[PATCH 06/22] samples/fileio: Use unlimited objects
Tue Nov 18 14:37:12 UTC 2014
 testsuites/samples/fileio/system.h | 9 +--------
 1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index 8e3fa9e..a99c36d 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
@@ -44,9 +44,6 @@ rtems_task Init(
 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY  14
 #endif
-#define CONFIGURE_MAXIMUM_POSIX_KEYS             1
-#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  2
 #if FILEIO_BUILD
   #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
   #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS  2
@@ -61,18 +58,14 @@ rtems_task Init(
  * XXX: these values are higher than needed...
-#define CONFIGURE_MAXIMUM_TASKS             20
-#define CONFIGURE_MAXIMUM_SEMAPHORES        20
-#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES    20
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
 #define CONFIGURE_STACK_CHECKER_ENABLED
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_EXTRA_TASK_STACKS         (6 * RTEMS_MINIMUM_STACK_SIZE)
 #define CONFIGURE_MALLOC_STATISTICS
 #define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_UNLIMITED_OBJECTS
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
1.8.4.5
