[PATCH 21/22] shell: Add CMDLS, CMDCHOWN, CMDCHMOD commands
Tue Nov 18 14:37:27 UTC 2014
 cpukit/libmisc/Makefile.am           |   3 +
 cpukit/libmisc/shell/main_cmdchmod.c |  85 ++++++++++++++++
 cpukit/libmisc/shell/main_cmdchown.c | 106 ++++++++++++++++++++
 cpukit/libmisc/shell/main_cmdls.c    |  91 +++++++++++++++++
 cpukit/libmisc/shell/shellconfig.h   |  18 ++++
 doc/shell/general.t                  | 186 +++++++++++++++++++++++++++++++++++
 6 files changed, 489 insertions(+)
 create mode 100644 cpukit/libmisc/shell/main_cmdchmod.c
 create mode 100644 cpukit/libmisc/shell/main_cmdchown.c
 create mode 100644 cpukit/libmisc/shell/main_cmdls.c
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 021a251..0cc9851 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -112,6 +112,9 @@ libshell_a_SOURCES = shell/cat_file.c shell/cmds.c shell/internal.h \
     shell/main_lsof.c shell/main_edit.c \
     shell/main_blkstats.c \
     shell/shell-wait-for-input.c
+libshell_a_SOURCES += shell/main_cmdls.c
+libshell_a_SOURCES += shell/main_cmdchown.c
+libshell_a_SOURCES += shell/main_cmdchmod.c
 if LIBNETWORKING
 libshell_a_SOURCES += \
diff --git a/cpukit/libmisc/shell/main_cmdchmod.c b/cpukit/libmisc/shell/main_cmdchmod.c
new file mode 100644
index 0000000..ea125fd
--- /dev/null
+++ b/cpukit/libmisc/shell/main_cmdchmod.c
@@ -0,0 +1,85 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <errno.h>
+#include <stdio.h>
+#include <string.h>
+#include <unistd.h>
+#include <rtems/shellconfig.h>
+#include <rtems/stringto.h>
+#include "internal.h"
+static int usage(void)
+  puts(rtems_shell_CMDCHMOD_Command.usage);
+  return -1;
+static void error(const char *s, int eno)
+  printf("%s: %s\n", s, strerror(eno));
+static int rtems_shell_main_cmdchmod(int argc, char **argv)
+  if (argc >= 2) {
+    unsigned long mode;
+    rtems_status_code sc;
+    uid_t task_uid;
+    int i;
+    sc = rtems_string_to_unsigned_long(argv[1], &mode, NULL, 8);
+    if (sc != RTEMS_SUCCESSFUL) {
+      return usage();
+    task_uid = getuid();
+    for (i = 2; i < argc; ++i) {
+      const char *cmd = argv[i];
+      rtems_shell_cmd_t *shell_cmd = rtems_shell_lookup_cmd(cmd);
+      if (shell_cmd != NULL) {
+        if (task_uid == 0 || task_uid == shell_cmd->uid) {
+          shell_cmd->mode = mode
+            & (S_IRUSR | S_IXUSR | S_IRGRP | S_IXGRP | S_IROTH | S_IXOTH);
+        } else if (rtems_shell_can_see_cmd(shell_cmd)) {
+          error(cmd, EACCES);
+        } else {
+          error(cmd, ENOENT);
+      } else {
+  } else {
+    return usage();
+  return 0;
+rtems_shell_cmd_t rtems_shell_CMDCHMOD_Command = {
+  .name = "cmdchmod",
+  .usage = "cmdchmod OCTAL-MODE COMMAND...",
+  .topic = "misc",
+  .command = rtems_shell_main_cmdchmod
diff --git a/cpukit/libmisc/shell/main_cmdchown.c b/cpukit/libmisc/shell/main_cmdchown.c
index 0000000..9cc8c44
--- /dev/null
+++ b/cpukit/libmisc/shell/main_cmdchown.c
@@ -0,0 +1,106 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <stdio.h>
+  puts(rtems_shell_CMDCHOWN_Command.usage);
+  return -1;
+static int rtems_shell_main_cmdchown(int argc, char **argv)
+  if (argc >= 2) {
+    const char *s = argv[1];
+    unsigned new_uid = UINT_MAX;
+    unsigned new_gid = UINT_MAX;
+    bool change_uid = false;
+    bool change_gid = false;
+    uid_t task_uid;
+    int i;
+    if (strcmp(s, ":") != 0) {
+      int n = sscanf(argv[1], "%u:%u", &new_uid, &new_gid);
+      if (n == 2) {
+        change_uid = true;
+        change_gid = true;
+      } else if (n == 1) {
+      } else {
+        n = sscanf(argv[1], ":%u", &new_gid);
+        if (n == 1) {
+        } else {
+          return usage();
+          if (change_uid) {
+            shell_cmd->uid = new_uid;
+          if (change_gid) {
+            shell_cmd->gid = new_gid;
+        } else {
+      } else {
+  } else {
+    return usage();
+  return 0;
+rtems_shell_cmd_t rtems_shell_CMDCHOWN_Command = {
