[PATCH] more data structures public in mongoose.h
Wed Nov 19 19:24:01 UTC 2014
Hi Ben,
Due to the license change, we can consider our version of Mongoose as
"RTEMS Project" maintained for now. I don't know if anyone is
maintaining a fork with an appropriate license.
Moving the struct definitions to the header file is sensible, although
the usual caveat is that users might have namespace conflicts.
Gedare
On Wed, Nov 19, 2014 at 1:16 PM, Ben Gras <beng at shrike-systems.com> wrote:
> The attached patch is a proposed solution to a problem I am having with
> interfacing with the mongoose httpd for which I've found no canonical (or
> any other) clean solution.
> The problem is that some of the data structures needed for some operations,
> specifically writing callbacks that get invoked for some HTTP requests, are
> declared in mongoose.c and therefore are not available to external programs,
> i.e. clients of mongoose. This is the mg_connection struct & its
> dependencies. It is passed as an argument to callbacks, and even without
> referencing the object the code won't compile if the struct isn't fully
> known.
> The change is moving some declarations from mongoose.c to mongoose.h.
> Unfortunately this diverges from the original code, then again mongoose
> isn't tracked any more since the license change I take it, so perhaps that's
> not so bad. I've made the changes __rtems__-conditional so it's clear where
> the divergence is.
> devel mailing list
> devel at rtems.org
