[PATCH 2/4] sys/mman.h: New file. Clean up and add supporting stubs
Thu Nov 20 02:31:46 UTC 2014
OK great
On Wed, Nov 19, 2014 at 5:04 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 11/19/2014 2:55 PM, Gedare Bloom wrote:
>> Is this the same one that Chris has had in use before? (I think that
>> is who had one in use..)
> Yes. You wanted it in rtems to avoid me having to add a prototype to a file
> to avoid a warning.
> I didn't integrate his implementation but only his .h file and stubs. His
> implementation will need the addition of tests and code in confdefs.h.
> --joel
>> -Gedare
>> On Wed, Nov 19, 2014 at 2:59 PM, Joel Sherrill
>>>         * Makefile.am updated and preinstall.am regenerated.
>>>         * mprotect.c had a prototype removed now that we have mman.h
>>>         * mmap.c, munmap.c: New stub files.
>>>  cpukit/posix/Makefile.am        |   5 ++
>>>  cpukit/posix/include/sys/mman.h | 189 ++++++++++++++++++++++++++++++++++++++++
>>>  cpukit/posix/preinstall.am      |   9 ++
>>>  cpukit/posix/src/mmap.c         |  26 ++++++
>>>  cpukit/posix/src/mprotect.c     |  10 +--
>>>  cpukit/posix/src/munmap.c       |  30 +++++++
>>>  6 files changed, 261 insertions(+), 8 deletions(-)
>>>  create mode 100644 cpukit/posix/include/sys/mman.h
>>>  create mode 100644 cpukit/posix/src/mmap.c
>>>  create mode 100644 cpukit/posix/src/munmap.c
>>> diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
>>> index 346b65a..b3be07c 100644
>>> --- a/cpukit/posix/Makefile.am
>>> +++ b/cpukit/posix/Makefile.am
>>> @@ -21,6 +21,9 @@ include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
>>>  include_rtems_posix_HEADERS += include/rtems/posix/config.h
>>>  include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
>>> +include_sysdir = $(includedir)/sys
>>> +include_sys_HEADERS = include/sys/mman.h
>>>  if HAS_PTHREADS
>>>  # include
>>>  include_HEADERS = include/aio.h
>>> @@ -91,7 +94,9 @@ libposix_a_SOURCES += src/cond.c src/condattrdestroy.c \
>>>      src/condtimedwait.c src/condwait.c src/condwaitsupp.c src/condget.c
>>>  ## MEMORY_C_FILES
>>> +libposix_a_SOURCES += src/mmap.c
>>>  libposix_a_SOURCES += src/mprotect.c
>>> +libposix_a_SOURCES += src/munmap.c
>>>  ## MESSAGE_QUEUE_C_FILES
>>>  libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
>>> diff --git a/cpukit/posix/include/sys/mman.h b/cpukit/posix/include/sys/mman.h
>>> new file mode 100644
>>> index 0000000..ddf34cc
>>> --- /dev/null
>>> +++ b/cpukit/posix/include/sys/mman.h
>>> @@ -0,0 +1,189 @@
>>> +/*     $NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $       */
>>> + * Copyright (c) 1982, 1986, 1993
>>> + *     The Regents of the University of California.  All rights reserved.
>>> + * Redistribution and use in source and binary forms, with or without
>>> + * modification, are permitted provided that the following conditions
>>> + * are met:
>>> + * 1. Redistributions of source code must retain the above copyright
>>> + *    notice, this list of conditions and the following disclaimer.
>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>> + *    notice, this list of conditions and the following disclaimer in the
>>> + *    documentation and/or other materials provided with the distribution.
>>> + * 3. Neither the name of the University nor the names of its contributors
>>> + *    may be used to endorse or promote products derived from this software
>>> + *    without specific prior written permission.
>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>>> + * SUCH DAMAGE.