+  .name = "cmdchown",
+  .usage = "cmdchown [OWNER][:[GROUP]] COMMAND...",
+  .topic = "misc",
+  .command = rtems_shell_main_cmdchown
diff --git a/cpukit/libmisc/shell/main_cmdls.c b/cpukit/libmisc/shell/main_cmdls.c
index 0000000..f08925c
--- /dev/null
+++ b/cpukit/libmisc/shell/main_cmdls.c
@@ -0,0 +1,91 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <stdio.h>
+static void print_cmd(const rtems_shell_cmd_t *shell_cmd)
+  if (rtems_shell_can_see_cmd(shell_cmd)) {
+    mode_t m = shell_cmd->mode;
+    printf(
+      "%c%c%c%c%c%c%c%c%c %5u %5u %s\n",
+      (m & S_IRUSR) != 0 ? 'r' : '-',
+      (m & S_IWUSR) != 0 ? 'w' : '-',
+      (m & S_IXUSR) != 0 ? 'x' : '-',
+      (m & S_IRGRP) != 0 ? 'r' : '-',
+      (m & S_IWGRP) != 0 ? 'w' : '-',
+      (m & S_IXGRP) != 0 ? 'x' : '-',
+      (m & S_IROTH) != 0 ? 'r' : '-',
+      (m & S_IWOTH) != 0 ? 'w' : '-',
+      (m & S_IXOTH) != 0 ? 'x' : '-',
+      (unsigned) shell_cmd->uid,
+      (unsigned) shell_cmd->gid,
+      shell_cmd->name
+static int rtems_shell_main_cmdls(int argc, char **argv)
+  const rtems_shell_cmd_t *shell_cmd;
+  if (argc <= 1) {
+    shell_cmd = rtems_shell_first_cmd;
+    while (shell_cmd != NULL) {
+      print_cmd(shell_cmd);
+      shell_cmd = shell_cmd->next;
+  } else {
+    int i;
+    for (i = 1; i < argc; ++i) {
+      shell_cmd = rtems_shell_lookup_cmd(cmd);
+      } else {
+  return 0;
+rtems_shell_cmd_t rtems_shell_CMDLS_Command = {
+  .name = "cmdls",
+  .usage = "cmdls COMMAND...",
+  .topic = "misc",
+  .command = rtems_shell_main_cmdls
diff --git a/cpukit/libmisc/shell/shellconfig.h b/cpukit/libmisc/shell/shellconfig.h
index c5fced3..cc2165b 100644
--- a/cpukit/libmisc/shell/shellconfig.h
+++ b/cpukit/libmisc/shell/shellconfig.h
@@ -24,6 +24,9 @@
 extern rtems_shell_cmd_t rtems_shell_HELP_Command;
 extern rtems_shell_cmd_t rtems_shell_ALIAS_Command;
 extern rtems_shell_cmd_t rtems_shell_TIME_Command;
+extern rtems_shell_cmd_t rtems_shell_CMDLS_Command;
+extern rtems_shell_cmd_t rtems_shell_CMDCHOWN_Command;
+extern rtems_shell_cmd_t rtems_shell_CMDCHMOD_Command;
 extern rtems_shell_cmd_t rtems_shell_LOGOFF_Command;
 extern rtems_shell_cmd_t rtems_shell_SETENV_Command;
 extern rtems_shell_cmd_t rtems_shell_GETENV_Command;
@@ -162,6 +165,21 @@ extern rtems_shell_alias_t * const rtems_shell_Initial_aliases[];
      *  Common commands that can be optional
     #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
+         !defined(CONFIGURE_SHELL_NO_COMMAND_CMDLS)) || \
+        defined(CONFIGURE_SHELL_COMMAND_CMDLS)
+      &rtems_shell_CMDLS_Command,
+    #endif
+    #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
+         !defined(CONFIGURE_SHELL_NO_COMMAND_CMDCHOWN)) || \
+        defined(CONFIGURE_SHELL_COMMAND_CMDCHOWN)
+      &rtems_shell_CMDCHOWN_Command,
+    #endif
+         !defined(CONFIGURE_SHELL_NO_COMMAND_CMDCHMOD)) || \
+        defined(CONFIGURE_SHELL_COMMAND_CMDCHMOD)
+      &rtems_shell_CMDCHMOD_Command,
+    #endif
          !defined(CONFIGURE_SHELL_NO_COMMAND_JOEL)) || \
         defined(CONFIGURE_SHELL_COMMAND_JOEL)
       &rtems_shell_JOEL_Command,
diff --git a/doc/shell/general.t b/doc/shell/general.t
index c0df5c1..ce8a5bb 100644
--- a/doc/shell/general.t
+++ b/doc/shell/general.t
@@ -13,6 +13,9 @@ The RTEMS shell has the following general commands:
 @item @code{help} - Print command help
 @item @code{alias} - Add alias for an existing command
+ at item @code{cmdls} - List commands
+ at item @code{cmdchown} - Change user or owner of commands
+ at item @code{cmdchmod} - Change mode of commands
 @item @code{date} - Print or set current date and time
 @item @code{echo} - Produce message in a shell script
 @item @code{sleep} - Delay for a specified amount of time
@@ -196,6 +199,189 @@ extern rtems_shell_cmd_t rtems_shell_ALIAS_Command;
 @c
 @c
 @page
+ at subsection cmdls - List commands
+ at pgindex cmdls
+ at subheading SYNOPSYS:
+ at example
+cmdls COMMAND...
