[PATCH 2/4] sys/mman.h: New file. Clean up and add supporting stubs
Thu Nov 20 02:37:18 UTC 2014
On November 19, 2014 8:31:46 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>OK great
I have an updated version of the patch. Something wasn't right with the mskefile that showed up later. Not sure how it built before. :(
>On Wed, Nov 19, 2014 at 5:04 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> On 11/19/2014 2:55 PM, Gedare Bloom wrote:
>>> Is this the same one that Chris has had in use before? (I think that
>>> is who had one in use..)
>> Yes. You wanted it in rtems to avoid me having to add a prototype to
>a file
>> to avoid a warning.
>> I didn't integrate his implementation but only his .h file and stubs.
>His
>> implementation will need the addition of tests and code in
>confdefs.h.
>> --joel
>>> -Gedare
>>> On Wed, Nov 19, 2014 at 2:59 PM, Joel Sherrill
>>>>         * Makefile.am updated and preinstall.am regenerated.
>>>>         * mprotect.c had a prototype removed now that we have
>mman.h
>>>>         * mmap.c, munmap.c: New stub files.
>>>>  cpukit/posix/Makefile.am        |   5 ++
>>>>  cpukit/posix/include/sys/mman.h | 189
>>>>  cpukit/posix/preinstall.am      |   9 ++
>>>>  cpukit/posix/src/mmap.c         |  26 ++++++
>>>>  cpukit/posix/src/mprotect.c     |  10 +--
>>>>  cpukit/posix/src/munmap.c       |  30 +++++++
>>>>  6 files changed, 261 insertions(+), 8 deletions(-)
>>>>  create mode 100644 cpukit/posix/include/sys/mman.h
>>>>  create mode 100644 cpukit/posix/src/mmap.c
>>>>  create mode 100644 cpukit/posix/src/munmap.c
>>>> diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
>>>> index 346b65a..b3be07c 100644
>>>> --- a/cpukit/posix/Makefile.am
>>>> +++ b/cpukit/posix/Makefile.am
>>>> @@ -21,6 +21,9 @@ include_rtems_posix_HEADERS +=
>include/rtems/posix/keyimpl.h
>>>>  include_rtems_posix_HEADERS += include/rtems/posix/config.h
>>>>  include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
>>>> +include_sysdir = $(includedir)/sys
>>>> +include_sys_HEADERS = include/sys/mman.h
>>>>  if HAS_PTHREADS
>>>>  # include
>>>>  include_HEADERS = include/aio.h
>>>> @@ -91,7 +94,9 @@ libposix_a_SOURCES += src/cond.c
>src/condattrdestroy.c \
>>>>      src/condtimedwait.c src/condwait.c src/condwaitsupp.c
>src/condget.c
>>>>  ## MEMORY_C_FILES
>>>> +libposix_a_SOURCES += src/mmap.c
>>>>  libposix_a_SOURCES += src/mprotect.c
>>>> +libposix_a_SOURCES += src/munmap.c
>>>>  ## MESSAGE_QUEUE_C_FILES
>>>>  libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
>>>> diff --git a/cpukit/posix/include/sys/mman.h
>b/cpukit/posix/include/sys/mman.h
>>>> new file mode 100644
>>>> index 0000000..ddf34cc
>>>> --- /dev/null
>>>> +++ b/cpukit/posix/include/sys/mman.h
>>>> @@ -0,0 +1,189 @@
>>>> +/*     $NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $
>>>> + * Copyright (c) 1982, 1986, 1993
>>>> + *     The Regents of the University of California.  All rights
>reserved.
>>>> + * Redistribution and use in source and binary forms, with or
>without
>>>> + * modification, are permitted provided that the following
>conditions
>>>> + * are met:
>>>> + * 1. Redistributions of source code must retain the above
>copyright
>>>> + *    notice, this list of conditions and the following
>disclaimer.
>>>> + * 2. Redistributions in binary form must reproduce the above
>copyright
>>>> + *    notice, this list of conditions and the following disclaimer
>in the
>>>> + *    documentation and/or other materials provided with the
>distribution.
>>>> + * 3. Neither the name of the University nor the names of its
>contributors
>>>> + *    may be used to endorse or promote products derived from this
>software
>>>> + *    without specific prior written permission.
>>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS
>IS'' AND
>>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>TO, THE
>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>PARTICULAR PURPOSE
>>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS
>BE LIABLE
>>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>CONSEQUENTIAL
>>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>SUBSTITUTE GOODS
>>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>INTERRUPTION)
>>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>CONTRACT, STRICT
>>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
>IN ANY WAY
>>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>POSSIBILITY OF
>>>> + * SUCH DAMAGE.
