[PATCH 4/4] libtests/malloctest/init.c: Fix warning
Wed Nov 19 19:59:48 UTC 2014
posix_memalign() is prototyped to take a non-NULL parameter. But our
test is deliberately passing one in. With the -Wnon-null warning flag
enabled, we will always get warnings on this test unless we disable
that warning for this single test case.
 testsuites/libtests/malloctest/init.c | 24 ++++++++++--------------
 1 file changed, 10 insertions(+), 14 deletions(-)
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index 0d95e3b..d95e434 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -1,17 +1,5 @@
-/*  Init
- *  This routine is the initialization task for this test program.
- *  It is a user initialization task and has the responsibility for creating
- *  and starting the tasks that make up the test.  If the time of day
- *  clock is required for the test, it should also be set to a known
- *  value by this function.
- *  Input parameters:
- *    argument - task argument
- *  Output parameters:  NONE
- *  COPYRIGHT (c) 1989-2011.
+ *  COPYRIGHT (c) 1989-2011, 2014.
  *  On-Line Applications Research Corporation (OAR).
  *  Copyright (c) 2009, 2010 embedded brains GmbH.
@@ -1188,9 +1176,17 @@ static void test_posix_memalign(void)
   int sc;
   int maximumShift;
+   * posix_memalign() is declared as never having a NULL first parameter.
+   * We need to explicitly disable this compiler warning to make this code
+   * warning free.
+  #pragma GCC diagnostic push
+  #pragma GCC diagnostic ignored "-Wnonnull"
   puts( "posix_memalign - NULL return pointer -- EINVAL" );
   sc = posix_memalign( NULL, 32, 8 );
   fatal_posix_service_status( sc, EINVAL, "posix_memalign NULL pointer" );
+  #pragma GCC diagnostic pop
   puts( "posix_memalign - alignment of 0 -- EINVAL" );
   sc = posix_memalign( &p1, 0, 8 );
1.9.3
