[PATCH 4/4] libtests/malloctest/init.c: Fix warning
Thu Nov 20 02:34:23 UTC 2014
I'd prefer to see it hidden behind a macro, like other
compiler-specific stuff (e.g. attributes). It could go in tmacros
also, since it should be restricted to testing.
I will oppose any #pragma within cpukit or c subdirectories.
-Gedare
On Wed, Nov 19, 2014 at 5:45 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 11/19/2014 4:32 PM, Chris Johns wrote:
>> On 20/11/2014 6:59 am, Joel Sherrill wrote:
>>> +  #pragma GCC diagnostic push
>>> +  #pragma GCC diagnostic ignored "-Wnonnull"
>> Do we allow the use of #pragma in RTEMS ?
> I would say no except for this one particular class.
> If a method has the proper prototype with the attribute
> "nonnull" on a parameter AND you compiler with -Wnon-null,
> then you get a warning for passing a NULL if GCC can detect it.
> If a user doesn't compile with this option, then you need a
> run-time check and we have them. And we have to test those
> NULL checks.
> This is TEST code and we are intentionally passing a
> hard-coded NULL value in to exercise the run-time check.
> We always compile with -Wnon-null so we have to disable
> the check for this one specific type of test on methods which
> have parameters with this attribute.
> Once Trac/Wiki is back up, that should be added to the
> Coding Conventions.
> FWIW I have never used a pragma in C or C++ before this. Use would
> have to be very special and justified than this in test code.
>> Chris
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