>>>> + *     @(#)mman.h      8.2 (Berkeley) 1/9/95
>>>> +#ifndef _SYS_MMAN_H_
>>>> +#define _SYS_MMAN_H_
>>>> +#ifdef __rtems__
>>>> +#include <inttypes.h>
>>>> +#include <stddef.h>
>>>> +#include <sys/types.h>
>>>> +#else /* __rtems__ */
>>>> +#include <sys/featuretest.h>
>>>> +#include <machine/ansi.h>
>>>> +#ifdef _BSD_SIZE_T_
>>>> +typedef        _BSD_SIZE_T_    size_t;
>>>> +#undef _BSD_SIZE_T_
>>>> +#endif
>>>> +#include <sys/ansi.h>
>>>> +#ifndef        mode_t
>>>> +typedef        __mode_t        mode_t;
>>>> +#define        mode_t          __mode_t
>>>> +#endif
>>>> +#ifndef        off_t
>>>> +typedef        __off_t         off_t;          /* file offset */
>>>> +#define        off_t           __off_t
>>>> +#endif
>>>> +#endif /* __rtems__ */
>>>> + * Protections are chosen from these bits, or-ed together
>>>> +#define        PROT_NONE       0x00    /* no permissions */
>>>> +#define        PROT_READ       0x01    /* pages can be read */
>>>> +#define        PROT_WRITE      0x02    /* pages can be written */
>>>> +#define        PROT_EXEC       0x04    /* pages can be executed */
>>>> + * Flags contain sharing type and options.
>>>> + * Sharing types; choose one.
>>>> +#define        MAP_SHARED      0x0001  /* share changes */
>>>> +#define        MAP_PRIVATE     0x0002  /* changes are private */
>>>> +#ifdef _KERNEL
>>>> + * Deprecated flag; these are treated as MAP_PRIVATE internally by
>>>> + * the kernel.
>>>> +#define        MAP_COPY        0x0004  /* "copy" region at mmap
>time */
>>>> +#endif
>>>> + * Other flags
>>>> +#define        MAP_FIXED        0x0010 /* map addr must be exactly
>as requested */
>>>> +#define        MAP_RENAME       0x0020 /* Sun: rename private
>pages to file */
>>>> +#define        MAP_NORESERVE    0x0040 /* Sun: don't reserve
>needed swap area */
>>>> +#define        MAP_INHERIT      0x0080 /* region is retained after
>exec */
>>>> +#define        MAP_HASSEMAPHORE 0x0200 /* region may contain
>semaphores */
>>>> +#define        MAP_TRYFIXED     0x0400 /* attempt hint address,
>even within break */
>>>> +#define        MAP_WIRED        0x0800 /* mlock() mapping when it
>is established */
>>>> + * Mapping type
>>>> +#define        MAP_FILE        0x0000  /* map from file (default)
>>>> +#define        MAP_ANON        0x1000  /* allocated from memory,
>swap space */
>>>> + * Alignment (expressed in log2).  Must be >= log2(PAGE_SIZE) and
>>>> + * < # bits in a pointer (26 (acorn26), 32 or 64).
>>>> +#define        MAP_ALIGNED(n)          ((n) <<
>MAP_ALIGNMENT_SHIFT)
>>>> +#define        MAP_ALIGNMENT_SHIFT     24
>>>> +#define        MAP_ALIGNMENT_MASK      MAP_ALIGNED(0xff)
>>>> +#define        MAP_ALIGNMENT_64KB      MAP_ALIGNED(16) /* 2^16 */
>>>> +#define        MAP_ALIGNMENT_16MB      MAP_ALIGNED(24) /* 2^24 */
>>>> +#define        MAP_ALIGNMENT_4GB       MAP_ALIGNED(32) /* 2^32 */
>>>> +#define        MAP_ALIGNMENT_1TB       MAP_ALIGNED(40) /* 2^40 */
>>>> +#define        MAP_ALIGNMENT_256TB     MAP_ALIGNED(48) /* 2^48 */
>>>> +#define        MAP_ALIGNMENT_64PB      MAP_ALIGNED(56) /* 2^56 */
>>>> + * Error indicator returned by mmap(2)
>>>> +#define        MAP_FAILED      ((void *) -1)   /* mmap() failed */
>>>> + * Flags to msync
>>>> +#define        MS_ASYNC        0x01    /* perform asynchronous
>writes */
>>>> +#define        MS_INVALIDATE   0x02    /* invalidate cached data
>>>> +#define        MS_SYNC         0x04    /* perform synchronous
>writes */
>>>> + * Flags to mlockall
>>>> +#define        MCL_CURRENT     0x01    /* lock all pages currently
>mapped */
>>>> +#define        MCL_FUTURE      0x02    /* lock all pages mapped in
>the future */
>>>> +#if defined(_NETBSD_SOURCE)
>>>> + * Advice to madvise
>>>> +#define        MADV_NORMAL     0       /* no further special
>treatment */
>>>> +#define        MADV_RANDOM     1       /* expect random page
>references */
>>>> +#define        MADV_SEQUENTIAL 2       /* expect sequential page
>references */
>>>> +#define        MADV_WILLNEED   3       /* will need these pages */
>>>> +#define        MADV_DONTNEED   4       /* dont need these pages */