+ at end example
+ at subheading DESCRIPTION:
+This command lists the visible commands of the command set.
+ at subheading EXIT STATUS:
+This command returns 0 on success and non-zero if an error is encountered.
+ at subheading NOTES:
+The current user must have read permission to list a command.
+ at subheading EXAMPLES:
+The following is an example of how to use @code{cmdls}:
+ at example
+SHLL [/] # cmdls help shutdown
+r-xr-xr-x     0     0 help
+r-x------     0     0 shutdown
+ at end example
+ at subheading CONFIGURATION:
+ at findex CONFIGURE_SHELL_NO_COMMAND_CMDLS
+ at findex CONFIGURE_SHELL_COMMAND_CMDLS
+This command is included in the default shell command set.
+When building a custom command set, define
+ at code{CONFIGURE_SHELL_COMMAND_CMDLS} to have this
+command included.
+This command can be excluded from the shell command set by
+defining @code{CONFIGURE_SHELL_NO_COMMAND_CMDLS} when all
+shell commands have been configured.
+ at subheading PROGRAMMING INFORMATION:
+The configuration structure for the @code{cmdls} has the
+following prototype:
+ at example
+ at end example
+ at c
+ at c
+ at c
+ at page
+ at subsection cmdchown - Change user or owner of commands
+ at pgindex cmdchown
+ at example
+cmdchown [OWNER][:[GROUP]] COMMAND...
+ at end example
+This command changes the user or owner of a command.
+The current user must have an UID of zero or be the command owner to change the
+owner or group.
+The following is an example of how to use @code{cmdchown}:
+ at example
+[/] # cmdls help
+r-xr-xr-x     0     0 help
+[/] # cmdchown 1:1 help
+[/] # cmdls help
+r--r--r--     1     1 help
+ at end example
+ at findex CONFIGURE_SHELL_NO_COMMAND_CMDCHOWN
+ at findex CONFIGURE_SHELL_COMMAND_CMDCHOWN
+ at code{CONFIGURE_SHELL_COMMAND_CMDCHOWN} to have this
+command included.
+defining @code{CONFIGURE_SHELL_NO_COMMAND_CMDCHOWN} when all
+The configuration structure for the @code{cmdchown} has the
+ at example
+ at end example
+ at c
+ at c
+ at c
+ at page
+ at subsection cmdchmod - Change mode of commands
+ at pgindex cmdchmod
+ at example
+cmdchmod OCTAL-MODE COMMAND...
+ at end example
+This command changes the mode of a command.
+mode.
+The following is an example of how to use @code{cmdchmod}:
+ at example
+[/] # cmdls help
+r-xr-xr-x     0     0 help
+[/] # cmdchmod 544 help
+[/] # cmdls help
+r-xr--r--     0     0 help
+ at end example
+ at findex CONFIGURE_SHELL_NO_COMMAND_CMDCHMOD
+ at findex CONFIGURE_SHELL_COMMAND_CMDCHMOD
+ at code{CONFIGURE_SHELL_COMMAND_CMDCHMOD} to have this
+command included.
+defining @code{CONFIGURE_SHELL_NO_COMMAND_CMDCHMOD} when all
+The configuration structure for the @code{cmdchmod} has the
+ at example
+ at end example
+ at c
+ at c
+ at c
+ at page
 @subsection date - print or set current date and time
 @pgindex date
1.8.4.5
