Access Control for RTEMS Shell
Peter Dufault dufault at hda.com
Wed Nov 19 22:54:21 UTC 2014
Are the UID and GID per-thread?  I assume two different telnet sessions would have different credentials.
I strongly agree that there is a need for credentials in embedded applications, but I don't see that they can be tied to the RTEMS shell.  I'm not sure how UID and GID work in a single process POSIX thread environment and the little google searching I did ended up with Linux extensions.
Do the credentials apply to file opens or message queue opens?
> On Nov 19, 2014, at 02:20 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> The goal is to provide different command sets for different users. For
> example a system could give the customer a certain command set and the
> service personal a different one which includes also maintenance operations.
> Most of the infrastructure was already present.  There were just some
> missing links in between.
> On 18/11/14 16:11, Gedare Bloom wrote:
>> Could you briefly explain a bit more context about the goals for
>> implementing access control? That is, is it for compliance to some
>> standard, to address a security need, or something else?
>> Thanks,
>> Gedare
>> On Tue, Nov 18, 2014 at 9:37 AM, Sebastian Huber
>>> This patch set adds access control to the RTEMS shell.  The command visibility
>>> and ability to execute are determined by the current user environment and per
>>> command mode, UID and GID values.  The user environment is set up by the
>>> rtems_shell_login_check() handler.  Commands to alter the mode, UID and GID of
>>> commands are added.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
