RTEMS toolchain for Epiphany?
Thu Nov 13 17:58:21 UTC 2014
On November 13, 2014 11:56:32 AM CST, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>Hi,
>I want to let you know that I found their main repos [1] Can I start
>from there? Imitating what has been done with OpenRISC?
Basically. Except you only need their repos for binutils and gdb. We use GCC and Newlib from upstream.
I have binutils patches
>[1] https://github.com/adapteva
>Regards,
>Hesham
>On Thu Nov 13 2014 at 3:29:14 PM Hesham Moustafa
>On Thu Nov 13 2014 at 2:59:33 PM Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>On 11/13/2014 8:07 AM, Joel Sherrill wrote:
>> On November 13, 2014 6:30:48 AM CST, Hesham Moustafa
>>> Hi all,
>>> I want to ask about the status of RTEMS toolchain for Epiphany
>>> architecture. I think Joel mentioned that there are some previous
>>> support for it; and if yes, does the toolchain need some additional
>>> work?
>> To give you a quick answer, I emailed the people who did the port.
>There apparently is a github repo with some of it and some is merged. I
>will dig through the emails and post the proper links.
>> One issue they mentioned was that the gdb port had many core/thread
>support that made it more than a simple port.
>From Jeremy Bennett:
>> piphany tool chain development runs on quite a tight budget, and its
>> GDB implementation is quite complex (it has to pretend cores are
>> threads, when they don't completely share an address space).  So we
>> haven't had the effort to devote to upstreaming.  And we were
>> reluctant to push the simulator upstream without a GDB implementation
>> to go with it.  You can of course access the code here:
>>   https://github.com/adapteva/epiphany-binutils-gdb
>> Epiphany GDB is still in quite substantial flux, due to the need to
>> support the Eclipse multicore visualizer with asynchronous and
>> non-stop support.
>The upstream gcc and newlib are OK. But since binutils and gdb are
>now in a single repo, it will need to come from the github site until
>it is merged upstream. And obviously patches just need to go upstream
>to whereever the code is. :)
>Jeremy also encouraged you to openly discuss things on their forums.
>He thought you would get good insight and advice there. And I don't
>doubt that.
>Thank you, I will.
>If it is a relatively low volume place, I may track it. But my email
>volume
>is already high and I don't have time to poke around on a bulletin
>board.
>> It will not have RTEMS as a target but that shouldn't be hard to
>address once we know where the master binutils, GCC, Newlib, and gdb
>are.
>So do you want me to try to build a toolchain and get you some starting
>patches?
>Sure that will definitely help as a starting point. And if you are so
>busy, you can just drop me HOWTO  instructions.
>> Then you are porting.
>>> Regards,
>>> Hesham
>> devel mailing list
>> devel at rtems.org
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel.sherrill at OARcorp.com        On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>Support Available                (256) 722-9985
