnet_config.mbuf_bytecount)
@@ -660,11 +672,25 @@ taskEntry (rtems_task_argument arg)
 	rtems_panic ("Network task returned!\n");
  * Start a network task
+#ifdef RTEMS_SMP
+rtems_id
+rtems_bsdnet_newproc (char *name, int stacksize, void(*entry)(void *), void *arg)
+	return rtems_bsdnet_newproc_affinity( name, stacksize, entry, arg,
+		networkDaemonCpuset, networkDaemonCpusetSize );
+rtems_id
+rtems_bsdnet_newproc_affinity (char *name, int stacksize, void(*entry)(void *),
+    void *arg, const cpu_set_t *set, const size_t setsize)
+#else
 rtems_id
+#endif
 	struct newtask *t;
 	char nm[4];
@@ -681,6 +707,14 @@ rtems_bsdnet_newproc (char *name, int stacksize, void(*entry)(void *), void *arg
 	if (sc != RTEMS_SUCCESSFUL)
 		rtems_panic ("Can't create network daemon `%s': `%s'\n", name, rtems_status_text (sc));
+#ifdef RTEMS_SMP
+	 * Use the default affinity or use the user-provided CPU set
+	if ( set != 0 )
+		rtems_task_set_affinity( tid, setsize, set );
+#endif
 	 * Set up task arguments
2.1.3
