Access Control for RTEMS Shell
    Gedare Bloom
    gedare at rtems.org
    Tue Nov 18 15:12:04 UTC 2014
Could you briefly explain a bit more context about the goals for
implementing access control? That is, is it for compliance to some
standard, to address a security need, or something else?
Thanks,
Gedare
On Tue, Nov 18, 2014 at 9:37 AM, Sebastian Huber
> This patch set adds access control to the RTEMS shell.  The command visibility
> and ability to execute are determined by the current user environment and per
> command mode, UID and GID values.  The user environment is set up by the
> rtems_shell_login_check() handler.  Commands to alter the mode, UID and GID of
> commands are added.
> devel mailing list
> devel at rtems.org
