[PATCH 18/22] shell: Inherit UID and GID if no login check
Tue Nov 18 14:37:24 UTC 2014
Use the UID and GID of the executing user for the real and effective UID
and GID of the shell task in case no login check is present.  This
prevents privilege escalation via shell scripts.
 cpukit/libmisc/shell/shell.c |  8 ++++++++
 cpukit/libmisc/shell/shell.h | 13 +++++++++++++
 2 files changed, 21 insertions(+)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 5b74257..14d4b5f 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -838,6 +838,12 @@ bool rtems_shell_main_loop(
         if (shell_env->login_check != NULL) {
           result = rtems_shell_login(shell_env, stdin,stdout);
         } else {
+          setuid(shell_env->uid);
+          setgid(shell_env->gid);
+          seteuid(shell_env->uid);
+          setegid(shell_env->gid);
+          rtems_current_user_env_getgroups();
           result = true;
@@ -1010,6 +1016,8 @@ static rtems_status_code rtems_shell_run (
   shell_env->output_append = output_append;
   shell_env->wake_on_end   = wake_on_end;
   shell_env->login_check   = login_check;
+  shell_env->uid           = getuid();
+  shell_env->gid           = getgid();
   getcwd(shell_env->cwd, sizeof(shell_env->cwd));
diff --git a/cpukit/libmisc/shell/shell.h b/cpukit/libmisc/shell/shell.h
index 726a8ee..c137378 100644
--- a/cpukit/libmisc/shell/shell.h
+++ b/cpukit/libmisc/shell/shell.h
@@ -17,6 +17,7 @@
 #ifndef __RTEMS_SHELL_H__
 #define __RTEMS_SHELL_H__
+#include <sys/types.h>
 #include <termios.h>
@@ -199,6 +200,18 @@ typedef struct {
   bool output_append;
   rtems_id wake_on_end;
   rtems_shell_login_check_t login_check;
+   * @brief The real and effective UID of the shell task in case no login check
+   * is present.
+  uid_t uid;
+   * @brief The real and effective GID of the shell task in case no login check
+   * is present.
+  gid_t gid;
 } rtems_shell_env_t;
1.8.4.5
