RTEMS Rehosting Update
Hesham Moustafa
heshamelmatary at gmail.com
Wed Nov 19 17:41:26 UTC 2014
Hi,
On Wed, Nov 19, 2014 at 5:01 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Hi
> I am sure you all have noticed that the RTEMS Project has had
> a lot of services offline for the past week. This has been part
> of a rehosting and improvement effort that simply took longer
> than anyone expected.
> At this point, most of the services are back online at the
> Oregon State University Open Source Laboratory (OSUOSL).
> This is a big leap in infrastructure and network bandwidth
> but it came with some growing pains. We plan to integrate
> both a web based patch submission and review system and
> a continuous testing system once this first round settles.
> At this point,
> + www.rtems.org is alive there. (accept the certificate)
> + mailing lists never went down. They had been relocated
> months ago.
This one is still down for me even after I accept the certificate.
> + git.rtems.org stayed alive for read only.
> - developer access is now via dispatch.rtems.org and
> will be up once the integration with Trac, github, and
> mailing lists is fully tested.
> + devel.rtems.org hosts a Trac implementation which
> replaces Mediawiki and Bugzilla. This should be back
> online when git write access is up.
> + IRC bot is still running on the old rtems.org and logs
> will transfer in the near future to the new host.
> Full version of the news at: https://www.rtems.org/node/116
> I am sure I missed something even in the full news write up.
> Please ask questions and politely report links and services that
> look broken.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141119/c15107a1/attachment.html>
