[PATCH 2/4] sys/mman.h: New file. Clean up and add supporting stubs
Wed Nov 19 19:59:46 UTC 2014
	* Makefile.am updated and preinstall.am regenerated.
	* mprotect.c had a prototype removed now that we have mman.h
	* mmap.c, munmap.c: New stub files.
 cpukit/posix/Makefile.am        |   5 ++
 cpukit/posix/include/sys/mman.h | 189 ++++++++++++++++++++++++++++++++++++++++
 cpukit/posix/preinstall.am      |   9 ++
 cpukit/posix/src/mmap.c         |  26 ++++++
 cpukit/posix/src/mprotect.c     |  10 +--
 cpukit/posix/src/munmap.c       |  30 +++++++
 6 files changed, 261 insertions(+), 8 deletions(-)
 create mode 100644 cpukit/posix/include/sys/mman.h
 create mode 100644 cpukit/posix/src/mmap.c
 create mode 100644 cpukit/posix/src/munmap.c
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 346b65a..b3be07c 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -21,6 +21,9 @@ include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/config.h
 include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
+include_sysdir = $(includedir)/sys
+include_sys_HEADERS = include/sys/mman.h
 if HAS_PTHREADS
 # include
 include_HEADERS = include/aio.h
@@ -91,7 +94,9 @@ libposix_a_SOURCES += src/cond.c src/condattrdestroy.c \
     src/condtimedwait.c src/condwait.c src/condwaitsupp.c src/condget.c
 ## MEMORY_C_FILES
+libposix_a_SOURCES += src/mmap.c
 libposix_a_SOURCES += src/mprotect.c
+libposix_a_SOURCES += src/munmap.c
 ## MESSAGE_QUEUE_C_FILES
 libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
diff --git a/cpukit/posix/include/sys/mman.h b/cpukit/posix/include/sys/mman.h
new file mode 100644
index 0000000..ddf34cc
--- /dev/null
+++ b/cpukit/posix/include/sys/mman.h
@@ -0,0 +1,189 @@
+/*	$NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $	*/
+ * Copyright (c) 1982, 1986, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)mman.h	8.2 (Berkeley) 1/9/95
+#ifndef _SYS_MMAN_H_
+#define _SYS_MMAN_H_
+#ifdef __rtems__
+#include <inttypes.h>
+#include <stddef.h>
+#include <sys/types.h>
+#else /* __rtems__ */
+#include <sys/featuretest.h>
+#include <machine/ansi.h>
+#ifdef	_BSD_SIZE_T_
+typedef	_BSD_SIZE_T_	size_t;
+#undef	_BSD_SIZE_T_
+#endif
+#include <sys/ansi.h>
+#ifndef	mode_t
+typedef	__mode_t	mode_t;
+#define	mode_t		__mode_t
+#endif
+#ifndef	off_t
+typedef	__off_t		off_t;		/* file offset */
+#define	off_t		__off_t
+#endif
+#endif /* __rtems__ */
+ * Protections are chosen from these bits, or-ed together
+#define	PROT_NONE	0x00	/* no permissions */
+#define	PROT_READ	0x01	/* pages can be read */
+#define	PROT_WRITE	0x02	/* pages can be written */
+#define	PROT_EXEC	0x04	/* pages can be executed */
+ * Flags contain sharing type and options.
+ * Sharing types; choose one.
+#define	MAP_SHARED	0x0001	/* share changes */
+#define	MAP_PRIVATE	0x0002	/* changes are private */
+#ifdef _KERNEL
+ * Deprecated flag; these are treated as MAP_PRIVATE internally by
+ * the kernel.
+#define	MAP_COPY	0x0004	/* "copy" region at mmap time */
+#endif
+ * Other flags
+#define	MAP_FIXED	 0x0010	/* map addr must be exactly as requested */
+#define	MAP_RENAME	 0x0020	/* Sun: rename private pages to file */
+#define	MAP_NORESERVE	 0x0040	/* Sun: don't reserve needed swap area */
+#define	MAP_INHERIT	 0x0080	/* region is retained after exec */
+#define	MAP_HASSEMAPHORE 0x0200	/* region may contain semaphores */
+#define	MAP_TRYFIXED     0x0400 /* attempt hint address, even within break */
+#define	MAP_WIRED	 0x0800	/* mlock() mapping when it is established */
+ * Mapping type
+#define	MAP_FILE	0x0000	/* map from file (default) */
+#define	MAP_ANON	0x1000	/* allocated from memory, swap space */
+ * Alignment (expressed in log2).  Must be >= log2(PAGE_SIZE) and
+ * < # bits in a pointer (26 (acorn26), 32 or 64).