>>> + *     @(#)mman.h      8.2 (Berkeley) 1/9/95
>>> +#ifndef _SYS_MMAN_H_
>>> +#define _SYS_MMAN_H_
>>> +#ifdef __rtems__
>>> +#include <inttypes.h>
>>> +#include <stddef.h>
>>> +#include <sys/types.h>
>>> +#else /* __rtems__ */
>>> +#include <sys/featuretest.h>
>>> +#include <machine/ansi.h>
>>> +#ifdef _BSD_SIZE_T_
>>> +typedef        _BSD_SIZE_T_    size_t;
>>> +#undef _BSD_SIZE_T_
>>> +#endif
>>> +#include <sys/ansi.h>
>>> +#ifndef        mode_t
>>> +typedef        __mode_t        mode_t;
>>> +#define        mode_t          __mode_t
>>> +#endif
>>> +#ifndef        off_t
>>> +typedef        __off_t         off_t;          /* file offset */
>>> +#define        off_t           __off_t
>>> +#endif
>>> +#endif /* __rtems__ */
>>> + * Protections are chosen from these bits, or-ed together
>>> +#define        PROT_NONE       0x00    /* no permissions */
>>> +#define        PROT_READ       0x01    /* pages can be read */
>>> +#define        PROT_WRITE      0x02    /* pages can be written */
>>> +#define        PROT_EXEC       0x04    /* pages can be executed */
>>> + * Flags contain sharing type and options.
>>> + * Sharing types; choose one.
>>> +#define        MAP_SHARED      0x0001  /* share changes */
>>> +#define        MAP_PRIVATE     0x0002  /* changes are private */
>>> +#ifdef _KERNEL
>>> + * Deprecated flag; these are treated as MAP_PRIVATE internally by
>>> + * the kernel.
>>> +#define        MAP_COPY        0x0004  /* "copy" region at mmap time */
>>> +#endif
>>> + * Other flags
>>> +#define        MAP_FIXED        0x0010 /* map addr must be exactly as requested */
>>> +#define        MAP_RENAME       0x0020 /* Sun: rename private pages to file */
>>> +#define        MAP_NORESERVE    0x0040 /* Sun: don't reserve needed swap area */
>>> +#define        MAP_INHERIT      0x0080 /* region is retained after exec */
>>> +#define        MAP_HASSEMAPHORE 0x0200 /* region may contain semaphores */
>>> +#define        MAP_TRYFIXED     0x0400 /* attempt hint address, even within break */
>>> +#define        MAP_WIRED        0x0800 /* mlock() mapping when it is established */
>>> + * Mapping type
>>> +#define        MAP_FILE        0x0000  /* map from file (default) */
>>> +#define        MAP_ANON        0x1000  /* allocated from memory, swap space */
>>> + * Alignment (expressed in log2).  Must be >= log2(PAGE_SIZE) and
>>> + * < # bits in a pointer (26 (acorn26), 32 or 64).
>>> +#define        MAP_ALIGNED(n)          ((n) << MAP_ALIGNMENT_SHIFT)
>>> +#define        MAP_ALIGNMENT_SHIFT     24
>>> +#define        MAP_ALIGNMENT_MASK      MAP_ALIGNED(0xff)
>>> +#define        MAP_ALIGNMENT_64KB      MAP_ALIGNED(16) /* 2^16 */
>>> +#define        MAP_ALIGNMENT_16MB      MAP_ALIGNED(24) /* 2^24 */
>>> +#define        MAP_ALIGNMENT_4GB       MAP_ALIGNED(32) /* 2^32 */
>>> +#define        MAP_ALIGNMENT_1TB       MAP_ALIGNED(40) /* 2^40 */
>>> +#define        MAP_ALIGNMENT_256TB     MAP_ALIGNED(48) /* 2^48 */
>>> +#define        MAP_ALIGNMENT_64PB      MAP_ALIGNED(56) /* 2^56 */
>>> + * Error indicator returned by mmap(2)
>>> +#define        MAP_FAILED      ((void *) -1)   /* mmap() failed */
>>> + * Flags to msync
>>> +#define        MS_ASYNC        0x01    /* perform asynchronous writes */
>>> +#define        MS_INVALIDATE   0x02    /* invalidate cached data */
>>> +#define        MS_SYNC         0x04    /* perform synchronous writes */
>>> + * Flags to mlockall
>>> +#define        MCL_CURRENT     0x01    /* lock all pages currently mapped */
>>> +#define        MCL_FUTURE      0x02    /* lock all pages mapped in the future */
>>> +#if defined(_NETBSD_SOURCE)
>>> + * Advice to madvise
>>> +#define        MADV_NORMAL     0       /* no further special treatment */
>>> +#define        MADV_RANDOM     1       /* expect random page references */
>>> +#define        MADV_SEQUENTIAL 2       /* expect sequential page references */
>>> +#define        MADV_WILLNEED   3       /* will need these pages */
