[PATCH 7/9] libcsupport: Avoid TOCTOU and format errors
Fri Nov 14 13:46:33 UTC 2014
 cpukit/libcsupport/src/pwdgrp.c           |  42 ++++++------
 testsuites/libtests/Makefile.am           |   1 +
 testsuites/libtests/configure.ac          |   1 +
 testsuites/libtests/pwdgrp01/Makefile.am  |  19 ++++++
 testsuites/libtests/pwdgrp01/init.c       | 107 ++++++++++++++++++++++++++++++
 testsuites/libtests/pwdgrp01/pwdgrp01.doc |  13 ++++
 testsuites/libtests/pwdgrp01/pwdgrp01.scn |   2 +
 7 files changed, 165 insertions(+), 20 deletions(-)
 create mode 100644 testsuites/libtests/pwdgrp01/Makefile.am
 create mode 100644 testsuites/libtests/pwdgrp01/init.c
 create mode 100644 testsuites/libtests/pwdgrp01/pwdgrp01.doc
 create mode 100644 testsuites/libtests/pwdgrp01/pwdgrp01.scn
diff --git a/cpukit/libcsupport/src/pwdgrp.c b/cpukit/libcsupport/src/pwdgrp.c
index c10cbab..a531b8b 100644
--- a/cpukit/libcsupport/src/pwdgrp.c
+++ b/cpukit/libcsupport/src/pwdgrp.c
@@ -39,40 +39,42 @@
 static pthread_once_t pwdgrp_once = PTHREAD_ONCE_INIT;
+static void init_file(const char *name, const char *content)
+  FILE *fp = fopen(name, "wx");
+  if (fp != NULL) {
+    fputs(content, fp);
+    fclose(fp);
  *  Initialize useable but dummy databases
 static void pwdgrp_init(void)
-  FILE *fp;
   mkdir("/etc", 0777);
    *  Initialize /etc/passwd
-  if ((fp = fopen("/etc/passwd", "r")) != NULL) {
-    fclose(fp);
-  else if ((fp = fopen("/etc/passwd", "w")) != NULL) {
-    fprintf(fp, "root:*:0:0:root::/:/bin/sh\n"
-                 "rtems:*:1:1:RTEMS Application::/:/bin/sh\n"
-                 "tty:!:2:2:tty owner::/:/bin/false\n" );
-    fclose(fp);
+  init_file(
+    "/etc/passwd",
+    "root:*:0:0:root::/:/bin/sh\n"
+      "rtems:*:1:1:RTEMS Application::/:/bin/sh\n"
+      "tty:!:2:2:tty owner::/:/bin/false\n"
    *  Initialize /etc/group
-  if ((fp = fopen("/etc/group", "r")) != NULL) {
-    fclose(fp);
-  else if ((fp = fopen("/etc/group", "w")) != NULL) {
-    fprintf( fp, "root:x:0:root\n"
-                 "rtems:x:1:rtems\n"
-                 "tty:x:2:tty\n" );
-    fclose(fp);
+  init_file(
+    "/etc/group",
+    "root:x:0:root\n"
+      "rtems:x:1:rtems\n"
+      "tty:x:2:tty\n"
 void _libcsupport_pwdgrp_init(void)
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 8475227..8e53204 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
 _SUBDIRS = POSIX
+_SUBDIRS += pwdgrp01
 _SUBDIRS += crypt01
 _SUBDIRS += sha01
 _SUBDIRS += i2c01
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 3882dcd..449a884 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -66,6 +66,7 @@ AS_IF([test x"$HAVE_LIBDL" = x"yes"],[
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+pwdgrp01/Makefile
 crypt01/Makefile
 sha01/Makefile
 i2c01/Makefile
diff --git a/testsuites/libtests/pwdgrp01/Makefile.am b/testsuites/libtests/pwdgrp01/Makefile.am
new file mode 100644
index 0000000..e624b26