+#define	MAP_ALIGNED(n)		((n) << MAP_ALIGNMENT_SHIFT)
+#define	MAP_ALIGNMENT_SHIFT	24
+#define	MAP_ALIGNMENT_MASK	MAP_ALIGNED(0xff)
+#define	MAP_ALIGNMENT_64KB	MAP_ALIGNED(16)	/* 2^16 */
+#define	MAP_ALIGNMENT_16MB	MAP_ALIGNED(24)	/* 2^24 */
+#define	MAP_ALIGNMENT_4GB	MAP_ALIGNED(32)	/* 2^32 */
+#define	MAP_ALIGNMENT_1TB	MAP_ALIGNED(40)	/* 2^40 */
+#define	MAP_ALIGNMENT_256TB	MAP_ALIGNED(48)	/* 2^48 */
+#define	MAP_ALIGNMENT_64PB	MAP_ALIGNED(56)	/* 2^56 */
+ * Error indicator returned by mmap(2)
+#define	MAP_FAILED	((void *) -1)	/* mmap() failed */
+ * Flags to msync
+#define	MS_ASYNC	0x01	/* perform asynchronous writes */
+#define	MS_INVALIDATE	0x02	/* invalidate cached data */
+#define	MS_SYNC		0x04	/* perform synchronous writes */
+ * Flags to mlockall
+#define	MCL_CURRENT	0x01	/* lock all pages currently mapped */
+#define	MCL_FUTURE	0x02	/* lock all pages mapped in the future */
+#if defined(_NETBSD_SOURCE)
+ * Advice to madvise
+#define	MADV_NORMAL	0	/* no further special treatment */
+#define	MADV_RANDOM	1	/* expect random page references */
+#define	MADV_SEQUENTIAL	2	/* expect sequential page references */
+#define	MADV_WILLNEED	3	/* will need these pages */
+#define	MADV_DONTNEED	4	/* dont need these pages */
+#define	MADV_SPACEAVAIL	5	/* insure that resources are reserved */
+#define	MADV_FREE	6	/* pages are empty, free them */
+ * Flags to minherit
+#define	MAP_INHERIT_SHARE	0	/* share with child */
+#define	MAP_INHERIT_COPY	1	/* copy into child */
+#define	MAP_INHERIT_NONE	2	/* absent from child */
+#define	MAP_INHERIT_DONATE_COPY	3	/* copy and delete -- not
+					   implemented in UVM */
+#define	MAP_INHERIT_DEFAULT	MAP_INHERIT_COPY
+#endif
+#ifndef _KERNEL
+#include <sys/cdefs.h>
+__BEGIN_DECLS
+void   *mmap(void *, size_t, int, int, int, off_t);
+int	munmap(void *, size_t);
+int	mprotect(void *, size_t, int);
+#ifndef __LIBC12_SOURCE__
+#if defined(__rtems__)
+int	msync(void *, size_t, int);
+#else
+int	msync(void *, size_t, int) __RENAME(__msync13);
+#endif
+#endif
+int	mlock(const void *, size_t);
+int	munlock(const void *, size_t);
+int	mlockall(int);
+int	munlockall(void);
+int	madvise(void *, size_t, int);
+int	mincore(void *, size_t, char *);
+int	minherit(void *, size_t, int);
+#endif
+__END_DECLS
+#endif /* !_KERNEL */
+#endif /* !_SYS_MMAN_H_ */
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 6e3f2a2..1b65213 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -43,6 +43,15 @@ $(PROJECT_INCLUDE)/rtems/posix/posixapi.h: include/rtems/posix/posixapi.h $(PROJ
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
+$(PROJECT_INCLUDE)/sys/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/sys
+	@: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/sys/$(dirstamp)
+$(PROJECT_INCLUDE)/sys/mman.h: include/sys/mman.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/mman.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/mman.h
 if HAS_PTHREADS
 $(PROJECT_INCLUDE)/aio.h: include/aio.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/aio.h
diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
index 0000000..2798326
--- /dev/null
+++ b/cpukit/posix/src/mmap.c
@@ -0,0 +1,26 @@
+ * @file
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/mman.h>
+int munmap(
+  void   *addr __attribute__((unused)),
+  size_t  length __attribute__((unused))
+  return -1;
diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
index 51b565e..94bd316 100644
--- a/cpukit/posix/src/mprotect.c
+++ b/cpukit/posix/src/mprotect.c
@@ -28,16 +28,10 @@
 #endif
 #include <unistd.h>
- * RTEMS does not have <sys/mman.h> so we need a prototype here to
- * avoid warnings.
-int mprotect( const void *, size_t, int );
 int mprotect(
-  const void *addr __attribute__((unused)),
   size_t len __attribute__((unused)),
   int prot __attribute__((unused)) )
diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
index 0000000..3ebb2f4
--- /dev/null
+++ b/cpukit/posix/src/munmap.c
@@ -0,0 +1,30 @@
+ * @file
+#if HAVE_CONFIG_H
+#endif
+void *mmap(
+  size_t  lenhth __attribute__((unused)),
+  int     prot __attribute__((unused)),
+  int     flags __attribute__((unused)),
+  int     fildes __attribute__((unused)),
+  off_t   off
+  return NULL;
1.9.3