>>> +#define        MADV_DONTNEED   4       /* dont need these pages */
>>> +#define        MADV_SPACEAVAIL 5       /* insure that resources are reserved */
>>> +#define        MADV_FREE       6       /* pages are empty, free them */
>>> + * Flags to minherit
>>> +#define        MAP_INHERIT_SHARE       0       /* share with child */
>>> +#define        MAP_INHERIT_COPY        1       /* copy into child */
>>> +#define        MAP_INHERIT_NONE        2       /* absent from child */
>>> +#define        MAP_INHERIT_DONATE_COPY 3       /* copy and delete -- not
>>> +                                          implemented in UVM */
>>> +#define        MAP_INHERIT_DEFAULT     MAP_INHERIT_COPY
>>> +#endif
>>> +#ifndef _KERNEL
>>> +#include <sys/cdefs.h>
>>> +__BEGIN_DECLS
>>> +void   *mmap(void *, size_t, int, int, int, off_t);
>>> +int    munmap(void *, size_t);
>>> +int    mprotect(void *, size_t, int);
>>> +#ifndef __LIBC12_SOURCE__
>>> +#if defined(__rtems__)
>>> +int    msync(void *, size_t, int);
>>> +#else
>>> +int    msync(void *, size_t, int) __RENAME(__msync13);
>>> +#endif
>>> +#endif
>>> +int    mlock(const void *, size_t);
>>> +int    munlock(const void *, size_t);
>>> +int    mlockall(int);
>>> +int    munlockall(void);
>>> +int    madvise(void *, size_t, int);
>>> +int    mincore(void *, size_t, char *);
>>> +int    minherit(void *, size_t, int);
>>> +#endif
>>> +__END_DECLS
>>> +#endif /* !_KERNEL */
>>> +#endif /* !_SYS_MMAN_H_ */
>>> diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
>>> index 6e3f2a2..1b65213 100644
>>> --- a/cpukit/posix/preinstall.am
>>> +++ b/cpukit/posix/preinstall.am
>>> @@ -43,6 +43,15 @@ $(PROJECT_INCLUDE)/rtems/posix/posixapi.h: include/rtems/posix/posixapi.h $(PROJ
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>>> +$(PROJECT_INCLUDE)/sys/$(dirstamp):
>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/sys
>>> +       @: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/sys/$(dirstamp)
>>> +$(PROJECT_INCLUDE)/sys/mman.h: include/sys/mman.h $(PROJECT_INCLUDE)/sys/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/mman.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/mman.h
>>>  if HAS_PTHREADS
>>>  $(PROJECT_INCLUDE)/aio.h: include/aio.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/aio.h
>>> diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
>>> index 0000000..2798326
>>> --- /dev/null
>>> +++ b/cpukit/posix/src/mmap.c
>>> @@ -0,0 +1,26 @@
>>> + * @file
>>> + *  COPYRIGHT (c) 2014.
>>> + *  On-Line Applications Research Corporation (OAR).
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this distribution or at
>>> + *  http://www.rtems.org/license/LICENSE.
>>> +#if HAVE_CONFIG_H
>>> +#include "config.h"
>>> +#endif
>>> +#include <sys/mman.h>
>>> +int munmap(
>>> +  void   *addr __attribute__((unused)),
>>> +  size_t  length __attribute__((unused))
>>> +  return -1;
>>> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
>>> index 51b565e..94bd316 100644
>>> --- a/cpukit/posix/src/mprotect.c
>>> +++ b/cpukit/posix/src/mprotect.c
>>> @@ -28,16 +28,10 @@
>>>  #endif
>>>  #include <unistd.h>
>>> - * RTEMS does not have <sys/mman.h> so we need a prototype here to
>>> - * avoid warnings.
>>> -int mprotect( const void *, size_t, int );
>>>  int mprotect(
>>> -  const void *addr __attribute__((unused)),
>>>    size_t len __attribute__((unused)),
>>>    int prot __attribute__((unused)) )
>>> diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
>>> index 0000000..3ebb2f4
>>> --- /dev/null
>>> +++ b/cpukit/posix/src/munmap.c
>>> @@ -0,0 +1,30 @@
>>> + * @file
>>> +#if HAVE_CONFIG_H
>>> +#endif
>>> +void *mmap(
>>> +  size_t  lenhth __attribute__((unused)),
>>> +  int     prot __attribute__((unused)),
>>> +  int     flags __attribute__((unused)),
>>> +  int     fildes __attribute__((unused)),
>>> +  off_t   off
>>> +  return NULL;
>>> 1.9.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