--- /dev/null
+++ b/testsuites/libtests/pwdgrp01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = pwdgrp01
+pwdgrp01_SOURCES = init.c
+dist_rtems_tests_DATA = pwdgrp01.scn pwdgrp01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(pwdgrp01_OBJECTS)
+LINK_LIBS = $(pwdgrp01_LDLIBS)
+pwdgrp01$(EXEEXT): $(pwdgrp01_OBJECTS) $(pwdgrp01_DEPENDENCIES)
+	@rm -f pwdgrp01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/pwdgrp01/init.c b/testsuites/libtests/pwdgrp01/init.c
index 0000000..4c1f7ff
--- /dev/null
+++ b/testsuites/libtests/pwdgrp01/init.c
@@ -0,0 +1,107 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <sys/stat.h>
+#include <grp.h>
+#include <pwd.h>
+#include <stdio.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "PWDGRP 1";
+static void test(void)
+  const char passwd[] = "moop:foo:1:2:blob:a:b:c\n";
+  const char group[] = "blub:bar:3:moop\n";
+  int rv;
+  FILE *fp;
+  struct passwd pwd;
+  struct group grp;
+  struct passwd *pwd_res;
+  struct group *grp_res;
+  char buf[256];
+  rv = mkdir("/etc", 0777);
+  rtems_test_assert(rv == 0);
+  fp = fopen("/etc/passwd", "wx");
+  rtems_test_assert(fp != NULL);
+  rv = fputs(&passwd[0], fp);
+  rv = fclose(fp);
+  fp = fopen("/etc/group", "wx");
+  rv = fputs(&group[0], fp);
+  rv = fclose(fp);
+  rv = getpwnam_r("moop", &pwd, &buf[0], sizeof(buf), &pwd_res);
+  rtems_test_assert(&pwd == pwd_res);
+  rtems_test_assert(strcmp(pwd_res->pw_name, "moop") == 0);
+  rtems_test_assert(strcmp(pwd_res->pw_passwd, "foo") == 0);
+  rtems_test_assert(pwd_res->pw_uid == 1);
+  rtems_test_assert(pwd_res->pw_gid == 2);
+  rtems_test_assert(strcmp(pwd_res->pw_comment, "blob") == 0);
+  rtems_test_assert(strcmp(pwd_res->pw_gecos, "a") == 0);
+  rtems_test_assert(strcmp(pwd_res->pw_dir, "b") == 0);
+  rtems_test_assert(strcmp(pwd_res->pw_shell, "c") == 0);
+  rv = getgrnam_r("blub", &grp, &buf[0], sizeof(buf), &grp_res);
+  rtems_test_assert(&grp == grp_res);
+  rtems_test_assert(strcmp(grp_res->gr_name, "blub") == 0);
+  rtems_test_assert(strcmp(grp_res->gr_passwd, "bar") == 0);
+  rtems_test_assert(grp_res->gr_gid == 3);
+  rtems_test_assert(strcmp(grp_res->gr_mem[0], "moop") == 0);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/pwdgrp01/pwdgrp01.doc b/testsuites/libtests/pwdgrp01/pwdgrp01.doc
index 0000000..4570424
--- /dev/null
+++ b/testsuites/libtests/pwdgrp01/pwdgrp01.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: pwdgrp01
+directives:
+  - _libcsupport_pwdgrp_init
+  - getpwnam_r
+  - getgrnam_r
+concepts:
+  - Ensure that _libcsupport_pwdgrp_init() doesn't overwrite existing files.
diff --git a/testsuites/libtests/pwdgrp01/pwdgrp01.scn b/testsuites/libtests/pwdgrp01/pwdgrp01.scn
index 0000000..df47c67
--- /dev/null
+++ b/testsuites/libtests/pwdgrp01/pwdgrp01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST PWDGRP 1 ***
+*** END OF TEST PWDGRP 1 ***
1.8.4.5
