[PATCH 1/9] Add <sys/endian.h>
Sebastian Huber
Fri Nov 14 13:46:27 UTC 2014
cpukit/Makefile.am | 1 +
cpukit/include/sys/endian.h | 195 ++++++++++++++++++++++++++++++++++++++++++++
cpukit/preinstall.am | 4 +
3 files changed, 200 insertions(+)
create mode 100644 cpukit/include/sys/endian.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b9e9992..8f99983 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -61,6 +61,7 @@ include_sys_HEADERS += libcsupport/include/sys/ttycom.h
include_sys_HEADERS += libcsupport/include/sys/termios.h
include_sys_HEADERS += libcsupport/include/sys/utsname.h
+include_sys_HEADERS += include/sys/endian.h
include_sys_HEADERS += include/sys/uio.h
include_sys_HEADERS += include/sys/_iovec.h
include_sys_HEADERS += include/sys/priority.h
diff --git a/cpukit/include/sys/endian.h b/cpukit/include/sys/endian.h
new file mode 100644
index 0000000..abd6f01
--- /dev/null
+++ b/cpukit/include/sys/endian.h
@@ -0,0 +1,195 @@
+ * Copyright (c) 2002 Thomas Moestl <tmm at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_ENDIAN_H_
+#define _SYS_ENDIAN_H_
+#include <sys/cdefs.h>
+#include <rtems/endian.h>
+ * General byte order swapping functions.
+#define bswap16(x) CPU_swap_u16(x)
+#define bswap32(x) CPU_swap_u32(x)
+static __inline uint64_t
+bswap64(uint64_t v)
+#ifdef __GNUC__
+ return __builtin_bswap64(v);
+#else
+ return ((v >> 56) | ((v >> 40) & 0xff00) | ((v >> 24) & 0xff0000) |
+ ((v >> 8) & 0xff000000) | ((v << 8) & ((uint64_t)0xff << 32)) |
+ ((v << 24) & ((uint64_t)0xff << 40)) |
+ ((v << 40) & ((uint64_t)0xff << 48)) | ((v << 56)));
+#endif
+ * Host to big endian, host to little endian, big endian to host, and little
+ * endian to host byte order functions as detailed in byteorder(9).
+#if BYTE_ORDER == LITTLE_ENDIAN
+#define htobe16(x) bswap16((x))
+#define htobe32(x) bswap32((x))
+#define htobe64(x) bswap64((x))
+#define htole16(x) ((uint16_t)(x))
+#define htole32(x) ((uint32_t)(x))
+#define htole64(x) ((uint64_t)(x))
+#define be16toh(x) bswap16((x))
+#define be32toh(x) bswap32((x))
+#define be64toh(x) bswap64((x))
+#define le16toh(x) ((uint16_t)(x))
+#define le32toh(x) ((uint32_t)(x))
+#define le64toh(x) ((uint64_t)(x))
+#else /* BYTE_ORDER != LITTLE_ENDIAN */
+#define htobe16(x) ((uint16_t)(x))
+#define htobe32(x) ((uint32_t)(x))
+#define htobe64(x) ((uint64_t)(x))
+#define htole16(x) bswap16((x))
+#define htole32(x) bswap32((x))
+#define htole64(x) bswap64((x))
+#define be16toh(x) ((uint16_t)(x))
+#define be32toh(x) ((uint32_t)(x))
+#define be64toh(x) ((uint64_t)(x))
+#define le16toh(x) bswap16((x))
+#define le32toh(x) bswap32((x))
+#define le64toh(x) bswap64((x))
+#endif /* BYTE_ORDER == LITTLE_ENDIAN */
+/* Alignment-agnostic encode/decode bytestream to/from little/big endian. */
+static __inline uint16_t
+be16dec(const void *pp)
+ uint8_t const *p = (uint8_t const *)pp;
+ return ((p[0] << 8) | p[1]);
+static __inline uint32_t
+be32dec(const void *pp)
+ return (((unsigned)p[0] << 24) | (p[1] << 16) | (p[2] << 8) | p[3]);
+be64dec(const void *pp)
+ return (((uint64_t)be32dec(p) << 32) | be32dec(p + 4));
+le16dec(const void *pp)
+ return ((p[1] << 8) | p[0]);
+le32dec(const void *pp)
+ return (((unsigned)p[3] << 24) | (p[2] << 16) | (p[1] << 8) | p[0]);
+le64dec(const void *pp)
+ return (((uint64_t)le32dec(p + 4) << 32) | le32dec(p));
+static __inline void
+be16enc(void *pp, uint16_t u)
+ uint8_t *p = (uint8_t *)pp;
+ p[0] = (u >> 8) & 0xff;
+ p[1] = u & 0xff;
+be32enc(void *pp, uint32_t u)
+ p[0] = (u >> 24) & 0xff;
+ p[1] = (u >> 16) & 0xff;
+ p[2] = (u >> 8) & 0xff;
+ p[3] = u & 0xff;
+be64enc(void *pp, uint64_t u)
+ be32enc(p, (uint32_t)(u >> 32));
+ be32enc(p + 4, (uint32_t)(u & 0xffffffffU));
+le16enc(void *pp, uint16_t u)
+ p[0] = u & 0xff;
+ p[1] = (u >> 8) & 0xff;
+le32enc(void *pp, uint32_t u)
+ p[0] = u & 0xff;
+ p[2] = (u >> 16) & 0xff;
+ p[3] = (u >> 24) & 0xff;
+le64enc(void *pp, uint64_t u)
+ le32enc(p, (uint32_t)(u & 0xffffffffU));
+ le32enc(p + 4, (uint32_t)(u >> 32));
+#endif /* _SYS_ENDIAN_H_ */
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 4a6c25b..9268075 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -103,6 +103,10 @@ $(PROJECT_INCLUDE)/sys/utsname.h: libcsupport/include/sys/utsname.h $(PROJECT_IN
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/utsname.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/utsname.h
+$(PROJECT_INCLUDE)/sys/endian.h: include/sys/endian.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/endian.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/endian.h
$(PROJECT_INCLUDE)/sys/uio.h: include/sys/uio.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/uio.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/uio.h
1.8.4.5
