gdb patches to RBS
Fri Nov 14 15:18:32 UTC 2014
On 11/14/2014 5:27 AM, Jiri Gaisler wrote:
> On 11/14/2014 02:34 AM, Chris Johns wrote:
>> On 14/11/2014 9:12 am, Jiri Gaisler wrote:
>>> What is the procedure to add gdb patches to RBS?
>> Patches are first accepted by the RTEMS Project as the definition of the tools belongs to the project and tool packagers, ie the RSB, need to adopt that definition to get a project tick. Patches should be posted upstream where possible and then referenced from there. If the
>> upstream does not have a suitable method to reference patches we can add them to the rtems-tools.git repo under the tools directory. There are specific cases such as the openrisc tools where a specific github instance is referenced as we have a positive undertaking from that
>> community the tools are being merged upstream. Examples of upstream patch referencing is qemu and patchworks.
>> I do not see a patch management system for gdb. There was talk back in April of this year of gdb using patchworks and then something else however it seems to have died out.
>>> I have a few patches that fixes the erc32 simulator and also
>>> add support for leon2 and leon3. This would allow us to drop
>>> the sis bsp, and also to test the leon2 and leon3 bsp's with
>>> sis.
>> Excellent. I suggest you provide git patches for the rtems-tools.git repo to add the patches and then provide RSB patches for the sparc gdb build to use them. There are specific sparc patches already present which need updating as they are currently stopping us moving off gdb-7.7.
> The latest stable gdb version is 7.8.1, while the git head is at 7.8.50.20141112-cvs .
> Should we switch to gdb-7.8.1 or stay at 7.7? It does not really matter to me which
> one. The existing sparc gdb patch for 7.7 is merged into my patches as I had to
> rework it a bit.
> I will try to push my patches upstream to gdb but I suspect it will take
> while before the are accepted, as they are quite large.
It may take a while but realistically the only people who care about the
sparc simulator are RTEMS folks and AdaCore. And you are certainly
to be trusted for the patches.
Submit them.  And help the RSB switch to using all the newer patches.
Then we can get some test time on them. That's what the gdb folks
will want to hear.
We can move rtems sparc GDB to whereever it needs to be but the
gdb head is better for submissions and we should base the RSB
version on a release.
> Jiri.
> devel mailing list
> devel at rtems.org