>>>> +#define        MADV_SPACEAVAIL 5       /* insure that resources
>are reserved */
>>>> +#define        MADV_FREE       6       /* pages are empty, free
>them */
>>>> + * Flags to minherit
>>>> +#define        MAP_INHERIT_SHARE       0       /* share with child
>>>> +#define        MAP_INHERIT_COPY        1       /* copy into child
>>>> +#define        MAP_INHERIT_NONE        2       /* absent from
>child */
>>>> +#define        MAP_INHERIT_DONATE_COPY 3       /* copy and delete
>-- not
>>>> +                                          implemented in UVM */
>>>> +#define        MAP_INHERIT_DEFAULT     MAP_INHERIT_COPY
>>>> +#endif
>>>> +#ifndef _KERNEL
>>>> +#include <sys/cdefs.h>
>>>> +__BEGIN_DECLS
>>>> +void   *mmap(void *, size_t, int, int, int, off_t);
>>>> +int    munmap(void *, size_t);
>>>> +int    mprotect(void *, size_t, int);
>>>> +#ifndef __LIBC12_SOURCE__
>>>> +#if defined(__rtems__)
>>>> +int    msync(void *, size_t, int);
>>>> +#else
>>>> +int    msync(void *, size_t, int) __RENAME(__msync13);
>>>> +#endif
>>>> +#endif
>>>> +int    mlock(const void *, size_t);
>>>> +int    munlock(const void *, size_t);
>>>> +int    mlockall(int);
>>>> +int    munlockall(void);
>>>> +int    madvise(void *, size_t, int);
>>>> +int    mincore(void *, size_t, char *);
>>>> +int    minherit(void *, size_t, int);
>>>> +#endif
>>>> +__END_DECLS
>>>> +#endif /* !_KERNEL */
>>>> +#endif /* !_SYS_MMAN_H_ */
>>>> diff --git a/cpukit/posix/preinstall.am
>b/cpukit/posix/preinstall.am
>>>> index 6e3f2a2..1b65213 100644
>>>> --- a/cpukit/posix/preinstall.am
>>>> +++ b/cpukit/posix/preinstall.am
>>>> @@ -43,6 +43,15 @@ $(PROJECT_INCLUDE)/rtems/posix/posixapi.h:
>include/rtems/posix/posixapi.h $(PROJ
>>>>         $(INSTALL_DATA) $<
>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>>>> +$(PROJECT_INCLUDE)/sys/$(dirstamp):
>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/sys
>>>> +       @: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/sys/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/sys/mman.h: include/sys/mman.h
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/sys/mman.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/sys/mman.h
>>>>  if HAS_PTHREADS
>>>>  $(PROJECT_INCLUDE)/aio.h: include/aio.h
>$(PROJECT_INCLUDE)/$(dirstamp)
>>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/aio.h
>>>> diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
>>>> index 0000000..2798326
>>>> --- /dev/null
>>>> +++ b/cpukit/posix/src/mmap.c
>>>> @@ -0,0 +1,26 @@
>>>> + * @file
>>>> + *  COPYRIGHT (c) 2014.
>>>> + *  On-Line Applications Research Corporation (OAR).
>>>> + *  The license and distribution terms for this file may be
>>>> + *  found in the file LICENSE in this distribution or at
>>>> + *  http://www.rtems.org/license/LICENSE.
>>>> +#if HAVE_CONFIG_H
>>>> +#include "config.h"
>>>> +#endif
>>>> +#include <sys/mman.h>
>>>> +int munmap(
>>>> +  void   *addr __attribute__((unused)),
>>>> +  size_t  length __attribute__((unused))
>>>> +  return -1;
>>>> diff --git a/cpukit/posix/src/mprotect.c
>b/cpukit/posix/src/mprotect.c
>>>> index 51b565e..94bd316 100644
>>>> --- a/cpukit/posix/src/mprotect.c
>>>> +++ b/cpukit/posix/src/mprotect.c
>>>> @@ -28,16 +28,10 @@
>>>>  #endif
>>>>  #include <unistd.h>
>>>> - * RTEMS does not have <sys/mman.h> so we need a prototype here to
>>>> - * avoid warnings.
>>>> -int mprotect( const void *, size_t, int );
>>>>  int mprotect(
>>>> -  const void *addr __attribute__((unused)),
>>>>    size_t len __attribute__((unused)),
>>>>    int prot __attribute__((unused)) )
>>>> diff --git a/cpukit/posix/src/munmap.c b/cpukit/posix/src/munmap.c
>>>> index 0000000..3ebb2f4
>>>> --- /dev/null
>>>> +++ b/cpukit/posix/src/munmap.c
>>>> @@ -0,0 +1,30 @@
>>>> + * @file
>>>> +#if HAVE_CONFIG_H
>>>> +#endif
>>>> +void *mmap(
>>>> +  size_t  lenhth __attribute__((unused)),
>>>> +  int     prot __attribute__((unused)),
>>>> +  int     flags __attribute__((unused)),
>>>> +  int     fildes __attribute__((unused)),
>>>> +  off_t   off
>>>> +  return NULL;
>>>> 1.9.3
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
